All MotorAll Motor Advanced Performance. Talk about Engine Swaps, Internal Engine work. Not your basic Y pipe and Intake Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Okay so I have a set of VQ35DE cams and had some questions.
I got the SM adapters, dowel holes set 178* degrees apart, per Dandy's recommendations.
Now I've been told that there have been dynos done on 3.5 camshafts on a DEK, but the All Motor archive shows nothing but speculation, so I'm curious if someone has done this before. Reason being is because I have no idea which cams I actually bought, whether they're off of a Maxima, 350Z, etc.
Has anyone run the Maxima VQ35 cams on the DEK? I'm looking at the specs for the Z camshafts and they're quite a bit better, close to the JWT S1s. Which leads me to my next question.
Using the specs on the Z/G camshaft profile (since I'm able to get a good deal on these cams)
Quote:
Intake__Lift: 10.5mm
Exhaust_Lift: 10.5mm
Intake__Duration: 248º
Exhaust_Duration: 248º
Intake_Opens: 2º ATDC
Intake_Closes: 70º ABDC
Exhaust_Opens: 70º BBDC
Exhaust_Closes: 2º BTDC
Overlap: -4º
Would the 178* dowels on SM's cam adapters work well with timing? Meaning that would I be able to emphasize midrange and top-end power without losing too much top end, even though these spacers were intially set up for the less aggressive Maxima cams?
Which brings me to my last question. Valve springs. Would the stock VQ35DE valve springs work on my DEK? I'm concerned because since this is more of a jump from the stock camshaft profile, that the DEK springs may not be stiff enough. Or should I go with HR springs? The reason I'm asking is because I can get some stock Z cams with the stock springs for cheap-ish.
Thanks for reading my wall of text
EDIT: Since I'll be revving to around 7k rpms then I will def need the HR valve springs. Any insight on my other questions is greatly appreciated.
__________________
2001 A33 AE || KV3 || 5MT || VLSD
SHIFT_sleepy
PM for cheap Infinity, Rockford Fostgate, and Kenwood car audio equipment!
To be honest, I have little recolection of this as I had VQ35 Max cams however sold them since I got Dandymax's motor. But I would recmmend changing to HR springs retainers etc since you'll be in there swapping cams anyways.
__________________
2000 Maxima SE| Tein S-Techs/Illumina struts | Stillen Front lip | Enkei 18" RSV's | Blacked out headlights | Brembo cross-drilled rotors | Cammed/mildly ported DEK W/VQ35HR springs/retainers| Cattman Headers | Greddy EU | Innovate WBO2| VIS CF Hood|Budget B Pipe |WAI | Maxxtunning VB | Hayden Tranny Cooler
To be installed | NWP DE-K manifold spacers | Greddy Evo 2 catback | Cattman Fastcat | Remove 00VI powervalve | 3" Custom MAF
The camshaft specs you listed are for "revup" 350Z/G35 cams. Standard 350Z cams came in the maxima/altima/quest etc. Quick way to tell which set you are getting is to look at the rear of the cams. If only the intake cams have timing "teeth", they are the latter. If all 4 have said "teeth" then they're the more aggressive "revup" cams.
Just FYI: VQ35 springs are actually softer than VQ30 springs.
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
So this is why you asked me if i still had the Rev up cams!
* Good luck bro, its almost show time.
Haha well, that only depends if the cam spacers will still work to my benefit, as far as cam timing goes.
And I still gotta buy the new valve springs/retainers. Should I double shim the springs? Where/how do I get shims if I'm buying through an online catalog? Since I'm using at the most a set of 05 Z/RevUps I'm not sure if double shimming is even necessary if I plan on cutting the fun off at 7,200rpm.
And Nismology, are you familiar with how the dowel holes on the SM cam spacers affect the opening/closing events on the cam? This is the last issue I have, since my project will be put even farther off if I have to get new spacers. (Money is tight since I'm at school)
__________________
SHIFT_sleepy
Awesome. That makes sense, now that I think about it. HR Zs have a slightly higher rev limit using the RevUp cam profile with HR springs anyway.
I'll call DaveB and see what he quotes for HR springs/retainers, I've pulled some online catalogs that put that combo just under $150. RevUp cams are relatively easy to come by.
Thanks everyone for your help. Nismology you're a great asset to the community.
__________________
SHIFT_sleepy
