Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 09-24-2009, 11:00 PM   #1
VQ30DE-K Swap Question
Ok first off I searched. Please dont flame me, I am just looking for help. I'm not willing to do a 3.5 swap.
The Facts: 95 Maxima GXE 5spd; cheaply obtainable VQ30DE-K out of a 2000 Maxima GLE
I had a complication with my stock motor. Bottomline I am looking at internal problems and swapping is cheaper and faster. Its not my Daily and its not my Project(race) car ... its kinda in between. That said I dont want to spend much putting it back together and I'm not looking to make it really fast. I have come across a good deal on a 2000 VQ30DE-K and wondered whats involved in this swap.
It looks straight forward but I am wondering if my harness,ecu,axles, ac compressor, etc will work. Any info would be much appreciated I need to jump on the motor before insurance pick the car up.
Stretch21 is offline   Reply With Quote
Old 09-25-2009, 04:15 AM   #2
Send a message via AIM to i2vicious2 Send a message via Yahoo to i2vicious2
got vq30de-k 2day, where do i start on removing 00vi parts?
__________________
d2 coilovers, Qtp eletric cutout, OBXV2 3.5 Headers,
97-99 complete swap..(center console, front end, rear end)
VAFC, I30 Headrest...............
"i think i need a bigger box"
See me......
I2VICIOUS
i2vicious2 is offline   Reply With Quote
Old 09-25-2009, 04:49 AM   #3
Yes all the 3.0 parts you listed should bolt right up.
For the harnesses you will need the injector clips off the 2000 and solder them in. and you will need the harness off the vias as well. but other then that you should be good to go.
__________________
97 Maxima GXE Totalled
96 Maxima Se Blown 3.5 New one coming
90 B12 Sentra My new winter beater
Product_Of_Korea is offline   Reply With Quote
Old 09-25-2009, 10:51 AM   #4
RIP Kevin007
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
+1
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The 3.5 Swap 15.508@90mph 60' 2.3 AUTO (Bad KS and stock catback) 210whp, 213wtq
The Dark Phoenix 13.402@102mph 60' 1.9 AUTO 257 RWHP 3280lb w/driver
Fear me.
My VQ35 Swap Progress Thread Now Complete!
ajcool2 is offline   Reply With Quote
Old 09-25-2009, 11:18 AM   #5
Did you mod the 2x4 into your hood assembly?
__________________
02 Max SE 6spd
89 Max SE 5spd
Augustus Maximus is offline   Reply With Quote
Old 09-25-2009, 11:30 AM   #6
RIP Kevin007
ajcool2's Avatar
Quote:
lol best mod evar.
__________________
DCMAX FTW
Fear me.
Old 09-25-2009, 04:56 PM   #7
I have read all the information on how to use the 00 intake manifold on my motor but what I am looking to do is the whole swap. I'll be finding out tomorrow if my bottom end is damaged and if so I can get the motor from my friend for 250.00. What I want to do is drop his motor in my car. It has 42,000 miles but the rear end on the car found out what happens when a drunk driver in a Yukon going 55+mph hits you when your sleeping peacefully on the curb in front of your house. His epic fail will hopefully work out as a good gain for me.
Old 09-25-2009, 05:03 PM   #8
I have a question as well, from what I have read, for this swap you need an RPM switch, but the original 00-01 Maximas dont have an RPM switch, so why would we need them if we are using the whole engine? Will having an 00-01 ecu eliminate the need for an rpm switch? Sorry, not tryin to thread jack....
Shift_Nismo is offline   Reply With Quote
Old 09-25-2009, 05:09 PM   #9
Quote:
pretty much the only eletrical is the harness clips for the injectors and vias, other than those everything else is PnP. You will have to use the 4th gen evap and egr equipment though(not so PnP) if you need emissions.
The bottom end of a de-k is damn near identical to a de. If you want you can use the 4th gen lower to use the 4th gen injectors so you wont be so rich.
__________________
Old 09-25-2009, 06:44 PM   #10
The Dirty Pearl
pmohr's Avatar
It's basically the same thing. It'll bolt right in, then you have to modify your vacuum line routing and whatnot for the 00VI.
Quote:
Yes, using an A33 ECU will eliminate the need for a $40 RPM switch...after you spend how many hundreds of dollars and hours of labor to swap in the entire engine control harness, modify it to fit your car, install the NATS IMMU and NATS antenna amp, run that wiring so the immobilizer works...
Spend the $40 on an RPM switch, seriously.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
