'92 SE Ground spot? How anout through the firewall?
Old 04-16-2003, 09:44 PM
todamax's Avatar
Never put amps in, I've got 2 Blaupunkts sitting in the box...
(and a third comming soon!)
Where is the best place to ground in the trunk?
Is there a "good" spot for through the firewall?
Thanks!
todamax is offline
Old 04-17-2003, 06:07 AM
Decal Specialist
erty67's Avatar
Re: '92 SE Ground spot? How anout through the firewall?
Thanks!
try pulling the panel off of the inside of the truck. You should be able to find a bolt that bolts into the inside of the rear quarter somewhere(usually holding something like the power antenna or a relay). Just make sure you sand down the paint around it, so you get a good metal to metal contact.
erty67 is offline
06-06-2017 02:01 PM
fastcarny
10-12-2015 07:06 AM
homewrecker
09-23-2015 03:41 AM
Quick Reply: '92 SE Ground spot? How anout through the firewall?
