Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-31-2009, 09:06 PM   #1
Unorthodox Crank pulley Question?
Hi guys....today arrived my unorthodox racing crank pulley to my 3.5L engine. I am in the process of purchasing all the things to make this swap possible in my 4th gen. Now, i am gonna use a 2005 maxima engine with the 3.0L timing, and i make a little mistake and ordered the crank pulley for 02-06 engine. As all you know, the 1995-2000 crank pulley uses a ring for the ckps (ref).
Now my questions are:
Can i use the unorthodox pulley with the 3.0L upper pan and 3.5L ckps (REF) sensor?
if possible...any modification is needed?
Or if any suggestion on what to do for make it work....
Thanks in advance for all your income..
__________________
SHIFT_www.Zlegends.com Nissan Crew at Puerto Rico
MaxPR0908 is offline   Reply With Quote
Old 08-31-2009, 10:17 PM   #2
Willing to learn
oldngivout's Avatar
If you will be using 3.0 timing equipment on your 3.5 swap, such as the upper oil pan and crank sensor, then you cannot use the 02-06 pulley. The 95-01 3.0 pulley has some trigger mechanisms for the crank sensor built into it. The later pulley doesn't have them, that's why it will not work.
__________________
Unless you do it exactly like I did, your results may vary.
oldngivout is offline   Reply With Quote
Old 09-02-2009, 04:26 PM   #3
ok...another question... i can use 3.0 timing equipment with the 3.5 upper oil pan and crank sensor?
I imagine that if i use the 3.5 upper oil pan i have to adapt the 3.0l crank sensor and obviously i can not use the pulley.
__________________
Old 09-03-2009, 01:39 PM   #4
Willing to learn
oldngivout's Avatar
You can use the 3.5 sensor with the 3.5 upper pan, if you change the connector on the 3.0 wiring harness to match. Easiest option in my opinion.
Or you can use the 3.0 sensor on the 3.5 upper pan by shaving down the surface to which it mounts. I think the 3.5 pan places the 3.0 sensor too far from the flywheel.
__________________
Old 09-03-2009, 03:09 PM   #5
Super Moderator
Send a message via AIM to nismology
Since this is dealing with UDP's I would assume he's talking about the REF sensor for which the 3.5 oil pan has no provisions, AFAIK.
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
nismology is offline   Reply With Quote
Old 09-03-2009, 04:52 PM   #6
i check today my motor and i understand now what nismology said...thank you
it doesn't have the ref sensor or any sensor in there..
__________________
Old 09-03-2009, 05:33 PM   #7
Super Moderator
Son of a.........I guess the 3.5 oil pan does have holes to mount the REF sensor after all. (duh....how else would all these swapper be using the 3.5 pan.)
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
