Go Back   Maxima Forums > Maintenance, Tech, & Care > Audio and Electronics
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Sponsored by:
Click Here
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 10-12-2002, 12:49 PM   #1
Constant to Momentary circuit for windows
I'm trying to wire a ground output from my alarm (.8 sec, 10 sec, or 30 sec) to make my windows go down. I have already wired the relays in the door, so I can hit the wire (that I ran to the cabin) to ground and the window goes down.
I've been trying to use this circuit from the12volt.com:
Click the image to open in full size.
Found Here
Only instead of constant fused +12v and momentary 12v output, I'm using ground on pins 87 and 30.
With the 1K uF cap, it's supposed to put out 1/2 sec. output, but I need 3 sec. for my windows so I am using 5.9K uF worth of caps, but I still get only about half a second. Anyone have any experience with this? Is it not a linear increase for time vs. capacity? Is there an easier way?
-Smitty
__________________
DJSmitty is offline   Reply With Quote
Old 10-13-2002, 06:59 AM   #2
I tend to get a bit irritable
Pearl96Max's Avatar
Points: 29,990, Level: 99
Points: 29,990, Level: 99 Points: 29,990, Level: 99 Points: 29,990, Level: 99
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
Send a message via AIM to Pearl96Max
Re: Constant to Momentary circuit for windows
Found Here
-Smitty
In all honesty...invest into a DEI module, 530T. It will save you alot of time and frustration.
My $.02
--Don
__________________
Clifford remote start GD
My 4550 lb SUV is faster than your 14 sec VQ
DVI-9990/TMI-M990/PXI-H990
Brax Matrix MX4 ..Dynaudio Esotar 1200 X 2
Brax Matrix MX4 ..Dynaudio Esotar 110 and 430
..Dynaudio Esotar 650
Straightwire,Stealth Cables,Cascade,Clifford,
Pearl96Max is offline   Reply With Quote
Old 10-13-2002, 08:29 AM   #3
You might be right, but MSRP on dei.com is $147.00, and that's a little too expensive to have the windows go up and down. I got to college, so I'll ask one of the EE professors this week I guess.
-Smitty
Old 10-14-2002, 04:18 AM   #4
Pearl96Max's Avatar
Activity: 7.1%
I can provide the module for you..for alot less than that.
There are several other features as well though. Like windows up when you arm your alarm,one touch windows up and down. roll windows down either all the way, or in increments via your remote.
--Don
__________________
Old 10-14-2002, 01:42 PM   #5
Points: 8,631, Level: 62
Points: 8,631, Level: 62 Points: 8,631, Level: 62 Points: 8,631, Level: 62
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Ok looks like you are going about it backwards. You need to get a circuit that will keep a momentary ground low for a few seconds instead of limiting a high to a few seconds. Your diagram will take a 12v permanant or switched source and limit it to 1/2 sec tops. The source side will stay at 12v and the rc time constant side (resistor and capacitor side) will start at ground , activating the relay, and charge to 12volts in 1/2 sec. Once it reaches about 9 volts the relay deenergizes because both of its coil contacts are near the same potential.
You need a timer circuit that keeps ground potential for 3 seconds and then floats. You can do this by a similar rc circuit with 1 capacitor and two resistor but it will leave your alarm output vulnerable. I would simply go to radio shack and buy a 555 timer ic. The ic's instructions show you how to build a circuit for under five dollars. And give you values for different durations if you need the output shorter or longer.
gp1.2k is offline   Reply With Quote
Old 10-14-2002, 10:39 PM   #6
If the relay switch point will be at around 9V you need to come up with a RC combination that will be at least 3s for one time constant, since 1 time constant will be between 8-9V.
You should be able to increase both R and C to come up with the necessary value. Unless the relay is opening up sooner than with a difference in 3V. You might need to test the relay or at least look at the data sheet for it and determine how much voltage is needed to maintain contact. If it is more than like 3 or 4V you might need to go with a different circuit.
Maxima Dan is offline   Reply With Quote
Old 10-14-2002, 11:30 PM   #7
Points: 13,588, Level: 75
Points: 13,588, Level: 75 Points: 13,588, Level: 75 Points: 13,588, Level: 75
Activity: 0%
Re: Re: Constant to Momentary circuit for windows
Quote:
My $.02
--Don
Yep, I installed this module last week. Works like a charm. Must choose particular options of what you want the power windows to do. Great option for summertime months. Look on Ebay, they usually have these and the 529T also. I won mine for $56.00!
MIXXMAX is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
