Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-26-2009, 08:45 AM   #1
Colder Spark Plugs for N/A?
What's up Maxima.org,
I searched.
But I'm going to be buying new spark plugs soon and I want to know whether I should go with a colder heat range inspite of me running an N/A application without nitrous. Would it benefit me more with running more aggressive timing maps? And is there any way to quantify this, by which I mean how much farther can I push my timing with a one step colder heat range?
And is two steps colder even worth considering here?
And does anyone have preferences with different brands? Denso and NGK are what I'm considering. I have an '01 DE-K running I/H/E/e-Manage Ultimate.
Thanks,
Moncef
__________________
2001 A33 AE || KV3 || 5MT || VLSD
SHIFT_sleepy
PM for cheap Infinity, Rockford Fostgate, and Kenwood car audio equipment!
MoncefA33 is offline   Reply With Quote
Old 10-26-2009, 10:22 AM   #2
2 step colder is overkill. I was told from the nitrous guys that one step colder won't hurt performance na. I got rid of my nitrous and still have my one step colder ngk's in. I doubt you'll benefit by getting more power. Are you just trying to play it more safe than sorry?
__________________
J Schultz
2003 Titanium SE Auto
Exterior mod: Tint
Performance mods: GAB w/ KN panel filter, NWP vias delete, Timing 17*BTDC, Custom test pipe/ exhaust cut-out, drop resistor mod.
Best 1/4 Mile Time: 14.6
jr schultz is offline   Reply With Quote
Old 10-26-2009, 11:08 AM   #3
Not trying to play it "safe than sorry" necessarily.
But I wanna run more ignition timing advance and running a colder heat range would help with knock suppression.
__________________
SHIFT_sleepy
Old 10-26-2009, 12:24 PM   #4
You won't benefit from using a colder plug. A colder plug is used in higher hp applications to prevent pre-ignition, not to prevent detonation. Pre-ignition occurs when a point within the combustion chamber becomes so hot that it becomes a source of ignition (e.g., a spark plug ground strap). Detonation occurs when excessive heat and pressure in the combustion chamber cause the air/fuel mixture to autoignite. There are many things that can cause detonation. One of the causes is too much ignition timing advance.
505max94se is offline   Reply With Quote
Old 10-28-2009, 12:05 AM   #5
Ahh I understand. Thanks for the insight!
__________________
SHIFT_sleepy
Old 10-28-2009, 06:46 AM   #6
STFU n00b!
Basically for an NA car you don't need it. at least not one with stock compression and heads. If you're really upping the performance, you might need to change plugs.. But even with my higher-compression engine with ported heads, I still run the same plugs as stock. Nissan did a pretty good job on designing the VQ. the rest of the car? meh. But that's a different dead horse...
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 10-28-2009, 07:58 AM   #7
Stock plugs are even a little cold for the VQ. I am running 12.7:1 and still am only using 7's now as a 'just in case'
__________________
Nissan N14 Pulsar - VQ35DE, 6spd HLSD, Kelford Spec C cams, 12.7:1CR & E85 tuned
Smashed Holden VY SS LS1 Twin Turbo Ute - 641rwHp@12psi Pics
New LS3 6.2 Camaro, Boyd Harm wheels and a big single Turbonetics huffer...
throttlehappy46 is offline   Reply With Quote
Old 10-29-2009, 11:03 PM   #8
Cool, thanks guys!
__________________
SHIFT_sleepy
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
