Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 01-14-2009, 12:55 AM   #1
Ignition Timing Problem
I have a weird issue with my ignition timing under partial throttle.
I datalogged my timing using the EU and noticed that my timing was dropping down to anywhere between 0 degrees and 10 degrees advance anywhere between 7-60% throttle. I have no codes that would point to a problem with ignition timing. This problems is also intermittent. When this condition is present and I try and accelerate, the motor just makes a sputtering sound and a serious lack of power is evident. I'm leaning towards a bad CPS sensor (maybe both). I have no codes for them and I was wondering if anyone else had any suggestions. I dont have hard start problems. I dont have a knock sensor code. What could cause such a huge retard in timing considering that its happening anywhere from 7% to 60% throttle. I dont think its a misfire because acceleration, even though it's horribly slow, is smooth.
__________________
Mods:| Cammed VQ35 | SSIM | HR springs | ARP rod bolts | OEM Nissan rwd head-gaskets | Budget Y-pipe and Catback | NWP Spacers | Dynomax Superturbo muffler | EdgeRacing Converter | Transgo Reprogramming Kit | Hayden Transmission Cooler | JWT Pop Charger | Emanage Ultimate | SSV4 | Innovate LC-1 WB | DR mod | ES motor mounts | ES x-member bushings | ES LCA bushings | Polyfilled tranny mount| 15" RX-7 BBS wheels (12lbs/rim) | Street tuned: 13.0 AFR, 7200 Rev limit, advanced timing |
whlimi is offline   Reply With Quote
Old 01-14-2009, 09:19 AM   #2
KRRZ350's Avatar
Send a message via AIM to KRRZ350
Does it only happen with the eu in place? If so, are you comfortable enough with wiring yet to leave the patch harness in place and jump the injector & coil pins, I'd like to rule out the patch harness, in particular one of the ground wires on it, or just interference in general. Also, I kept searching for you and dug up the rest of my wiring stuff, so I can tell you which wires on the 4-cylinder eu harness were used for inj&coil's 5 & 6 in & out.
Otherwise I would think it was a tps or maf issue ftr.
KRRZ350 is offline   Reply With Quote
Old 01-14-2009, 11:07 AM   #3
Send a message via AIM to MDeezy
i agree. trouble shoot section by section. first rule out whether its the EU's doing or something else. test sensors with a voltmeter to verify its still putting out the correct voltages it should be.
MDeezy is offline   Reply With Quote
Old 01-29-2009, 05:53 AM   #4
I replaced the TPS and calibrated it and now it seems to run a lot stronger under light to moderate throttle. The only thing is I had to set the TPS to around 0.2V at idle.
I have this thread in the 4th gen section concerning ignition timing at idle with big cams.
Aftermarket Cams and idle ignition timing
Just wanted the input of those who are running aftermarket cams.
__________________
Old 03-23-2009, 10:28 AM   #5
I have since removed the patch harness and wired everything directly to the main harness but I'm still getting the sputtering at part throttle and ignition timing dropping to low teens. I ruled out the KS buy hooking it up to the firewall. I swapped the 3.0 coils in place of the 3.5 to see if it was a coil issue and the symptoms are still present. The only thing left is MAF or ECM.
Could a dying maf present those symptoms without throwing a code or going into fail safe mode? The worst part is that the problem is intermittent and no codes...very frustrating.
__________________
Old 03-26-2009, 11:36 PM   #6
It seems the ABS/TCS unit was responsible for the retarded timing. I had P1320 because of the EU (no resistors ) and the TCS module didnt like that and lit up the SLIP/TCS OFF lights. I unplugged the module all together and the car runs fine now. Any thoughts as to why it would cut fuel, indirectly retarding timing? I confirmed by plugging in the TCS unit again and the symptoms returned immediately. So right now I have no ABS/TCS but car runs fine
__________________
Old 03-27-2009, 06:30 AM   #7
I wonder if that could also be a problem too... I have th ABS light on, on my swap. No EU thou. I'll found out today.. good info
SleepyMax1 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
