4th gen trunk questions
which part of the trunk rattles the most? I'm trying to get rid of all the rattles. I also noticed a loud rattle underneath the trunk, but I can't figure out where it's from, any ideas? Also, is that metal piece with the trunk passthrough nessesary? I removed mine to get more bass.
Personally I am sick of the little plastic tensioner holder..I have gone thru 8 of those freakin things since I have bought the car...
I am sick of that piece and cannot figure out why they keep getting stress breaks.
Originally posted by jmax
What plastic tensioner in the trunk?
It is the square plastic piece that holds the two metal tensioner bars that cross in the middle under the back dash...they re tensioners for the trunk opening system.
What plastic tensioner in teh trunk? As for the original question the noise under the trunk is probably the exhaust heat shielding vibrating against the muffler. It should be pretty simple to diagnose and rebend.
WizzaMax can we do without those bars? They are very much in the way of my box.
Originally posted by Unibomber
your trunk lid wont stay up
Have you tried the same pressure test on the rear license plate and the lock mechanism in the trunk lid? Also, the tail fin can resonate, tail lights, just about anything.
That rattling under your car is probably the shield they are talking about. It will rattle with just the smallest vibration. All you have to do is turn on your radio so it vibrates,get under the car and just end and move it all over till you find where its vibrating.
its not the heat shield i have all of mine removed they POS are useless...my car still has a rattle...inside by the wheel in the trunk u will see a box with holes this lets the air out of your trunk when u close the lid it has rubber flaps on it that vibrates those make ALOT of noise it could be this..
i have come to the realization u wont get every noise but who care when u have your car turned up u cant hear a thing HAH
Finkle
09-27-2015 09:53 PM
ViciousVQ30
08-05-2015 05:40 PM
