Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-09-2009, 06:53 PM   #1
Any one know what a Built 3.5 compression psi would be per cylinder?
Do any one know what the exact numbers should be on a built vq 3.5 bored out .020 over stock (3.6) liters with 9.0:1 wiseo pistons , did a compression test and got 175-180 psi from cylinders 1-3-5 and 160-165 from 2-4-6 getting mixed numbers when searching
96sleepergle is offline   Reply With Quote
Old 08-09-2009, 07:06 PM   #2
Super Moderator
Send a message via AIM to nismology
The numbers from bank to bank should be pretty consistent. There seems to be a 20PSI max variance with your setup and that is excessive per the FSM. Either there's a head gasket breach all along the front cylinder bank or the cam timing is off (more likely of the two).
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
nismology is offline   Reply With Quote
Old 08-10-2009, 10:29 AM   #3
Quote:
Yep your right was discussing it with my brother theres no oil spitting outof the breather filter nor smoke but it seems to be off sequence when you listen to it idling never thought of the cam timing being off but thats what it sounds like your the man nismology tilley built this motor there were aot of F+++ked things he did so we will be pulling this motor to fix all his screw up
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
