Finished IZZYS96SE's box this morning and installed it
Old 03-21-2004, 10:48 AM
  #41
Maxima Dan's Avatar
I was just joking about the expectations. Very clean, looks good.
Did you calculate it as a slot or as a square port?
Maxima Dan is offline
Old 03-21-2004, 12:09 PM
  #42
friendhasmax's Avatar
i calculated it as a slot.
friendhasmax is offline
Old 03-21-2004, 07:33 PM
  #43
AscendantMax's Avatar
thanks for the link
AscendantMax is offline
Old 03-22-2004, 06:05 AM
  #44
Originally Posted by Fosgate Fan
thanks for the link
no prob
Old 03-22-2004, 11:36 AM
  #45
stephenlc's Avatar
where do you get the carpet from?
stephenlc is offline
Old 03-22-2004, 04:12 PM
  #46
www.partsexpress.com
Old 03-24-2004, 11:00 AM
  #47
Maxima Dan's Avatar
FYI. A port is considered slotted if it is using an existing wall of the enclosure as a part of the port. So you should only be using 3 pieces of wood extra to create the port. The remaining side of the port will be the side, top, or bottom of the enclosure.
Old 03-24-2004, 06:50 PM
  #48
FYI. You are wrong Maxima Dan. A slot port is one in which the length and width are in correct proportion as to minimize port turbulance. the type of slot port that you mention is a special case of a SLOT port in which the pieces of the box are used as part of the port. just because my slot port didnt use a part of the wall, top or bottom, does not mean that it is not a slot port. i don't know where you get your information from, but you are wrong...in any even, the port that you mention is normally referred to as a transmission line.
Old 03-29-2004, 10:23 AM
  #49
Maxima Dan's Avatar
Port area and length determine the max air speed of the port. Doesn't matter the shape of the port, although flared ports will produce less turbulance than sharp edged ports. Thereby allowing the use of a smaller dia port than would otherwise be used. The port length calculator you used is applying an end correction factor making the effective length of the port longer than the actual length. Those calculators are meant to get you in the ballpark anyway. To get the correct tuning frequency you need to measure, cut, and measure again.
BTW a TL is a non-ressonant enclosure that combines the rear energy of the woofer with the front energy of the cone.
Old 03-29-2004, 06:30 PM
  #50
"BTW a TL is a non-ressonant enclosure that combines the rear energy of the woofer with the front energy of the cone"
duh, thats the purpose of any port!! and i know abot the end correction factor...and it makes a very little difference on tuning frquency anyway.....just let it be man, ur just wasting ur time here
Old 03-29-2004, 10:11 PM
  #51
HitManSE's Avatar
Looks nice man, thats a damn good install
HitManSE is offline
Old 03-30-2004, 04:28 AM
  #52
thanks....go check out the one i did for manny
Old 03-30-2004, 05:45 AM
  #53
HitManSE's Avatar
One step ahead of you I already did, just didnt leave a comment, both look sick though
HitManSE is offline
Old 03-30-2004, 07:46 AM
  #54
IZZYS96SE's Avatar
Still Getting Hits?? Your Going To Be Famous!! Hahahaha...
IZZYS96SE is offline
Old 03-30-2004, 09:11 AM
  #55
Maxima Dan's Avatar
No, it's not the purpose of any port! A vented enclosure uses resonance, hence the tuning frequency, to contribute to the sound. A TL passes the rear wave of the woofer through a vent such that it is back in phase with the front.
Old 03-30-2004, 07:17 PM
  #56
ur so correct...my appologies..i just skimmed through my book (great sound stereo speaker manual)...im sorry
matts95max
09-09-2023 01:52 AM
The Frye
09-02-2021 11:03 AM
MaxLife17
06-27-2019 01:37 PM
trungg86
09-04-2015 04:58 AM
Johnny9595
09-03-2015 05:18 AM
Quick Reply: Finished IZZYS96SE's box this morning and installed it
