2000 Maxima 3.5 Swap Thread
Old 11-28-2014, 10:24 PM
TravisCadello's Avatar
238k miles i blew head gaskets on my 3.0..its supercharged @ 10psi, so got a really good deal on a 2004 Maxima motor with 78xxx Miles. But reading all these stickies their from 10 years ago so none of the pictures even show up Figured Id start this thread to see if anybody could help me through out my swap.
As of right now i have a couple questions.
1- do you guys just bolt in the cam gear sensors on head and leave them their not plugged in since 3.0 timing reading off cam gear iteself?
2-Anybody have a link to where i get the cam gear spacers? And possibly aa write up with working pics on this?
3-Should i use my 00 intake manifold or the mevi?
Thanks guys
TravisCadello is offline
Old 11-29-2014, 06:51 AM
aackshun's Avatar
1. Yes or you'll be leakin da oilz.
2. It's very self explanitory, hell if you're keeping the S/C you could just use 3.0 intake cams and 3.5 exhaust cams, if you can not get in contact with Stephen Max anymore.
3. Jesus christ lord 1/2 mercy, don't ever fathom the idea. Stop. Every time you think of doing that, a little puppy gets ran over in SE Houston.
aackshun is offline
Old 11-30-2014, 04:58 PM
lmao i dont know about 3.0 intake cam and 3.5 exhaust cam thats like defeating the whole purpose of the swap not only that it'll never get tuned right light that.
whens the last time stephen max sold them? is it something thats outdated and nobody sells them anymore? if so then it getting another 3.0.
Old 11-30-2014, 06:50 PM
schmellyfart's Avatar
Um no its not.
schmellyfart is offline
Old 12-01-2014, 07:02 AM
MoncefA33's Avatar
This thread is awesome.
MoncefA33 is offline
Old 12-01-2014, 08:54 PM
aackshun's Avatar
I...
But...
You know if...
Ah fck it, just go blow up another 3.0
aackshun is offline
Old 12-02-2014, 05:59 PM
Originally Posted by aackshun
I...
But...
You know if...
Here's my favorite for when that situation arises:
Old 12-02-2014, 09:46 PM
aackshun's Avatar
Thats what i was looking for but couldnt find it. Thanks!
Ps trav, you have a lot of learning to do. Words do not do justice to how much you need to understand about general tuning.
Not an insult, just a reality check.
aackshun is offline
Old 12-04-2014, 06:45 AM
What a bunch of ****** jus runnin their dic suckers cause they have no better answear to my questions. Slap yallself. Worthless ppl. Waiting for a real maxima enthuaist WITH knowlede to lead me right way not some amature rice burners.
Old 12-04-2014, 06:52 AM
MoncefA33's Avatar
Everyone in this thread has done a 3.5 swap at least once.
Old 12-04-2014, 01:19 PM
Okayy, well wheres the positive help at? Not Aaron with a slow broke down 6speed i35. Possibly link to where or who i get the cam spacer from.
Old 12-04-2014, 05:09 PM
OP:
This will help too https://maxima.org/forums/search.php
Old 12-04-2014, 07:42 PM
ajcool2's Avatar
I have cam adapters for sale.
ajcool2 is offline
Old 12-04-2014, 07:45 PM
ajcool2's Avatar
And I've personally put so much info up about this swap I refuse to spoon feed anyone. All of my pictures still work Just take 2 second to search.
ajcool2 is offline
Old 12-13-2014, 12:07 AM
Ok, Awesome Thanks ajcool2 ill be pm you here next month or two..Im about ready to pickup a motor I just don't wanna pick a bad year like 02/03 that burn oil. is any motor 04 on up good? the one im looking at is a 2007 motor for $1100 local and 78k miles. is their a particle year that maybe the best pick?
Old 12-18-2014, 12:53 AM
TurboA32's Avatar
These guys are no help at all but in my opinion all the 3.5's suck I wouldn't waste your time unless you are building a 3.5 and i hope you don't plan on boosting the 3.5 stock
TurboA32 is offline
Old 12-18-2014, 01:10 AM
TurboA32's Avatar
Thanks guys
If your doing a 3.5 swap into your 2000 maxima your going to need to use the 3.0 timing equipment. If you want to use the 3.5 cams with your swap your going to need cam spacers which can be found at www.jimwolftechnology.com and you will have to drill intake cams 180° from where the stock dowel pin hole is and use the stock dowel in the hole you drilled I believe the hole to be made is a 6mm hole and or if you want to save money you can just use the stock cams from your 3.0
TurboA32 is offline
Old 12-26-2014, 03:00 AM
Max streets's Avatar
Their is no 3.5 that won't burn oil,ur best bet is to find something with very low miles like under 50k or just the cheapest motor u can find or a longblock and invest in pistons,ARP rod bolts if u can't afford rods,revup oil pump ,acl bearings,HR headgasket,ARP head bolts.and if u want upgraded cams and springs cheapest would be some revup cams and springs.since ur boosting this would be ur best route or motor may last less than a 3.0.
When it comes to cam adapters setting up the adapters to ur optimum power level they get setup different depending NA or boost.
Let's not forget new timing,water pump and all new seals.
Reason for getting new or better used parts is because ur gonna be taking apart half of the motorso u might as well.
Max streets is offline
Old 01-26-2015, 03:41 PM
yeah changed my entire mind already. swapin another 3.0 in and gonna run 14psi on it. its the easiest route and seems like it will make power more reliably and not brake **** or blowup.
So I guess we can close this thread.
Old 01-27-2015, 10:41 AM
TurboA32's Avatar
Actually they can blow up I've done it a few times but why close the thread keep it open post progress and pics people like that
TurboA32 is offline
Slamrod
04-10-2016 05:24 PM
Finkle
09-27-2015 09:53 PM
schmellyfart
09-25-2015 04:47 PM
jholley
08-11-2015 09:38 AM
Blackwind
08-05-2015 06:35 PM
Quick Reply: 2000 Maxima 3.5 Swap Thread
