Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-06-2009, 12:27 PM   #1
Mr.Duck's Avatar
Send a message via AIM to Mr.Duck Send a message via MSN to Mr.Duck
00vi not opening
so at maxus i dynoed my car, and the dyno read like i had my stock intake manifold off, the power just dropped past 5500rpms or so.... so when i checked my VI, alas it was not opening
so i searched and searched, and i even checked my VIAS and it is still in tact, but my VI is not opening.
my switch is working, i opened it up, and the light comes on when i hit the RPM rangeits supposed to open at, but my VI is still not opening. Could it be the solenoid? anybody have a part number for the solenoid?
anybody have any ideas on what the problem could be?
__________________
Modifications:Cattman Y-pipe, Motostorm UDP, Blehmco Ground Kit, SS clutchline, Autovation Aluminum Pedals, Otto Racing FSTB, Ksport Coilovers, SRE Short Throw Shifter, 00vi
14.521 on street tires
14.42xon drag radials(will update when i get my slips outa my car)
Chicago members!!!!
http://www.chicagonissanclub.net/
Mr.Duck is offline   Reply With Quote
Old 08-06-2009, 01:36 PM   #2
RIP Kevin007
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
What kind of switch are you using?
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The 3.5 Swap 15.508@90mph 60' 2.3 AUTO (Bad KS and stock catback) 210whp, 213wtq
The Dark Phoenix 13.402@102mph 60' 1.9 AUTO 257 RWHP 3280lb w/driver
Fear me.
My VQ35 Swap Progress Thread Now Complete!
ajcool2 is offline   Reply With Quote
Old 08-06-2009, 01:44 PM   #3
Mr.Duck's Avatar
IIRC, its a summit racing switch
__________________
Chicago members!!!!
Old 08-06-2009, 02:03 PM   #4
Not a GM sack rider...
did you look at the lil cup closely? Mine looked good from the outside and moved when I used the outer shaft to spin but when I opened it up, the hole in the cup was worn out and the rod just spun inside the hole. Run vacuum to one of the nipples, not sure which, to see if it opens to eliminate possibilities...
DAVE Sz is offline   Reply With Quote
Old 08-06-2009, 02:50 PM   #5
Mr.Duck's Avatar
when i opened it up,the cup moved fine when i manually opened the switch from the outside, is there still a need to run a vacuum to it?
__________________
Chicago members!!!!
Old 08-06-2009, 03:35 PM   #6
try the VIAS test by putting a vacuum hose on the nipple and sucking in air to if its holding vacuum at all.
__________________
SHIFT_4.GO
96 Nissan Maxima SE 5SPD
Full Warpspeed Exhaust~Short Shifter~Exedy Stage 1~00VI~Black Leather Conversion~Shaved~Blacked Out Lights
96nismoSE is offline   Reply With Quote
Old 08-06-2009, 07:59 PM   #7
Just because that LED is lighting up, its possible that there is no voltage going to the valve. Might wanna multi meter test.
__________________
00VI | 5.5Gen BBK | 00 5 spokes | Kumho Ecsta SPT | Cleared Tails | FX retro | LED interior | SNOMAX's LCAs | Raxles
FS: Plug and Play E-manage Ultimate, E-manage Blue & VAFC/SAFC Harnesses
Florida Gators: (10-0) | CSU (62-3) W | Troy (56-6) W | Tenn (23-13) W | Kentucky (41-7) W | LSU (13-3) W | Arkansas (23-20) W | Miss St (29-19) W | Georgia (41-17) W | Vandy (27-3) W | SC (24-14) W | FIU | FSU
MOHFpro90 is offline   Reply With Quote
Old 08-08-2009, 09:41 AM   #8
dave, did you figure it out?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
