Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-29-2009, 11:03 AM   #1
RIP Kevin007
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
Crank wont turn
Ok me and my brother swapped out his motor on sunday because of a leaking head gasket. On tuesday he went to start it and it started to crank as if it was going to turn over but it just stopped. When he tried again it clicked as if the starter was dead. When he checked the starter one of the bolts was not tight which caused the starter to die. He got another starter and tried it and it just clicks like the starter is unable to turn the motor. When he tried putting a breaker bar on the crank pulley and turn it it doesnt move. It turns the opposite way maybe an inch or less but thats it. We called up a local nissan performance shop and he said that it may have blown when we tried starting it up because of the huge dent in the lower oil pan. He said he's seen it happen on 300zx's with smaller dents then what we have. The dent somehow starves the engine of oil. I dont completely understand it how that could happen but he's usually 100% right. I guess I'm just trying to find out if theres anything else we should try to diagnose the issue. The motor is a vq30DE.
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The 3.5 Swap 15.508@90mph 60' 2.3 AUTO (Bad KS and stock catback) 210whp, 213wtq
The Dark Phoenix 13.402@102mph 60' 1.9 AUTO 257 RWHP 3280lb w/driver
Fear me.
My VQ35 Swap Progress Thread Now Complete!
ajcool2 is offline   Reply With Quote
Old 10-29-2009, 07:14 PM   #2
Sorry but your situation is not clear, first you mention swapping the engine, wich make me think that you got the engine replaced by another one, right ? or did you mean that you fixed the blown head gasket ?
Maybe I'm old fashion but a blown head gasket is nothing good and is often the sign of a blown engine, therefore you wont be able to turn that crank pulley even with a 20 foot perch. I've seen similar situation but the problem was a bad solenoid on 3 different starter, the other thing is a bad battery would trigger that noise on a starter.
The fact that you mentioned there is a big dent on the lower oil pan make believe there might be a snap rods in there so this engine need a rebuild.
If you want to rebuild I have many parts that I could sell you to build that engine.
__________________
2K1 AE-SE - Sterling Mist
2004 BMW X5 4.4i
doublea is offline   Reply With Quote
Old 10-29-2009, 07:33 PM   #3
RIP Kevin007
ajcool2's Avatar
We took out the engine with the blown head gasket and put another engine in the car. The new engine has the large dent in the lower oil pan (the small steel one). I just think the motor is siezed. So we'll probably end up pulling it and finding another one.
__________________
DCMAX FTW
Fear me.
Old 10-29-2009, 08:31 PM   #4
Shift_Broken Tranny
why not drop the lower pan and have a look around 1st
__________________
My Cardomain _ _Maxima runs 13.4@109
Dyno:? whp & ? wtq
Nitrous PB: 13.4@110mph
All Motor PB: 14.0@99mph
3280lb with driver, full trim, rims, spare, jack, fluids, etc & notorized proof
t6378tp is offline   Reply With Quote
Old 10-29-2009, 08:56 PM   #5
RIP Kevin007
ajcool2's Avatar
He did that tonight and found peices of a coil pack and small metal shavings. He said the dent in the oil pan was so bad it was touching the oil strainer inside.
__________________
DCMAX FTW
Fear me.
Old 10-29-2009, 09:27 PM   #6
pieces of a coilpack??? how the heck does that end up in an engine? I would take the engine back where it came from for selling you an engine that was way screwed up before you got it
Gemner is offline   Reply With Quote
Old 10-30-2009, 06:38 AM   #7
Ok I see, so you have a bad engine, time for a rebuild.
__________________
2004 BMW X5 4.4i
Old 10-30-2009, 06:53 AM   #8
Send a message via AIM to i2vicious2 Send a message via Yahoo to i2vicious2
sounds like a piston is warped so bad it wont turn, or the motor is flooded.....
__________________
d2 coilovers, Qtp eletric cutout, OBXV2 3.5 Headers,
97-99 complete swap..(center console, front end, rear end)
VAFC, I30 Headrest...............
"i think i need a bigger box"
See me......
I2VICIOUS
i2vicious2 is offline   Reply With Quote
Old 10-30-2009, 10:51 AM   #9
RIP Kevin007
ajcool2's Avatar
Its not flooded. The motor was run for a while with only 5 sparkplugs by the previous owner. He actually drove the car to the shop and had the motor replaced. We figured a missing spark plug wouldnt hurt much and it was worth a try especially since he paid next to nothing for the engine. I'm guessing it ended up melting the coilpack in the cylinder where the spark plug was missing and the plastic ran down into the engine.
__________________
DCMAX FTW
Fear me.
Old 10-30-2009, 05:25 PM   #10
Shift_Broken Tranny
that sucks, well atleast you have everything you need for a 3.5swap now
__________________
Dyno:? whp & ? wtq
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
