Q45 MAF
Old 04-15-2012, 07:28 PM
95naSTA's Avatar
Q45 MAF
Sorry for no before/after dynos or anything but I'm successfully running the Q45 MAF with my hybrid 3.5 swapped 98. I searched and only found one other mention of someone running this MAF but no real info. Below is how I went about adapting it to my setup.
Wiring is it in is a joke.
A32
Red - +12v
White - Signal
Black - Ground
Q45
Black w/ White stripe - +12v (could also be black with red stripe)
White - Signal
Black - Ground
A lightning MAF adapter will work if you re-drill it. It's a little larger than the MAF opening but a 3.5" coupler will still stretch over it.
I used this for the IACV port.
It's for silicone couplers no larger than 3" but you can easily bend it out a little for a 3.5" coupler.
I'm still waiting for my velocity stack. So I just took the filter off my other car and shoved it into the MAF adapter for now.
The bay is 100% beater status but here it is installed:
I'm using 01 in 04 out on my VAFCII and I increased my fuel pressure to 70 psi. I still have a lot of messing around to do but the VAFCII only making corrections 1000rpm and up is the reason for the crazy high fuel pressure.
The midrange feels healthier but I haven't really pushed it due to lack of tuning.
95naSTA is offline
Old 04-15-2012, 08:02 PM
hornepirate's Avatar
What afpr are you using?
hornepirate is offline
Old 04-15-2012, 08:20 PM
95naSTA's Avatar
It's an Aeromotive.
95naSTA is offline
Old 04-16-2012, 07:14 AM
aackshun's Avatar
Nice, you beat me to it!
aackshun is offline
Old 04-16-2012, 07:28 AM
Maximeltman's Avatar
cool man...
Maximeltman is offline
Old 04-16-2012, 11:45 AM
schmellyfart's Avatar
Good stuff!
schmellyfart is offline
Old 04-17-2012, 10:43 PM
ajcool2's Avatar
Its funny you post this now since I started to take one off of an M45 I found at the junkyard but decided not to. iFail
ajcool2 is offline
Old 04-18-2012, 05:55 AM
blue_magicSE's Avatar
The a33b is:
yellow/green
red/green
black
white
Anyone know how i can wire the Q45 MAF up to this?
http://img.photobucket.com/albums/v6...MAFharness.jpg
blue_magicSE is offline
Old 04-18-2012, 08:59 AM
shrek's Avatar
nicely done man,i also have a Q45 MAF but i havent done any before and after dynos ,but i felt it pulls a little more in the top end(maybe my Z33 IM with 5/8 spacer helps too)
i have a VAFC2 and DE-K injectors and i had to had something like 8-9% almost everywhere,i ant to get all the parts to do a returnless fuel sistem and then i will tune it to perfection
shrek is offline
Old 04-18-2012, 10:35 AM
95naSTA's Avatar
I SSIM'd the intake a few days before I installed the MAF to get an idea of what each mod would do. The Q45 MAF definitely compliments the SSIM.
I wasn't expecting a noticable midrange increase from just the MAF but the power just comes on sooner and smoother than before. The top end obviously pulls harder too.
95naSTA is offline
Old 04-18-2012, 10:39 AM
Originally Posted by blue_magicSE
The a33b is:
yellow/green
red/green
black
white
Why not get a LRMAF housing instead?
Old 04-18-2012, 11:51 PM
shrek's Avatar
yes and i felt the engine more responsive, but a dyno would be nice,just ti see what it does on a 4.5 maxima
shrek is offline
TallTom
50
07-08-2022 09:54 AM
aw11power
10-10-2021 04:57 AM
-ReLLiK-
04-29-2016 06:25 PM
ballerchris510
09-10-2015 09:35 PM
dcardello
09-03-2015 11:44 PM
Quick Reply: Q45 MAF
