2007 Altima engine, 4th gen, 3.0 timing
Old 04-08-2013, 12:13 PM
  #41
LandShark has Cosworth
grey99max's Avatar
Originally Posted by 95naSTA
If that's your current ride height you could get away with lowering the engine.
Space out the lower beam to drop the F/R mounts, space out the drivers, and make a custom poly-filled passenger.
My manifold-to-hood measurements were made before I raised the hood for better cooling, I figured that if I do have hood clearance problems with a 2009/10 Maxima UIM I can install longer bolts in the hood hinges before lowering the engine. I keep the axles straight as possible so I don't beat up the CV joints any more than I gotta. The suspension is confined to about one inch lift when launching, and about 1 1/2 inches when hitting a bump. Tokiko lowering springs and a lot of hard rubber spring spacers and the shocks set to "5" keep the travel to a minumum, yet setting the tire air pressure to 25psi front / 38psi rear gives a decent ride.
Or I could take a rubber hammer and make a hella dent in the hood...
I prefer solid engine mounts, since the front only is solid right now and works well, and any attempt at lowering the engine will be the time to make all of them aluminum plates.
grey99max is offline
Old 04-16-2013, 09:15 PM
  #42
95naSTA's Avatar
Got some #s
http://forums.maxima.org/1-4-1-8-mil...ap-98-i30.html
95naSTA is offline
Old 04-17-2013, 07:26 PM
  #43
Turbo'd Saab
DrunkieTheBear's Avatar
Wow super impressive!
DrunkieTheBear is offline
Old 06-10-2013, 04:27 PM
  #44
Dark_man_x's Avatar
Quick question about the cam timing on this swap. Would it be possible to use regular 05 max cams in the 07 Altima VQ so that I could use the adapters? I did some slight FSM research and they both have the same bearing/bore diameters. Only difference I can find is the lobe height witch is about .6 mm less on the max cams.
I am assuming the cam length and lobe placement would be the same but I would just like another opinion before I make the decision to try it. This way would just be 10x easier for me since I have multiple sets of 05 cams laying around, plus I don't really have the resources to drill the Alti cams.
Thanks.
Dark_man_x is offline
Old 07-05-2013, 07:13 PM
  #45
stephenlc's Avatar
just making sure, you are running a stock 4th gen ecu with the e-manage? I see a non cable driven throttlebody
stephenlc is offline
Old 07-06-2013, 11:21 AM
  #46
schmellyfart's Avatar
Yes. Look closer, the 09 TB was converted to cable driven.
schmellyfart is offline
Old 07-07-2013, 07:22 PM
  #47
95naSTA's Avatar
Yep.
I run the cable in the rear.
Thanks.
Yep, no reason you can't run any non-HR head VQ cams with adapters. But, as with any cam swap, you'll want to check the valve lash.
95naSTA is offline
Old 07-07-2013, 08:44 PM
  #48
Turbo 3.5
t6378tp's Avatar
your go back to the track yet, any oil burning issues with these motor
t6378tp is offline
Old 07-07-2013, 09:39 PM
  #49
95naSTA's Avatar
I'm not planning on going back to the track till the fall. IMO there's no point going past May. I hate lines and the heat soak.
It's hard to tell if I'm burning any oil. If I am, it's a 1/2 qt between changes.
I've yet to get the VIAS hooked up and the WBO2 wired into the emanage for logging but that should come soon. Most of my free time has been going to my project car.
95naSTA is offline
Old 07-08-2013, 10:01 AM
  #50
95naSTA's Avatar
Also, FWIW I just got 30.3 mpg on a 250 mile trip.. with the a/c on and about a dozen or so red lights.
95naSTA is offline
Old 07-15-2013, 02:27 PM
  #51
niceguy's Avatar
The Bonnie reminds me a little of an older Infiniti J30 but better looking...
niceguy is offline
Old 07-31-2013, 08:55 AM
  #52
Dark_man_x's Avatar
hey man, one more quesrtion. What are using for a throttle return spring? i cant seem to find one long enough to bring the throttle all the way back down.
Old 07-31-2013, 01:43 PM
  #53
95naSTA's Avatar
@niceguy, thanks.
When I converted the 09 TB to cable I used the spring from an 03 TB since I re-used it on the 1st 3.5 swap.
95naSTA is offline
Old 03-29-2014, 08:34 PM
  #54
Black Lion
maxprivate's Avatar
Very nice build, do you plan on boosting at all?
Curious why you couldn't get the cruise control to work?
maxprivate is offline
Old 03-30-2014, 03:03 PM
  #55
95naSTA's Avatar
Nah, no boost. Maybe if the car was in better shape I would.
I could get cruise to work if wanted but I just dont feel like putting the time/effort into something I would rarely use.
95naSTA is offline
Old 03-31-2014, 02:57 AM
  #56
Black Lion
maxprivate's Avatar
Got ya.. Will you ever consider a full 3.5 swap? I may need to replace my engine and not sure if I should go The 07 Altima engine or 09 maxima engine.. i know either way Im not unlocking its full potential on 3.0 timing.
So not sure if it even worth doing cams or not side I can't mess with adjusting cams at all on 3.0 timing. Or even porting heads.
Im supercharged now too... Im basically looking for a stronger better built engine that will be more reliable and efficient but also make more power than my 3.0
Old 04-17-2014, 09:17 PM
  #57
I<3 A32's's Avatar
some one needs to make so adjustable cam gears for the 3.0
I<3 A32's is offline
Old 04-18-2014, 07:35 AM
  #58
dot dot dot ...
NmexMAX's Avatar
PITA with chains though.
NmexMAX is offline
Old 04-19-2014, 12:56 PM
  #59
krazy6's Avatar
+1 wouldn't be worth it!
krazy6 is offline
Old 05-24-2014, 10:19 AM
  #60
David3267's Avatar
Wonder if this swap is similar for a 5th gen 2000 hmmmm...
David3267 is offline
Finkle
09-27-2015 09:53 PM
MaximaDrvr
08-19-2015 08:20 PM
95naSTA
08-16-2015 05:03 PM
95naSTA
08-16-2015 05:02 PM
Quick Reply: 2007 Altima engine, 4th gen, 3.0 timing
