I took a peak under...
... the rear deck of my 2k3; on the right, there is what look like an upside-down amp, marked "Bose" : is it the processor/equalizer for the system? Also, just under the sub, there is a brownie-sized metallic box : is it the sub amp?
Originally posted by Stereodude
The black box is the amp. The brown thing under your sub might be the connector for it? The amp for the sub is built into the sub.
Stereodude
Stereodude
Originally posted by dracip
So, could someone tap the wires (line-level signal,I assume) bound to the Bose amps using rca connectors, then straight to aftermarket amps?
Tony
MaximaDrvr
08-19-2015 08:20 PM
