Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 09-09-2009, 10:46 PM   #1
??00VI on a VQ35??
Okay... so a very reputable org member brought this up once, but didnt give much info.
So what I'm trying to find out is if this has been done!? Not sure if it was a sarcastic remark, or an actual project thats in the making. Not sure if there would be massive hp/tq gains, but just thought i'd ask.
Anyone!?!?
__________________
915Max is offline   Reply With Quote
Old 09-09-2009, 11:07 PM   #2
I assume you're referring to nismology's comment.
Two problems...TB and LIM.
You could run the PF tb or something along those lines, but obviously somewhere down the line you're going to need an adapter plate. Though, I would think you could run the DEK TB, assuming you're swapped. Else, youd be stuck with the 3.5 TB and have to get an adapter plate made.
With the LIM, its a lot trickier. You have 3 options. The 3.5 LIM, 3.0 DE and 3.0 DEK LIMs. With either of the 3.0 LIM's youre going to have to port match the LIM's and heads to get them to flow decently. With the DE LIM, you'll have to redrill it, making the DEK LIM a much more approachable LIM to use. If you decided to use the 3.5 LIM, (not sure of the shape of the ports, not as familiar with the 3.5 as I should be) you'll have to do some work on the UIM and LIM to get the ports to align up and flow decent.
So, either way, LIM is gonna be the hardest part. If I were you, DEK LIM and fuel equipment, with a return less setup. Unless someone can share that the 3.5 LIM would be easier to use, I cant answer that for sure.
Oh yeah, and Im pretty sure there are a few more "issues" to work around, but those are what came to mind.
__________________
00VI | 5.5Gen BBK | 00 5 spokes | Kumho Ecsta SPT | Cleared Tails | FX retro | LED interior | SNOMAX's LCAs | Raxles
FS: Plug and Play E-manage Ultimate, E-manage Blue & VAFC/SAFC Harnesses
Florida Gators: (11-0) | CSU (62-3) W | Troy (56-6) W | Tenn (23-13) W | Kentucky (41-7) W | LSU (13-3) W | Arkansas (23-20) W | Miss St (29-19) W | Georgia (41-17) W | Vandy (27-3) W | SC (24-14) W | FIU (62-3) W | FSU
MOHFpro90 is offline   Reply With Quote
Old 09-09-2009, 11:14 PM   #3
I know there would have to be some modification involved to achieve this. I just wonder if the DE-K upper manifold would bolt up to the 3.5 lower manifold.
I would assume that it would be best to use the 3.5 fuel system... arent the injectors larger on a 3.5 than a 3.0!?
I wish I could get my hands on a 00vi to get a visual of possible issues, but I'm not as fortunate....
__________________
Old 09-09-2009, 11:46 PM   #4
Ive got some pictures and such, what you need? dimensions?
From what I know, the 00VI will not bolt to the 3.5 LIM.
Edit: And yes, 3.5 injectors are larger, however you would need a tune regardless of what "route" you went while doing this, so you could tune for the smaller injectors. Or just get bigger 3.0 injectors.
__________________
Old 09-10-2009, 04:58 AM   #5
the de-k injectors will flow more then the 3.5 injectors. I dont remember the exact numbers but Im pretty sure that the dek's flow more
Also i belive there has been only one or two people that have utilized the 00vi on the 3.5. I know krismax for sure.
The other option besides grinding the snatch out of your manifolds and what not is to use Heads off a Pathfinder.
But IIRC there will not be gains using the 00vi over the 3.5 upper. I belive some power is lost.
__________________
97 Maxima GXE Totalled
96 Maxima Se Blown 3.5 New one coming
90 B12 Sentra My new winter beater
Product_Of_Korea is offline   Reply With Quote
Old 09-10-2009, 09:49 AM   #6
RIP Kevin007
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
I think this was discussed in one of Nealoc's threads because he had the 3.0 DE IM on his 3.5.
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The 3.5 Swap 15.508@90mph 60' 2.3 AUTO (Bad KS and stock catback) 210whp, 213wtq
The Dark Phoenix 13.402@102mph 60' 1.9 AUTO 257 RWHP 3280lb w/driver
Fear me.
My VQ35 Swap Progress Thread Now Complete!
ajcool2 is online now   Reply With Quote
Old 09-10-2009, 10:26 AM   #7
Quote:
Any links to this!?
I'm looking for info on the DE-k... not the DE manifold.
__________________
Old 09-10-2009, 11:20 AM   #8
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
Quote:
Originally Posted by 915Max View Post
Any links to this!?
DE and DEK LIMs are the same as far as port shape goes, that's the point he's making.
You could make this work, but it would require either:
a) a lot of porting in order to use a 3.0 LIM on the 3.5 heads (which would do unknown things to their flow, could be good, could be bad).
or
b) an adaptor plate to make the 00vi upper match up with the 3.5L lower (which would need to be 3D machined to have the different port shapes morph to match each other, and then you'd need to figure out how to work the bolts because the bolts aren't even close to matching up either).
or
c) (and I believe this would work, but someone correct me if I'm wrong) pathfinder heads which have intake ports shaped the same as 3.0s (or utilization of 3.0 heads on a 3.5 which I don't feel is a good idea).
I bought an 00vi with the intention of doing option B, and when I finally realized how badly things were misaligned I said "to hell with this" and sold the 00VI. Wasn't worth the effort for me - I have the means to design and machine the adaptor plate at my buddy's house but I just decided it wasn't worth the effort.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 09-10-2009, 11:31 AM   #9
Holy crap dude... thats pretty far off.
There have been a few topics of the 3.0 heads on the 3.5, but it involved enlarging the diameter of the combustion chamber on the heads to clear the piston. And the lack of flow with the 3.0 heads is a downfall.
How do the PF heads flow compared to the 3.5DE?
IMO, seems like a lot of work, even though the 00VI may be regarded as one of the best UIM's made, the ammount of work to go in to get it on the 3.5 might just be absurd...
__________________
Old 09-10-2009, 11:52 AM   #10
SLOW
Nealoc187's Avatar
__________________
Old 09-10-2009, 12:03 PM   #11
SLOW
Nealoc187's Avatar
here's the thread that's from
VQ30 Maxima, VQ35 Pathfinder, VQ35 Maxima Cylinder Flow Data
__________________
Old 09-10-2009, 12:54 PM   #12
Super Moderator
Send a message via AIM to nismology
Yea it was me that he originally contacted. I'm convinced that the 00VI more than makes up for the difference in head flow (which can be improved anyway) and will set out to prove it once I find a decent 5MT '01.
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
nismology is offline   Reply With Quote
Old 09-10-2009, 12:57 PM   #13
Super Moderator
Quote:
Don't remember reading this. In any case, I highly doubt this is necessary since the squish clearance doesn't change regardless of the heads you are using as long as stock pistons and head gaskets are being used.
__________________
Old 09-17-2009, 04:46 AM   #14
No need to enlarge the combustion chamber volume on the VQ30 heads, if anything having larger bore pistons with a smaller bore head is an advantage!
VQ35 injectors flow more fuel but only when they have 3.5bar stock rail pressure and the DE-K is running its stock 3bar rail pressure. DE-K injectors would flow more fuel on a test bench when both are being fed 3bar and as such, DE-K injectors at 3.5bar would outflow VQ35 injectors on 3.5bar
__________________
Nissan N14 Pulsar - VQ35DE, 6spd HLSD, Kelford Spec C cams, 12.7:1CR & E85 tuned
Smashed Holden VY SS LS1 Twin Turbo Ute - 641rwHp@12psi Pics
New LS3 6.2 Camaro, Boyd Harm wheels and a big single Turbonetics huffer...
throttlehappy46 is offline   Reply With Quote
Old 09-17-2009, 11:41 AM   #15
Quote:
Damn where did I read that? Maybe it was the thread where someone was trying to use the VK45 pistons in the 3.0 to get the higher CR. Anyhow thanks for correcting me
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
