No spark and pulse on cyl. 1,2&4
Old 12-13-2011, 07:30 PM
bigrak's Avatar
I have a 1997 Maxima Se 5 speed . No spark and injector pulse on cyl. 1,2 & 4. Swapped coils and Changed both crank sensors . tested cam sensor. I tried another ECM and but no go. Any help? Anyone with this same problem before? Thank you.
bigrak is offline
Old 12-14-2011, 06:21 AM
ajm8127's Avatar
Make sure the wires running from the ECU to the coil/injectors are good. I think there was a TSB on these cars about wires breaking or something in the main engine harness.
ajm8127 is offline
Old 12-14-2011, 04:47 PM
bigrak's Avatar
Thanks for your reply. I saw the sticky for the pin out and tested fine. I have the pos. and neg. feed at the coil connectors as well. Tried another ecm. and still no pulse while cranking. Any other ideas would be appreciated.
bigrak is offline
Old 12-18-2011, 09:45 AM
KRRZ350's Avatar
Any recent timing chain related work, waterpump, or sitting for an extended period? AFAIK timing off causes no fire on cylinders 2 & 3 but who knows.
Do you have an OBD-II reader? Any codes or pending codes?
I'm assuming you're using a noid light to check for injector pulse?
I get the feeling you've already done these, but just a reminder- clean all your grounds esp. the manifold ones, and make sure battery is fully charged. Inspect the rubber damper & nubs on the crank pulley as well.
KRRZ350 is offline
Need help
23
10-02-2015 08:56 AM
Gingerheadman
10-01-2015 05:11 PM
dshinn
09-26-2015 08:07 PM
zmcneely13
09-26-2015 02:26 PM
msellas
09-23-2015 09:16 PM
Quick Reply: No spark and pulse on cyl. 1,2&4
