Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-13-2009, 01:07 AM   #1001
Send a message via AIM to TurboS13Hatch
Aaron..
So, using a 2002, manual trans ECU (3L), will eliminate the CAN code, and allow the cruise to work?
I've been fighting with this in the Spec V chassis for a while, and never could figure out why the cruise wouldn't work.. even though it was all properly wired up.
Travis
TurboS13Hatch is offline   Reply With Quote
Old 07-13-2009, 06:28 AM   #1002
Jime's Avatar
Quote:
Originally Posted by TurboS13Hatch View Post
Aaron..
Travis
Works for me. I switched from an auto ecu to manual for another reason (throttle opening on launch) but it fixed the cruise.
__________________
0-60 MPH = 2.38 sec
Jime is offline   Reply With Quote
Old 07-13-2009, 11:23 AM   #1003
Call me Wookiee Goldberg
CapedCadaver's Avatar
Quote:
m/t ecu is gentler to open the throttle than a/t ECU on part throttle launching? or more abrupt? On the 1G Probe/MX-6 the a/t and m/t versions actually had different TB's.. with a dual-asymmetrical butterfly design. On a/t, the big one opened first then the little one... other way around for m/t.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 07-13-2009, 01:12 PM   #1004
NWP Engineering.com
Aaron92SE's Avatar
Send a message via AIM to Aaron92SE Send a message via MSN to Aaron92SE Send a message via Yahoo to Aaron92SE
Aaron..
Travis
Yeah, I'm pretty sure that's correct. I know the cruise control needs proper CAN function to operate. And without the correct automatic TCM sending the right signals to and from the ECU, then you'll have CAN codes and it will prevent the cruise from working. It makes perfect sense too that Jime mentioned he needs to lock up his torque converter in order for his 6spd ECU cruise control to work. For the cruise to work with an automatic, the TCM needs to be there and working properly in and out of converter lock up.
Did the 6spd ECU solve your throttle opening issue? I thought the ASCD single handily fixed that problem for you. I figured you got the 6spd ECU thinking it would fix your throttle opening problem, but didn't.
I will end up getting the ECU to fix my cruise issue. I still have not noticed a throttle opening issue though with my Auterra software. I did notice a slight hesitation in throttle opening speed sometimes, but unplugging the ASCD brake switch didn't do anything. I will experiment more with this when I get the 6spd ECU installed in my car. The ASCD brake switch thing may work only on the 6spd ECU. We'll see.
__________________
NWP Engineering Phenolic Thermal Intake Spacers
10hp and 12ft-lb gain & 40°F temp drop on the VQ35DE
Engine Torque Link Bracing Kits now available for the 1995-2003 Maxima!
The first VQ35DE Full ECU engine swap in a 3rd gen Maxima
92 Maxima SE Auto VQ35DE Swap
VE Auto PB: 12.8 @ 104mph w/ 75 shot
VQ35 PB: 12.76 @ 108 mph ALL MOTOR
Winner of the MAXUS 09 NA Maxima Unlimited class!
Aaron92SE is offline   Reply With Quote
Old 07-14-2009, 12:26 AM   #1005
Interesting..
I have the CAN code, which I know that the 6spd ECU will eliminate, but, I have a ASCD switch code as well.. I wonder if the two go hand in hand..?
I can turn the cruise on right now, and it lights up on the dash, but, the "set" light blinks on/off.. I'm interested to see if this ECU fixes my problem.
Travis
Old 07-14-2009, 06:04 AM   #1006
Jime's Avatar
Interesting..
Travis
Aaron the 6 spd ECU did not change the throttle problem, that was before i discovered the ASCD fix.
Travis the 6 spd ECU will fix that, its exactly the way mine was, it would just blink on and off and not set.
__________________
0-60 MPH = 2.38 sec
Old 07-14-2009, 09:41 AM   #1007
NWP Engineering.com
Aaron92SE's Avatar
Interesting..
Travis
I have the same EXACT problem. Mine just blinks and I have an ASCD code most of the time. I will clear the codes and it will come back when I try to set the cruise control. The SET light blinks rapidly. That's b/c we have CAN errors that have to be solved first. A 6spd ECU won't have that problem.
Gotcha. Thanks.
__________________
Old 07-14-2009, 12:50 PM   #1008
Sweet.. I should have cruise, and a codeless VQ swap this week!
Old 07-14-2009, 01:47 PM   #1009
NWP Engineering.com
Aaron92SE's Avatar
Let me know how it goes. And you probably already know this, but just in case, the dealership is needed in order to match the new ECU to your NATS.
__________________
Old 07-16-2009, 09:11 AM   #1010
Not when you own a Conuslt II and NATS card..
Old 07-16-2009, 09:49 AM   #1011
RIP Kevin007
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
Aaron when will the nitrous be going on?
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The 3.5 Swap 15.508@90mph 60' 2.3 AUTO (Bad KS and stock catback) 210whp, 213wtq
The Dark Phoenix 13.402@102mph 60' 1.9 AUTO 257 RWHP 3280lb w/driver
Fear me.
My VQ35 Swap Progress Thread Now Complete!
ajcool2 is online now   Reply With Quote
Old 07-16-2009, 11:52 AM   #1012
NWP Engineering.com
Aaron92SE's Avatar
Crap man! That's sweet! Where are you located?
Quote:
I'd like to see what this car can do All Motor before I start messing around with nitrous. I probably won't put the bottle and a WOT TPS switch in my car until early next year at least.
__________________
Old 07-16-2009, 06:13 PM   #1013
I'm in South Louisiana..
Old 07-31-2009, 02:35 AM   #1014
There's never a day when something's not on sale
Send a message via AIM to blackmaxx96
Aaron!
So I start visiting the forums again and I see your company doing well and you doing a phenomenal project... way to go dude!
Once I get some money I may be coming to you for some spacers for my 5.5 I'm picking up this weekend!
__________________
"If you're not selling something then somethings not right... You're always selling something."
blackmaxx96 is offline   Reply With Quote
Old 08-05-2009, 09:58 AM   #1015
NWP Engineering.com
Aaron92SE's Avatar
Awesome! Thanks man. Good to hear from you.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
