Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-06-2009, 01:51 PM   #1
question?
I'm new to the vq scene. i saw the cosworth heads and didn't find any info or reviews on it. I was wondering what ya'lls thoughts would be on the cosworth heads w/ JWT c8 cams.
would it be beneficial on a NA set up?
heres a link to the heads
http://www.stillen.com/product.asp?i...SAN&model=350Z
thanks in advance
04flspecv is offline   Reply With Quote
Old 08-06-2009, 05:00 PM   #2
bump. please chime in anyone?
__________________
04 satin black se-r spec VQ
vq35de-250mm clutch, CAI, headers, 3in vrs exh, VIAS Dlete plate, shftr bshngs, tein SS, 4pt trnk bar, upg fp.
future-rebuilt high comp/cammed tuned VQ, 5lug conv, rims, Xmmbr insrts, CNC bshngs.(c/f trunk and sparco seats )
Old 08-06-2009, 05:55 PM   #3
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
you don't need to bump a thread from 2 posts down back to the top of the forum a mere 4 hours after it was posted. this forum gets a couple posts a day in it, your thread is not going to get lost in the shuffle. do not do that again.
VQ35 heads are some of the best flowing factory heads in existence on any normal street car (by that I mean short of supercars). unless you are building a race car and by that i mean a RACE car and you are willing to pay through the nose to get every single ounce of power you can out of the VQ35 NA, there is no way I would spend the money on touching the heads of a VQ35 let alone get the cosworth heads for it.
Cams are another story stock VQ cams are very mild. I don't know the specs on the C8 specifically, but cams are very worthwhile on a VQ assuming you have lofty power goals either NA or boosted.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 08-06-2009, 10:53 PM   #4
thanks for the info, i didn't know its that serious for a measely bump.
i'm not sure of the specs of the c8's but travis used them on barry's car which is another sentra vqswap.
i was told from another member on my sentra site that going +1mm on the ports wouldn't be beneficial on a NA motor.
so if any more info that can be posted it would be great.
thanks again.
__________________
Old 08-07-2009, 07:32 AM   #5
thanks again.
The Cosworth VQ35 heads are a piece of art but the price is steep. If you can P & P the heads yourself and have the valve seat bored by a machine shop you would save a bundle and have better flowing heads, but this kind of job take countless hours. I have a VQ 30DEK and I did an extensive P & P jobs on the VQ DEK heads, I then took them to a machine shop where they replaced the valve guide for manganese/bronze one but they also increase the valve seat by 1 mm ( this was done on a CNC ) The heads where also mounted with HR spring & double shim. I should know within the next month how well the heads flow now but there is no doubt in my mind that they will flow much better than before.
Adding aggressive cam would definitely give you more HP & TQ's, how much more ? well this depend on what other mods you have but I think a 15 HP should be close to reality, with a good tuning and P & P on the heads I think that should be in the 25-30 HP + range.
I will know for sure only when my car is running and dyno'd.
Hope it help.
Cheers
AA
__________________
2K1 AE-SE - Sterling Mist
2004 BMW X5 4.4i
doublea is offline   Reply With Quote
Old 08-07-2009, 08:49 AM   #6
The LandShark has teeth..
grey99max's Avatar
thanks in advance
I'm in the final stages of assembling a seriously-built short block ( CP pistons, Carrillo rods, balanced, etc) and a new set of Cosworth heads and ZK2 cams for my '99, using the 3.0 timing setup with custom gears... I like the 10,500 RPM valve train - gives me a reason to upgrade the ECU setup.
grey99max building another 3.5
Check with Cosworth for details: http://www.cosworthusa.com/
Their NA power gains were - impressive. Their flow bench numbers were also impressive.
Check on one of our member's experiences with porting the VQ35 heads and racing N/A with his car.
3rd gen VQ35DE Full ECU Swap Progress Thread
Make your own conclusions...
__________________
'99 GXE, Tune-by-Tape MAF mod, 3.5L w/cams, SSIM, 255Walbro,AERO FPR, VLSDauto, Edge TC, DR-mod, Shift_Fast, dual-B&M cooler, JClawbars, cryoed axles, dual-NX nitrous, dual heated15lb bottles, OBX headers, 3"Warpspeed exhaust, PLXR-300 wideband, IlluminasStrut/springs, 24.5"M&H, ProgressRSB, HawkHPS, Clarion50Wx4 head w/Alpines, Fosgate sub. Spare tire+jack,3300 lb car. 355WHP-dyno.
12.394 @113.22 ( 114.51 now) w/3.5
http://i48.photobucket.com/albums/f2...9/DSCN0527.jpg
grey99max is offline   Reply With Quote
Old 08-07-2009, 10:22 AM   #7
awesome info guys. can't wait to see ya'lls #'s on ya'lls build. I really appreciate the info and ya'll taking the time to post up useful info.
thanks again.
later
chris
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
