Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-27-2008, 08:58 PM   #81
Quote:
Originally Posted by Aaron92SE View Post
Yeah. Whenever you replace rings without boring out the cylinder, you are only making things worse unless the rings are in really bad shape, then anything would be better. If all you do is break the glaze with a light hone and use stock rings, it will seal just that much less.
I know what you mean and it make sense in a way that if it's not broken dont touch it. But I think that if the concentricity of the cylinder is within spec ( the maximum out-of round clearance on a VQ30DEK is .015 VQ35 should be similar)
If within spec I would then only polish the cylinder wall in order to only remove the carbon build-up, no need to shave any material. With a new set of stock ring and cleaned cylinder wall, I'm almost sure your compression test for each cylinder will be higher and very close to each other.
I guess my next step is to remove the heads and inspect the cylinder walls. Or do you think I should bother with a leak down test first? I can get a tester pretty cheap. But, I am not willing to spend the money on boring the cylinders right now. I'm already way over my budget because of the, "while you're in there, you might as well", mods.
Doing a leak down test is cheap and may tell you something that the guess work wont. Let say the compression is pretty much consistent from one cylinder to another after the test, then there will be no need to investigate further, you know you have a good engine. On the contrary if there is let say one or two cylinder that are off compare to the others, you will then have to investigate further to see what's the cause ( cylinder concentricity, out of spec ring etc.) or anything else.
__________________
2K1 AE-SE - Sterling Mist
2004 BMW X5 4.4i
doublea is offline   Reply With Quote
Old 10-27-2008, 08:59 PM   #82
Super Moderator
Send a message via AIM to nismology
If the crosshatch pattern is still intact, re-ringing the motor without honing is the proper method. You only want to hone if you absolutely have to.
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
nismology is offline   Reply With Quote
Old 10-27-2008, 09:00 PM   #83
NWP Engineering.com
Aaron92SE's Avatar
Send a message via AIM to Aaron92SE Send a message via MSN to Aaron92SE Send a message via Yahoo to Aaron92SE
Quote:
Originally Posted by eng92 View Post
I did not rehone and I do not burn any oil. The factory x-hatch hone pattern was still clearly visible on the walls so I just left them.
My leakdown numbers went from about 40% to about 5% on a cold engine. Originally I was leaking air past the rings and through a few of the exhaust valves.
If you are pulling the heads anyways then don't bother doing a leakdown.
Thanks. Did you replace any of the valve seals since you heard air escaping from the exhaust valves?
I am guessing that since the engine is so cold, compression or leak down test numbers will vary from one cylinder to another. I will go ahead and yank the heads and inspect everything thoroughly. I will post my findings.
__________________
NWP Engineering Phenolic Thermal Intake Spacers
10hp and 12ft-lb gain & 40°F temp drop on the VQ35DE
Engine Torque Link Bracing Kits now available for the 1995-2003 Maxima!
The first VQ35DE Full ECU engine swap in a 3rd gen Maxima
92 Maxima SE Auto VQ35DE Swap
VE Auto PB: 12.8 @ 104mph w/ 75 shot
VQ35 PB: 12.76 @ 108 mph ALL MOTOR
Winner of the MAXUS 09 NA Maxima Unlimited class!
Aaron92SE is offline   Reply With Quote
Old 10-27-2008, 09:03 PM   #84
NWP Engineering.com
Aaron92SE's Avatar
Quote:
That's the thing. I'm not sure if my numbers are considered inconsistent. I didn't like the dry numbers, but when I put equal amounts of oil in each cylinder, they were all near perfect.
I can get a leak down test kit for only $30. If you think it will help, then I can do it.
__________________
Old 10-27-2008, 09:21 PM   #85
eng92's Avatar
I bought the top end gasket set so all the stem seals were replaced.
eng92 is offline   Reply With Quote
Old 10-27-2008, 09:30 PM   #86
Super Moderator
To be clear, new valve oil seals will not fix a leaky exhaust valve. The leak eng92 is referring to was occuring where the valve meets the seat.
__________________
Old 10-27-2008, 09:38 PM   #87
NWP Engineering.com
Aaron92SE's Avatar
Gotcha. Thanks guys.
eng92, did you happen to visually see any imperfections in the exhaust valves, seats or seals?
Quote:
__________________
Old 10-28-2008, 01:56 PM   #88
eng92's Avatar
There was no physical damage to any of the valves or seats.
There were a lot of carbon deposits in the seat area and on the back of the valves. I suspect they were preventing the valves from closing fully. Fortunately none of the valves were burned and there was no seat errosion.
I just cleaned everything up with a brass brush/wire wheel and hand lapped the valves to the seats.
Old 10-28-2008, 02:36 PM   #89
NWP Engineering.com
Aaron92SE's Avatar
OK thanks. I went ahead and bought a leak down tester today. I know it won't hurt to do the test and it will give me a good idea if I may run into any valve sealing issues as well. The more I know about this engine before I remove the heads, the better.
__________________
Old 10-28-2008, 04:21 PM   #90
Jime's Avatar
I know you are getting lots of good advice Aaron but I am on my 3rd 3.5 and haven't pulled a head off yet or modified the stock block and have never got an oil burner. I think I would run it like it is before doing anything and if it gives you problems or doesn't perform then go for it but the old " if it ain't broke don't fix it" comes to mind. I dont like to borrow trouble or do work if it isn't necessary and I hate spending money. So far it has proven to be the best route.
If you have the whole winter with nothing to do, hmmm maybe but I have other stuff I can do that is more fun.
__________________
0-60 MPH = 2.38 sec
Jime is offline   Reply With Quote
Old 10-28-2008, 09:23 PM   #91
NWP Engineering.com
Aaron92SE's Avatar
Thanks. I can work on this engine through the entire winter, but I'd much rather get this car back on the road as soon as possible. I definitely would like to do cams, ARP bolts, and HR springs. While I'm that deep, I might as well put in HR head gaskets and do headwork.
Today, I did a brief leak down test with results of 13-15% pressure loss. I plan to conduct a much better test tomorrow to see if anything differs between cylinders with regards to the valves. That will give me a better idea of which cylinders I need to pay closer attention to once the heads are removed. But at the moment, it does not appear that I will need to touch any of the rings.
__________________
Old 10-28-2008, 09:37 PM   #92
Hey Aaron, if you need new valve seal, I have an extra set of Toga valve seal I can sell you, I've posted it in the 5th for sale forum.
__________________
2004 BMW X5 4.4i
Old 10-28-2008, 10:55 PM   #93
Quote:
Originally Posted by SurraTT View Post
what about using the vq30 fuel rail. its a return system right?
i havent looked at injectors at so for all i know vq30 fuel rail will plug n play wit vq35, thus having a return system.
which for the ve fuel pump im 99% sure u will have to convert to return system
Quote:
Originally Posted by pmohr View Post
Yes, VQ30 is a return style setup. The rail won't work with the VQ35 LIM, though. So to use the VQ30 fuel rail, you'd need a VQ30 LIM, which only matches up perfectly with the Pathfinder VQ35 heads (or VQ30 heads obviously).
As has been said, it's a trivial thing to convert the VQ35 to a return style fuel setup. Many aftermarket companies make return systems for this motor.
Of course, you could always look into the 4th gen VQ35 swap threads, there are instructions there for cobbling together a return system.
makes sence, jus do what 4tg gen guys do to convert to return system!
i didnt think of that.
Not sure if someone mentioned this previously, but if you are using the A33B ECU then you need to convert to a BYPASS fuel system, not "return" setup. Most A32 guys switched over to return systems because they were able to utilize the stock style return system that has variable fuel pressure. The A33B likes the FP to remain at 51 PSI. You are better off using the stock VQ35 fuel rail with a bypass style FPR, just bypass the bleed off pressure to your return line and set the static FP to 51 PSI. No need to change out fuel rails or such.
BTW, my 3.5 has 30K+ miles on it and has yet to consume any oil at all. (knocks on fake wood)
Good luck man, I like the Gen 3 Maxima the most!
__________________
1997 Maxima SE
Pearl White/Black Leather
2004 VQ35DE Full Swap
2004 4AT Full Swap
2004 Infiniti I35 Leather Swap
2004 I35 Cluster Swap
Gen 5.5 Brakes
Completely stock looking
(快速的汽车)
made in china is offline   Reply With Quote
Old 10-29-2008, 07:51 AM   #94
NWP Engineering.com
Aaron92SE's Avatar
I don't think I will need any aftermarket seals. But thanks.
Thanks. I have a Nismo AFPR that I hope to be able to use in order to set pressure to 51psi.
__________________
Old 10-29-2008, 03:47 PM   #95
NWP Engineering.com
Aaron92SE's Avatar
I did some further leak down testing today.
Here are the average results with over 5 tests per cylinder:
1: 16%
3: 15%
5: 16%
2: 15%
4: 16%
6: 16%
I'm guessing that since this engine hasn't ran in a while, that's why the first dry compression test was erratic between cylinders. But, now that I've turned this engine over so many times by hand and with the starter, the numbers have now gotten better.
Also, during the leak down test, I paid close attention to where the air was leaking out. In all cylinders, a good rush of air could be heard in the crankcase (air slipping by rings). And the same exact amount of air was coming from the intake ports, exhaust ports, and coolant housing. I could not tell any difference between any of the cylinders.
__________________
Old 10-29-2008, 07:17 PM   #96
Send a message via AIM to Gunther
clue me in - is 15% a good result?
__________________
Gunther is offline   Reply With Quote
Old 10-29-2008, 08:45 PM   #97
NWP Engineering.com
Aaron92SE's Avatar
I am mainly happy that all the cylinders are close to one another with valve and head gasket leakage that is consistent. But, 15% is doable. If it were under 10%, that would be a pretty good race motor. But, considering how most VQ35s have sub par rings, I am happy with it. Some motors can still be just fine as high as 20%. But when you start to get over that, you really need to think about a complete rebuild.
__________________
Old 10-29-2008, 08:49 PM   #98
The Dirty Pearl
pmohr's Avatar
Ah, so I guess my engine being at ~95% leakdown could contribute to my loss of power?
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 10-29-2008, 08:51 PM   #99
NWP Engineering.com
Aaron92SE's Avatar
Haha Yeah, I think so. 95% usually means that your rings are gone or the valves are completely stuck open or the cylinder isn't at TDC.
__________________
Old 10-29-2008, 08:53 PM   #100
The Dirty Pearl
pmohr's Avatar
Rings? Oh...I was wondering why they gave me so many cool bracelets with my rebuild kit.
__________________
Old 10-31-2008, 04:24 PM   #101
NWP Engineering.com
Aaron92SE's Avatar
Finally got it on the stand! Now it's time to have fun!
__________________
Old 10-31-2008, 07:29 PM   #102
hadman's Avatar
Send a message via AIM to hadman
Shweet. Make sure you rotate it every 15 minutes to ensure even cooking.
Your toys make me jealous.
__________________
'hadman' on Maxima.org ~ 'MarkhamMax' on TorontoMaxima.com
4DSC Decals ARE BACK!! - see thread for details: --> 4DSC DECAL
Timeslip
hadman is offline   Reply With Quote
Old 10-31-2008, 11:25 PM   #103
Bear > Wookie
DrunkieTheBear's Avatar
Send a message via AIM to DrunkieTheBear
That engine is well taken care of and definitely in great condition damn! Nice pick up.
__________________
2004 Pontiac Grand Prix GTP Comp G
|3.5" Intake Bpi/R2C|Ram Air|3.4" Pulley|180* T-stat|Headers|Corvette Brakes|SSC Lowering|KYB|LEDs everywhere|GXP parts|SE Parts|
Want a Plug and Play Harness for your Emanage Ult/Blue? CLICK HERE!
Quote:
Originally Posted by MOHFpro90 View Post
Thank you Dave. I love you Dave.
Quote:
Originally Posted by bigleman View Post
...so i had to get towed out of a ditch last night...
DrunkieTheBear is offline   Reply With Quote
Old 11-01-2008, 06:43 AM   #104
Shift_Broken Tranny
hey were you planning on cams
__________________
My Cardomain _ _Maxima runs 13.4@109
Dyno:? whp & ? wtq
Nitrous PB: 13.4@110mph
All Motor PB: 14.0@99mph
3280lb with driver, full trim, rims, spare, jack, fluids, etc & notorized proof
t6378tp is offline   Reply With Quote
Old 11-01-2008, 07:08 AM   #105
HandyMan
SurraTT's Avatar
Send a message via AIM to SurraTT
FRAM
FTMFL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
__________________
336-338-3570
HAVE:
2002 SE 6Speed KH3
2002 SE Auto
HAD:
1985300ZX5Speed
1992SEAutoAztecRed
1992SE5SpeedKH3
1990SE5SpeedPartscar
1987SE5Speed Started it all!
SurraTT is offline   Reply With Quote
Old 11-01-2008, 09:06 AM   #106
STFU n00b!
The VE I built had <1% in each cylinder at 30k miles.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 11-03-2008, 08:55 AM   #107
NWP Engineering.com
Aaron92SE's Avatar
Quote:
So far, it's clean on the inside. I'll know more once I remove the timing cover and heads.
Quote:
Oh yeah.
FRAM
I didn't do it.
Quote:
Did you use Total Seal rings? Or just stock replacements? Did you bore or hone the cylinders?
__________________
Old 11-03-2008, 05:50 PM   #108
STFU n00b!
I used whatever rings that came with the 11:1 JE pistons I bought. I think I remmeber hearing Total Seal during my discussions with the machine shop. I just told them to put something in there they'd be willing to stick their name on. He said he'd use good stuff.
When the rings didn't seat after 10k miles, I called the machine shop back and talked to them. He mentioned they were Chrome rings and it's not uncommon for them not to seat due to the nissan cyl walls being so hard as well as the rings. neither of them wear enough to seat properly. DOH.
(I had them build the bottom end since I didn't have the time, tools, or experience to deal with mic'ing the crank and bearings and etc. Plus I had them balance the bottom end, so no point in me building it for the $100 they charged to assemble the shortblock.)
fortunately the guy said he'd stand behind it too. bring the engine back in anytime and they'd go through it and install new rings for only the parts cost. sweeeet.
Cyls were bored 0.5mm over. (87.5mm)
__________________
Old 11-03-2008, 05:59 PM   #109
NWP Engineering.com
Aaron92SE's Avatar
Some of the Total Seal rings are chrome. It definitely sounds like you went with the best (Total Seal). It's really the only way you can get the leak down numbers you were getting. If you went with new OEM rings with a fresh over bored block, you'd probably still get 5+%.
It's quite a good setup you have there!
__________________
Old 11-03-2008, 06:50 PM   #110
Send a message via ICQ to Lordrandall Send a message via AIM to Lordrandall Send a message via Yahoo to Lordrandall
Good luck Aaron.
__________________
92 SE 5-speed - 96 S14 SE 5-speed
Lordrandall is offline   Reply With Quote
Old 11-04-2008, 07:39 PM   #111
damn took me a while to read all this useful information that all you guys have posted about Aarons motor swap. Aaron, i hope you finish this damn swap already so that the 3rd gen community can finally leave the 160+hp range and step up into the 200+ N/A. i think i will just pick up a 3.5 along with all the parts that you will use for yours and do the same to my 3rd gen. Aaron finish this swap buddy and good luck.
__________________
www.cardomain.com/id/green_max
'93 GXE 5-spd - sporting JDM power fold heated mirrors.
'97 SE Auto - finally running.
'08 BMW 335i Twin Turbo 6-speed - d/d temp.
GRNMAXDMON is offline   Reply With Quote
Old 11-04-2008, 08:09 PM   #112
Send a message via AIM to pezking4 Send a message via Yahoo to pezking4
Amazing Aaron. Subscribed!
The Raleigh guys haven't been out to the track in years, but I'll keep up with your progress and maybe we can meet up in the future.
I've got to get my 328i running again
Jon (JMAXIMA) now has an Infiniti I35
Will (KINGMAX) wrecked his 97 maxima, and recently got a 99 maxima
and Brandon (Ladeesman) now has a 04 Audi S4
__________________
1992 SE 5 speed
- sold
1997 BMW 328i - in progress
2001 Audi A4 1.8T - daily
pezking4 is offline   Reply With Quote
Old 11-05-2008, 09:30 AM   #113
NWP Engineering.com
Aaron92SE's Avatar
Quote:
Originally Posted by Lordrandall View Post
Good luck Aaron.
Thanks.
Quote:
I'm stepping up from the 170whp VE to 260whp 3.5!
Awesome! Thanks for the update. I hope we can do another track meet next Spring.
__________________
Old 11-05-2008, 07:17 PM   #114
Thanks.
yes, please step up with this cuz today i found out my friend who use to work for my local Nissan dealer has a '03 3.5L VQ from an I30 with less 60K miles on it willing to sell it to me for $400. what do you think? i think will get it off of him so i can start my build along with yours.
__________________
Old 11-05-2008, 07:36 PM   #115
The Dirty Pearl
pmohr's Avatar
Orly?
__________________
Old 11-05-2008, 09:17 PM   #116
NWP Engineering.com
Aaron92SE's Avatar
That engine will work great. Does the engine run right now? Can you warm it up and test compression before you purchase it? If not, is he trustworthy and can vouch for where the engine has been? Can he guarantee it hasn't been run without oil or anything?
But, if you are really interested in doing the swap, I will be more than happy to help you out. Also, I will be posting as much information as I can in this thread about the details of my swap.
__________________
Old 11-06-2008, 04:45 PM   #117
I love lamp.
maximase86's Avatar
Send a message via MSN to maximase86
Subscribed. A NW guy and myself were thinking of fitting a VQ35 to a 2nd or 3rd gen just for the fun of it. Be good to see what you did for a potential future project.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
04 Sentra SE-R Spec-V - Super Black/Silver-Black Cloth
Northwest Nissan & Infiniti
maximase86 is offline   Reply With Quote
Old 11-06-2008, 06:54 PM   #118
well, he told me that he has had the engine for almost a year now and that it came out of an '03 I30 that was involved in a crash. he was gonna swap it into his 240 but i guess he just bailed out and doesn't want to do it anymore. so he offered to sell me the engine for $400 and for me to swap it into my 3rd gen. but i will get more info from him about it before the accident to that I30. and trust me, i really want to swap it into my car.
__________________
Old 11-06-2008, 07:06 PM   #119
NWP Engineering.com
Aaron92SE's Avatar
Run a carfax check. He should be able to find the VIN on that 03 I30. Maybe the junkyard he got it from still has it on file. But it's nice to be able to confirm mileage of the engine.
__________________
Old 11-06-2008, 07:17 PM   #120
NWP Engineering.com
Aaron92SE's Avatar
I finally got this dang crank pulley off!!
Since the engine is on the stand, I was scared of tipping the entire thing over with the cheater bar. I first locked the engine with the "suitable tool" (cough, screwdriver) in the driveplate teeth. It was tough holding the screwdriver while lifting on the huge cheater bar. And my impact wrench wasn't nearly strong enough. So I borrowed a friend's 675 ft-lbs max impact wrench and it didn't even phase it! And I've been soaking this thing in PB Blaster for the past 36 hours.
And I was about to take out the torch to heat it up, but just a little while ago, KRRZ350 gave me an idea to lock the engine in place. On the 3.5, there is a stud that sticks out of the timing cover used for the lowest nut on the front engine mount. Simply wrap a belt around the crank pulley and fold it under itself. The stud will keep the engine from turning. This pic is for illustrative purposes only. It's best to wrap the belt around the inside rib since it's closer to the stud. Then put a 3 foot cheater bar on that crank pulley bolt and that's it!
Thanks Kevin for the idea!
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
