Altima eBay Headers installed (Hotshot knockoff?)
Old 01-30-2013, 08:41 PM
  #81
schmellyfart's Avatar
schmellyfart is offline
Old 01-31-2013, 08:15 AM
  #82
aackshun's Avatar
I'm seeing what's going on here.
And I like it.
Proceed.
aackshun is offline
Old 01-31-2013, 10:07 AM
  #83
95naSTA's Avatar
x2 looking good
95naSTA is offline
Old 01-31-2013, 10:38 PM
  #84
Thanks guys. I'm also looking into coating the headers with one of these: http://www.vhtpaint.com/products/flameproof/ or http://www.ebay.com/itm/370730995856
Right behind the flex is a Vibrant 3" ultra quiet resonator. I'm looking forward to see how this affects the drone zone.
Old 02-03-2013, 02:12 AM
  #85
Almost done, just need to weld in the o2 bung, hanger, and then coat it. I'm really happy with the way this one turned out.
Old 02-03-2013, 12:56 PM
  #86
Turbo 3.5
t6378tp's Avatar
nice
t6378tp is offline
Old 02-04-2013, 01:38 PM
  #87
I like Maximas
vipervadim's Avatar
Finally!!!! somebody else who's not cheap and actually using v-band flanges on their headers
love not having to change gaskets/re-rtv the 3-bolt flanges every 3 months.
I totally approve, and looking forward to that quiet resonator too.
vipervadim is offline
Old 02-05-2013, 11:12 AM
  #88
Hadou-kai's Avatar
@schmellyfart, was wondering, I'm limited in my knowledge of header theory so bare with me. We all know the 3" catback makes more power, however i guess you're basically making a stepped header to meet your 3" catback, was wondering though......what do you think about the following?
just as how you used the 2.25" pipes for the "y", my theory suggests each pipe from primary is stepped 1/8th at a time so three primary 1.75"/(1 6/8) pipes when stepped merges to (2 1/8 i.e. 1 6/8 + 3/8) however the common pipe one size up is 2 1/4(2 2/8) so thats satisfactory, for two (2 1/4) pipes to merge and maintain velocity it would step up by 2/8 so it would be 2 4/8 or 2.5. that would be a upgraded choke without having a drastic shift in exhaust volume and velocity meaning going directly to 3". so right from the 2-1 merge a 2.5" to 3" transition cone could be used.
so its not to knock your setup but just a silly whymsical thought that i had.
meaning i see cattman's with exhaust cutout put down numbers and they have a 2.5 choke/final merge of two pipes before catback
Hadou-kai is offline
Old 02-05-2013, 11:20 AM
  #89
95naSTA's Avatar
Nice Job. That's plenty far from the LCA, much easier to swap out than cattmans, and it would clear a 3.5 drain plug if you went that route.
95naSTA is offline
Old 02-05-2013, 11:33 AM
  #90
I love the vbands! It makes the y pipe a breeze to remove.
That's some interesting info, I never thought about it that way. Do you have any sources regarding the exhaust velocity and stepped pipe diameter?
I would have to use a different merge collector in order to retain the vibrant resonator, and I've become quite fond of this flowmaster merge.
Thanks, I thought the 3.0 oil pan had to be used with the swap due to clearance issues with a crank sensor?
Old 02-05-2013, 11:42 AM
  #91
95naSTA's Avatar
I used 3.5 upper and lower pans on my 1st gen 3.5 hybrid swap with a 3.0 CPS. The lower pan has the drain plug pointing to the rear.
95naSTA is offline
Old 02-05-2013, 11:51 AM
  #92
Interesting, I see there's conflicting info on the two guides on VQPower
Old 02-05-2013, 12:05 PM
  #93
95naSTA's Avatar
I know the guides say that but I for sure ran the 3.5 upper with a 3.0 CPS. The 3.5 CPS hole is larger and the 3.0 sensor had play to clock a few degrees either way before you tightened down the 10mm. If the sensor was clocked wrong or loose, it would intermittent hard start. But with the sensor where it should, no problems. This was with a '03 auto max 3.5 upper oil pan.
95naSTA is offline
Old 02-05-2013, 12:09 PM
  #94
Oh ok that makes more sense. Thanks for the info!
Old 02-05-2013, 01:15 PM
  #95
I like Maximas
vipervadim's Avatar
Cattman headers that have the skid plate are really bad with the 3.5L lower oil pan. The location of the 3.5L drain plug drains the oil right onto the skidplate (hot headers + engine oil = bad smelly combo)
I have hotshot headers on mine (anyone else still have Hotshots??), I never liked the 3.5L lower drain spot, so i reused my 3.0L lower oil pan with 3.5L swap. (i did use the 4AT 3.5L upper oil pan and spliced in the 3.5L CPS to the 3.0L sub harness, I did not use the 3.5L 'oil cooler' since it's more like an oil warmer if anything -- using 200* coolant to cool the engine oil?? no thanks.. with the oil warmer it doesn't clear traction bars [anyone here use traction bars?])
I don't even take off the tire when changing oil, just drive onto a curb with the pass front tire and i have all the clearance i need
Old 02-05-2013, 08:26 PM
  #96
More pics I removed the cat 'section' so this bolts straight to the catback.
http://www.flickr.com/photos/schmellyfart/8448795121/
http://www.flickr.com/photos/schmellyfart/8448795117/
http://www.flickr.com/photos/schmellyfart/8449879752/
Old 02-06-2013, 06:00 AM
  #97
Hadou-kai's Avatar
your y-pipe is what size now 2" or 2.25"?
Old 02-06-2013, 06:45 AM
  #98
2.25" into 3"
Old 02-06-2013, 07:17 AM
  #99
ABIGBRAIN's Avatar
How much $$$ do you have into this final setup? As in, if you had built the headers and y-pipe this way from the start.
Andy
ABIGBRAIN is offline
Old 02-06-2013, 07:45 AM
  #100
Hadou-kai's Avatar
Schmelly this is the type of collector I was thinking about, raceprovenparts on ebay is selling two for $83 shipped. its used but its stainless steel. I love shopping from the v8 crowd because buying the same style true merge 2-1 collector is $100 a piece elsewhere
Old 02-06-2013, 07:47 AM
  #101
Hadou-kai's Avatar
take note of the choke and transistion cone. Thats the idea i was refering to.
Old 02-06-2013, 08:02 AM
  #102
ABIGBRAIN's Avatar
http://item.mobileweb.ebay.com/viewi...id=71144815087
$33 shipped
Old 02-06-2013, 08:21 AM
  #103
aackshun's Avatar
Mmmmm, that's not so equal length though
aackshun is offline
Old 02-06-2013, 08:22 AM
  #104
Andy
Lets see
eBay
Altima headers: $135 (they are now about $220 on eBay)
SS o2 bung: $8
Mandrel Bending Solutions 2x 2.25" SS Vband clamp & flanges: $84 shipped
Amazon
Vibrant 3" Ultra Quiet resonator: $94.80 ( I only paid 67.91 after rewards points)
Flowmaster Merge Y214300S: $53.99 ( I got it for free after rewards points)
SiliconeIntakes.com
2 x 2' Extra Thick Stainless Steel 180° Bend, 2.25" (SIL001637) = $47.98
1 x 3.0" Stainless Steel Exhaust/Intake Flex Section - 6" Long (EXH000868) = $17.99
+ $18 shipping
My Total: $378.87
I see what you're talking about now. I'll try it out next time I build a y pipe.
Old 02-06-2013, 08:23 AM
  #105
I don't care. The name of the game was getting it to fit and have plenty of clearance while keeping the bends smooth.
Old 02-06-2013, 07:58 PM
  #106
Azmax61's Avatar
Good to see people modifying them to fit. Always need people to experiment!
Azmax61 is offline
Old 02-07-2013, 08:04 AM
  #107
nishfish871's Avatar
That looks very similar to what Cattmans welder used to make the 3" ypipe 2-1 section on mines.
Now the question is whether the larger piping will actually nets gains, I'm not too sure right now.
nishfish871 is offline
Old 02-13-2013, 07:43 AM
  #108
The cell phone mic can't handle it, but here is a vid nonetheless.
Old 02-27-2013, 06:11 PM
  #109
Sound clip under load.
Old 02-27-2013, 11:58 PM
  #110
Rods03Max619's Avatar
Good **** Man...
Rods03Max619 is offline
Old 02-28-2013, 04:28 AM
  #111
carsnwomen91's Avatar
I bought jime's hot shots, just waiting for spring to get them on! Hopefully they fit fine other than deleting egr.
schmelly that y looks fantastic, did my hot shot measurements help at all? It's not fully equal but better sounding than it just going straight into the collector like bolt on y pipes.
When you get time grab a nice cam and make a nice video, sounds pretty mean though
carsnwomen91 is offline
Old 02-28-2013, 07:32 PM
  #112
I totally forgot about those. lol I think I was using them before I ordered the piping, so yes they helped.
Free time and a nice camera? Maybe in a few years hahah.
Old 03-01-2013, 04:04 AM
  #113
Turbo 3.5
t6378tp's Avatar
yo, I so like the sound has more of 350z/G35 tone to it.
t6378tp is offline
Old 03-04-2013, 09:44 AM
  #114
deloa84's Avatar
Yeah my cell phone mic does it no justice lol
deloa84 is offline
Old 04-14-2014, 04:34 AM
  #115
max ride 41's Avatar
well, after all these compelling arguments and some nice sounds scmelly i'm sticking to another warpspeed y cause i don't have a shop around here that can do all that and money's tight. i would however like to do a different cattback and was wondering what you have cause i really did'nt read all the data you posted. it's early and i'm tired so i was thinkin about a flowmaster 40 with the monza resonator and b pipe i already have, thoughts? seen some vids, sounds ok to me.
max ride 41 is offline
Old 04-14-2014, 09:06 AM
  #116
This has absolutely nothing to do with the y pipe Chris is selling.
VQ'ed
69
08-27-2020 12:29 PM
Cotozic
06-28-2017 08:01 PM
Maximeltman
08-31-2015 01:01 PM
stromm
08-27-2015 04:13 PM
soon2ownmax
08-13-2015 02:19 PM
Quick Reply: Altima eBay Headers installed (Hotshot knockoff?)
