Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-05-2009, 07:23 PM   #1
4th Gen Fidanza Flywheel not fitting on Crank Shaft
Hey
I ordered a fidanza flywheel (12lbs) and clutch from ebay. The flywheel weighs 12 pounds as stated and the clutch checks out. Now when I went to go put it on the flywheel does not fit on the crankshaft as the center hole is to small. My brother says the flywheel is a knock off. Is there any way of figuring if its a true fidanza flywheel? It does have some sort of ID scratched into the flywheel but thats it.
Any help would be appreciated. The flywheel is going to a machine shop tomorrow to have it enlarged, of course the original flywheel is going with it for proper measurement.
OC_Nooby is offline   Reply With Quote
Old 08-05-2009, 09:31 PM   #2
I've never heard of this, but if your having it machined then I guess it wont matter. Maybe someone will chime in that has had the same problem.
__________________
WTB 97-99 Stillen Rear skirts
maxboy325 is offline   Reply With Quote
Old 08-06-2009, 07:57 AM   #3
'Trynna' is not a word
mtrai760's Avatar
I have installed a few Fidanza's and they have always been really snug. The one I just installed took a few minutes of light sanding and testing to get it to fit right. Never required any machining though.
__________________
98 SE - VQ35
2k SE - Stock... pretty much
Boost, juice, conversions, been there, done that.
mtrai760 is offline   Reply With Quote
Old 08-06-2009, 02:13 PM   #4
was there any labels or marking to show that its a fidanza flywheel?
Old 08-06-2009, 08:24 PM   #5
Quote:
Originally Posted by OC_Nooby View Post
Hey
The fidanza I installed was snug as well, I just put in 6 flywheel bolts and tightened them evenly with not much effort till it pulled flush with the crank. Then removed the bolts and re-installed with loctite and torqued to 69 ft-lbs, have 600 miles on it now no vibration.
Tmars is offline   Reply With Quote
Old 08-12-2009, 10:52 AM   #6
what's the weight difference on the fidanza? I ma very interested in the flywheel but Aasco said the stock flywheel was like 15 pounds? and that 5 pounds would be better? im looknig for about half of the stock weight. can anyone verify what that might be?
i have a 4th gen
Blazingwolf is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
