Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 09-21-2009, 07:55 PM   #1
Axle comparo between 5 & 6 speed tranny's...
OK, so I'm working on my swap (2 yrs. in the making, whatever) and I had both drivers side axles side by side. I didnt see any noticable differences in the 2. The ends that go into the trans appear exactly the same. Which leads me to ask, can the 5 spd axles be used in a 6spd? or are there minute tolerances that wont allow this?
I was wondering because I remember there being a shortage of 6spd axles at one point and a few people not being able to drive because their axle were bad. wouldnt it be nice if we could use 5 spd axles with the 6spd boxes? (well at least for us 4th gen swappers)
__________________
"The Lord seen it fit to put you in my path...and I aim to cure you of your wickedness..."
yevrah4728 is offline   Reply With Quote
Old 09-22-2009, 06:55 AM   #2
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
I always understood that they were different but I've never seen them side by side to confirm.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 09-22-2009, 08:12 PM   #3
Send a message via AIM to MDeezy
I always thought they were different also. If they are not visibly different maybe internally the one for the 6speed might have been built better/different to tolerate the higher power level
MDeezy is offline   Reply With Quote
Old 09-23-2009, 03:33 AM   #4
Quote:
true, but what about all the people running 3.5 swaps, NOS, and/or boost with the 5 speed? They seem to hold up, unless they're doing burn out contest or repeated drag launches.
I'll try to take some pics before I put the tranny in...(which is another problem, cant seem to get it on. The shifter mechanism, hits the chassis and keeps getting in the way)
__________________
Old 09-23-2009, 04:20 AM   #5
I believe the inner shaft splines are different that engage into the final drive. One is a 27mm diameter(A32) and the other is a 29mm diameter(A33b+A34+L31 etc). Would love to know if the A34 inners could work with the A32 shaft and outer CV joint though
__________________
Nissan N14 Pulsar - VQ35DE, 6spd HLSD, Kelford Spec C cams, 12.7:1CR & E85 tuned
Smashed Holden VY SS LS1 Twin Turbo Ute - 641rwHp@12psi Pics
New LS3 6.2 Camaro, Boyd Harm wheels and a big single Turbonetics huffer...
throttlehappy46 is offline   Reply With Quote
Old 09-24-2009, 07:33 PM   #6
The Dirty Pearl
pmohr's Avatar
Quote:
After having pulled the 6MT out a half dozen times, I've found the quickest way to just yank the shift tower out and stuff a rag in there; 45 minutes from jacking the car up to having the trans on the ground and split in half.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 09-26-2009, 07:07 AM   #7
Quote:
I thought of that but didnt wanna try it for fear of damaging a tranny I have yet to use. But it does make total sense though. I guess its back to the FSM to see how it comes out. Thanx Pmohr
__________________
Old 09-26-2009, 07:11 AM   #8
Quote:
just eyeing them, they look to be the same size but I'll try to get a caliper to measure exactly...or maybe I should try to just stick one in to see...
__________________
Old 10-01-2009, 07:18 AM   #9
nycnissans
secondtonone317's Avatar
Send a message via AIM to secondtonone317
pictures?
__________________
Co-Owner and Founder of NYCNissans.com
secondtonone317 is offline   Reply With Quote
Old 10-02-2009, 03:26 AM   #10
I have been informed today by my CV joint tech(he wrote the first book about CV joints/shafts etc) that the A32 and the Australian J31(American I35 I believe) shafts have the same shaft spline and diameter, so the 6 speed inner CV joints and 4th gen and 5th gen outer CV joints can be joined by any suitable A32/33 Maxima shaft to the 6 speed box.
I ordered a gearbox side(my passenger, USA driver side) shaft to confirm it works as this will solve a small problem of mine with the L31 Altima shaft being too long.
__________________
Old 10-03-2009, 12:30 PM   #11
Send a message via MSN to J-Rod
__________________
Jarrod
2000 Maxima SE
White Pearl
5-Speed, short throw shifter
Dropped on Progress Springs & KYB GR2 Struts
True CAI
Unorthodox Underdrive Pulley
CustomMaxima.com Front Strut Bar
Sarona Design Full Body Kit... still in attic
J-Rod is offline   Reply With Quote
Old 10-04-2009, 09:08 AM   #12
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
Im in for pics also.
__________________
97 SE Auto Built Auto
97 SE Holset HX52|N2O|6 SP|Built 3.56|More to come
91 GXE Auto bone stock beater
91 GXE 5sp Another beater
Led retro's Pm me
kzoosho is offline   Reply With Quote
Old 10-04-2009, 07:26 PM   #13
Installed today A32 passenger(Australian driver side) driveshaft and outer CV joints into A34/L31 inner CV joints works. Untested about the US driver side(aussie passenger)
However, I believe the US passenger side axle from the 5 speed will encounter a problem from pics I found...
6 speed shaft is the one fitted and the 5 speed shaft is sitting where the gearbox would be, as the 5 speed shaft goes into the box in line with the block, not further toward the driver side axle like the 6 speed.
So, if the 5 speed shaft splines went into the 6 speed gearbox, it would be about 1.5" too short at the block bracket.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
