Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 09-13-2009, 10:07 AM   #1
Send a message via Yahoo to VenoMax647
35 swap...no spark
hey guys well it is as stated...it gettin fuel....all my coils are new but its now gettin any spark....anysugestions?
__________________
95 se custom 2.5'' exhaust//high flow cat//warpspeed y pipe//weapon R short ram//k sport lowering springs (2.2-2.0)//tokico Hp series shocks and struts//poly mounts
3.5 swap with head work complete!!!.....
VenoMax647 is offline   Reply With Quote
Old 09-13-2009, 11:21 AM   #2
Check all relevant fuses.
Look up the ignition circuit under P1320 in the EC section of the FSM. Do the diagnostics for voltage and ground.
__________________
Mods:| Cammed VQ35 | SSIM | HR springs | ARP rod bolts | OEM Nissan rwd head-gaskets | Budget Y-pipe and Catback | NWP Spacers | Dynomax Superturbo muffler | EdgeRacing Converter | Transgo Reprogramming Kit | Hayden Transmission Cooler | JWT Pop Charger | Emanage Ultimate | SSV4 | Innovate LC-1 WB | DR mod | ES motor mounts | ES x-member bushings | ES LCA bushings | Polyfilled tranny mount| 15" RX-7 BBS wheels (12lbs/rim) | Street tuned: 13.0 AFR, 7200 Rev limit, advanced timing |
whlimi is offline   Reply With Quote
Old 09-13-2009, 12:44 PM   #3
Shift_Broken Tranny
check your connections and harness grounds
__________________
My Cardomain _ _Maxima runs 13.4@109
Dyno:? whp & ? wtq
Nitrous PB: 13.4@110mph
All Motor PB: 14.0@99mph
3280lb with driver, full trim, rims, spare, jack, fluids, etc & notorized proof
t6378tp is offline   Reply With Quote
Old 09-13-2009, 02:49 PM   #4
check the 2 ground harnesses that use to go to the lower intake manifold.
__________________
97 Maxima GXE Totalled
96 Maxima Se Blown 3.5 New one coming
90 B12 Sentra My new winter beater
Product_Of_Korea is offline   Reply With Quote
Old 09-13-2009, 10:21 PM   #5
Send a message via AIM to MDeezy
Quote:
thought those were for the injectors? either way they need to be grounded.
MDeezy is offline   Reply With Quote
Old 09-14-2009, 12:09 AM   #6
checked all grounds....someone said i should check the crank sensor....and i heard something about modifying the one on the tranny somehow but idk
__________________
Old 09-14-2009, 12:12 AM   #7
Quote:
that wouldnt cause no spark. Timing would be off but not no spark.
if you are using the 3.5 oil pan and 3.0 sensor you will need to grind it down 1/4
if your using the 3.5 oil pand an 3.5 sensor you will need to re wire
if your using the 3.0 oil pan and 3.0 sensor, nothing needs to be done.
Old 09-14-2009, 01:48 AM   #8
make sure the timing ring is not messed up. a dented timing ring will cause there to be no spark.
Gemner is offline   Reply With Quote
Old 09-14-2009, 03:17 AM   #9
yea i'm using the3.5 oil pan...but i didnt shave it...how hard is it to re-wire the 3.5 sensor cuz i dont have the 3.0 pan anymore(dont ask)....but as i said ive checked and re checked all grounds anything else?
__________________
Old 09-14-2009, 03:21 AM   #10
we'll if you have the 3.5 sensor and its harness then its not hard. if you dont have it, then grinding it down and using your old 3.0 sensor might be the best bet....
let me guess you cracked your old oil pan trying to get it off but forgot there was a bolt still in and you Heman'd it and its now in 2 pieces?
Old 09-14-2009, 10:03 AM   #11
exactly what i did lol...but i can go out n but the 3.5 sensor easily....i dont trust myself grinding anything down
__________________
Old 09-14-2009, 12:30 PM   #12
if you have a 3.0 oil pan for reference you'd see what you need to grind and its not as bad as you'd think. the 3.5 oil pan has a hump....
I think I have both pans in the garage. I'll snap some pics later (after I cook some hashbrowns and pancake )
Old 10-01-2009, 05:16 AM   #13
Today is October 1st...but you're prolly still cooking your hashbrowns and pancake, right?
__________________
02 Max SE 6spd
89 Max SE 5spd
Augustus Maximus is offline   Reply With Quote
Old 10-04-2009, 07:49 AM   #14
LOL^.....yea i jus ended up grinding it down....but then my bat died.....completely so i'm picking up a new 1 on wed
__________________
Old 10-10-2009, 10:09 AM   #15
WE GOT SPARK!!!....now jus to put these axles in n i'm up n running
__________________
Old 10-10-2009, 11:59 AM   #16
RIP Kevin007
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
wat was the problem?
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The 3.5 Swap 15.508@90mph 60' 2.3 AUTO (Bad KS and stock catback) 210whp, 213wtq
The Dark Phoenix 13.402@102mph 60' 1.9 AUTO 257 RWHP 3280lb w/driver
Fear me.
My VQ35 Swap Progress Thread Now Complete!
ajcool2 is offline   Reply With Quote
Old 10-10-2009, 07:31 PM   #17
Send a message via AIM to i2vicious2 Send a message via Yahoo to i2vicious2
crank sensor......... engine and trans.. (didnt grind it down)
__________________
d2 coilovers, Qtp eletric cutout, OBXV2 3.5 Headers,
97-99 complete swap..(center console, front end, rear end)
VAFC, I30 Headrest...............
"i think i need a bigger box"
See me......
I2VICIOUS
i2vicious2 is offline   Reply With Quote
Old 10-10-2009, 07:51 PM   #18
yep...now just to figure out this egr from the rear header....maybe plug?....does the front header fit the rear?
__________________
Old 10-10-2009, 09:27 PM   #19
The Dirty Pearl
pmohr's Avatar
http://www.courtesyparts.com/14003k-...3-p-53839.html
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 10-12-2009, 02:48 AM   #20
RIP Kevin007
ajcool2's Avatar
I have an extra one sitting in front of me if you want it let me know.
__________________
DCMAX FTW
Fear me.
Old 10-12-2009, 06:28 PM   #21
Quote:
he!! yes.... r u comin down wed to curtis shop...if not fri at mcdonalds...i'll buy, trade, take for free it's watev
__________________
Old 10-13-2009, 08:54 AM   #22
RIP Kevin007
ajcool2's Avatar
I'll probably be down at the mcdonalds on friday I'll bring it with me.
__________________
DCMAX FTW
Fear me.
Old 10-13-2009, 08:32 PM   #23
SWEET.....
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
