Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Closed Thread
Thread Tools Display Modes
Old 11-19-2008, 08:41 PM   #1
Send a message via AIM to TurboS13Hatch
HR pistons in VQ35DE block.. no go without mods..
I'm starting a new thread, and hoping that a mod will sticky this.. so you guys can avoid the same problem that I've encountered.
Stock HR pistons, with VQ35DE rods/crank will not work, without either slightly fly cutting the edges of the pistons, or, by using a slightly thicker Cometic head gasket.
Without mods, and with clearances set a little on the loose side (any performance built engine), the pistons just barely make contact with the quench pads in the cylinder heads.. So, I would recommend fly cutting the edges on each piston, up to about 1/8" from the valve reliefs. I would cut it around .010" deep, to avoid any/all potential contact.
Here's a pic to show what I'm talking about..
The area in the rectangle, shows how contact with the quench has cleaned the piston of carbon. We're not talking much here, but, there's enough contact to cause noise. By cutting the area shown with a mill, you can increase clearance by about .010", just to be safe, and get away with putting HR pistons into your DE block. You should be able to get this done at any competent machine shop for around 100.00 for 6 pistons. Or, you could spend a few more bucks, and get Cometic gaskets that are a little thicker, and avoid having to cut the pistons alltogether.
Anyway.. just wanted to share some useful info..
Travis
TurboS13Hatch is offline
Old 11-19-2008, 11:56 PM   #2
Ok, so I did some research.. and found that the HR pistons have the same dome volume as Rev-up pistons. The difference in compression ratio between the two, comes from changes in the combustion chamber volume. So, we know that HR pistons have a 5cc's of dome volume. We can get pretty close in guestimating that the .010" of material removed will equate to roughly .5cc.. MAYBE 1cc.. max.. So here we go..
Bore- 3.759"
Stroke- 3.204"
HG thickness (compressed)- .028"
Deck height- -.007" (after removing material/splitting the difference with the rest of the remaining (taller) material where we didn't take .010" out)
Piston dome volume- -4.5cc (with material removed)
Combustion chamber volume- 56cc's
This give us a static compresion ratio of 11.53:1. I would say that it will be plus/minus 1 tenth, depending on the exact dome volume, but, it's safe to say that it'll be within .5cc's of my estimate. So, betwen 11.4:1 and 11.6:1 static compression with this HR pistons, fly cut .010", in a DE block with DE heads/rods/crank.
Travis
Old 11-20-2008, 07:33 AM   #3
sparks03max's Avatar
Quote:
Bore- 3.759"
Stroke- 3.204"
Travis
Seems like you're still having alot of fun with those vq swaps in the specs, travis. Are the HR pistons forged?
__________________
2003 SE 6MT Titanium Edition - Sterling Mist
Power mods: SRI, VIAS Delete, NWP spacers, Cattman Headers, Custom exhaust, TurboXS UTEC + Tuner
12-second 5.5 gen track vid: http://www.youtube.com/watch?v=HDz_fIHZgig
sparks03max is offline
Old 11-20-2008, 10:54 AM   #4
Super Moderator
Send a message via AIM to nismology
Quote:
They are still hypereutectic cast.
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
nismology is offline
Old 11-20-2008, 11:29 AM   #5
Super Moderator
Stuck.
__________________
Old 11-21-2008, 11:27 AM   #6
Thanks Nismology..
I snapped a few pics of a piston that has been cut down .010" to clear the head..
The piston's edges are now flush with the bore.
Travis
Old 02-11-2009, 07:08 PM   #7
Super Moderator
Thread closed. Will consider reopening if the OP has something new to add or if someone has a legitimate question that has not been addressed.
__________________
Closed Thread
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
