Need help with XBOX installtion in my 95 MAX!!
Old 12-26-2003, 11:08 PM
kyllr's Avatar
So far i got my alpine 9518 and a farenheit 7" LCD installed. Now i want ot put my xbox in the car. I have a couple of questions if anyone has done it or have knowledge.
1. is under the passenger seat a good place to put it?
2. if i use a power inverter. can i just splice into the cig lighter wires and solder it there to looks nicer? Also if the Xbox is always plugged into the inverter will i have any problems with my cars electrical system.
3. Is the Xbox a better choice or should i go with mini DVd player is see here in that Redamx is selling.
4. Ok i have last question reguarding my Farenheit lcd. is there any way to turnt he lcd on/off with using the remote control? im afraid i might lose the remote and will not able to use anymore.
Any input will be greatly appreciated!!!
kyllr is offline
Old 12-27-2003, 12:54 PM
DerekJ212's Avatar
I have done this before..
1. It will not fit under the passenger seat but since you can raise the driver seat up, it will fit under there.
2. Yes, and it will all be fine.
3. Chip your XBOX like me and it will be perfect! Use XBOX Media Player for all your media needs!
4. I have a RedMax so i dont know...
Let me know if you need any help with anything about this..it is awesome when finished!
Derek
DerekJ212 is offline
Old 12-27-2003, 12:55 PM
DerekJ212's Avatar
Ooops, one thing about #2. Instead of hardwiring to the cig lighter, run a small cable and fuse it directly from the battery. Be sure the ground you choose is very good or else you will get all kinds of noise. Lastly, FUSE FUSE FUSE, if you run a wire from the battery and dont fuse it, youll have what happened to me, a near electrical fire in the car.
Derek
Old 12-27-2003, 02:18 PM
kyllr's Avatar
cool thanks i already have evox on my xbox awesome
kyllr is offline
Old 12-27-2003, 02:24 PM
kyllr's Avatar
Do you use a remote or a controller for the xbox media player?
kyllr is offline
Old 12-27-2003, 10:35 PM
EriCCirE's Avatar
u use a controller
EriCCirE is offline
Old 12-28-2003, 09:03 AM
kickyoazzz's Avatar
what is this mod chip? and what can it do?
kickyoazzz is offline
Old 12-28-2003, 05:51 PM
EriCCirE's Avatar
A mod chip lets you run unsigned code. What that means is, it will let you run programs that will let you play and copy games to the hard drive. You can also upgrade your harddrive to a larger one and have more games on the hard drive. So you can rents games and heve them forever.
EriCCirE is offline
Old 12-29-2003, 04:19 AM
Master Will
metallic97gxe's Avatar
http://forums.maxima.org/showthread.php?t=273264
metallic97gxe is offline
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
magiconthetire
10-26-2015 09:03 PM
maxima297
09-30-2015 03:32 PM
Quick Reply: Need help with XBOX installtion in my 95 MAX!!
