Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-01-2009, 10:30 AM   #1
Send a message via AIM to DcMaN
01 DEK motor swap cold start issue ?
Hey guys, its been a while since ive posted, im wondering if anyone has fixed the cold start issue with the dek manifold/motor swap into the 4th gen maxima. This is the problem, on days that get to around 30-40 degrees and lower when i turn the key to the start position it starts right up but doesnt stay running this only happens on thef irst start up for the day. Any day below 40 degrees causes the car to have trouble on the first start up for the day. I have to give it some gas for a few seconds and then it will idle/ drive fine for the rest of the day. Does anyone have a fix for this ? I havnt really looked into it its been a year or two since ive done the swap. Im really hoping there is a fix or maybe something i can do to get rid of that cold start issue
DcMaN is offline   Reply With Quote
Old 11-01-2009, 10:34 AM   #2
Tried looking through the links in the stickies but all the links are busted. Whats better to use 4thgen IACV , or 5thgen iacv ?
Old 11-01-2009, 11:31 AM   #3
KRRZ350's Avatar
Send a message via AIM to KRRZ350
The 4g tb has a mechanical cold start valve to bypass the butterfly under those conditions. The 5G has programming in the ecu to command the iacv more under those conditions.
The tps & leaks should be double checked, the 4g iacv should be adjusted as per the fsm, nothing else. Ignore the cold start, or toggle switch a solenoid to bypass the butterfly w/metered air, maybe even get creative and use a temp switch. It's as simple as that I think. Use jets in the vacuum line to fine tune.
KRRZ350 is offline   Reply With Quote
Old 11-01-2009, 09:12 PM   #4
Would greddy emanage ultimate help me out with this issue at all ?
Old 11-02-2009, 08:54 AM   #5
Willing to learn
oldngivout's Avatar
Here's what I came up with to deal with the cold start issue on my 3.5 swap:
I grafted the cold start plunger & modified linkage from the 4th Gen TB on to my Pathfinder TB.
http://i188.photobucket.com/albums/z...t/DSC00142.jpg
Granted it was a lot of trouble and would take some keen fabricating skills (I'm kissing my own butt here ain't I?) but it works great.
__________________
Unless you do it exactly like I did, your results may vary.
oldngivout is online now   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
