Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-20-2008, 09:28 AM   #41
Super Moderator
Send a message via AIM to nismology
Quote:
Originally Posted by CapedCadaver View Post
got a question about the variable timing and the fact that you're probably putting in more aggressive cams..... are you going to have to totally re-map the variable timing points? cuz i guess the stock ECU's valve timing maps are "optimized" for the stock cam grind... whereas putting in different cams may throw that off a little bit
It's not absolutely necessary to re-do the cam timing maps for aftermarket camshafts to see a gain but it does help.
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
nismology is offline   Reply With Quote
Old 10-20-2008, 10:10 AM   #42
Call me Wookiee Goldberg
CapedCadaver's Avatar
Quote:
yeah, i figured it would still be in the ballpark, just not optimized. but given the balls-to-the-wall nature of Aaron's mods (and this 3.5 swap is one hell of a mod)... i wouldn't expect anything less of him.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 10-21-2008, 03:11 AM   #43
UnPr3d!cT@bL3 M@X !!!
JonBlz's Avatar
Send a message via AIM to JonBlz
wow this is gonna be amazing i cant wait til this is finished buddy
__________________
Y0u kNoW Wh@T !t !$ !!!!! Money/Cash
^^R.I.P to my 99 maxima in Jan09
came back with an 02 maxima SE 6 spd nov 09
JonBlz is offline   Reply With Quote
Old 10-21-2008, 06:14 PM   #44
Jime's Avatar
Good stuff Aaron, looks like you got it well in hand though. The wiring isn't hard just time consuming like installing cams etc.
If you were in Fla this winter I would give you a hand, we are going down for another 3 months in Jan.
The 3.5 is an awesome engine and after having 3 of them I still haven't had one that burns oil even though I wind up to 7k+, so I wouldn't worry about it. My last compression test a couple of weeks ago was 165 psi all cyls so its not necessary to have 200 psi, what is more important is the difference between cyls. Having a built engine and trans is not necessary to go fast.
__________________
0-60 MPH = 2.38 sec
Jime is offline   Reply With Quote
Old 10-21-2008, 08:21 PM   #45
NWP Engineering.com
Aaron92SE's Avatar
Send a message via AIM to Aaron92SE Send a message via MSN to Aaron92SE Send a message via Yahoo to Aaron92SE
Thanks Jim. It sounds like you know what you are talking about.
Knowing that you got 165psi is nice. That is considered in-spec in the FSM. I hope to bench test compression tomorrow or Thursday when my 4th gen starter arrives! I was unable to mount the VE starter to the 4th gen torque converter housing.
BTW, the CPS didn't pose a problem with my converter housing. I think it came off a 98 Maxima. There was already a section cut out for it.
Everybody says rings are the problem for losing oil. But there doesn't seem to be a fix for it other than going with a Total Seal type ring. I just don't want to lose more than a half quart every 3K miles and I'll be fine. My VE with 203K miles lost about 1 quart every 3K miles. So I can live with that as long as it doesn't kill my HP.
__________________
NWP Engineering Phenolic Thermal Intake Spacers
10hp and 12ft-lb gain & 40°F temp drop on the VQ35DE
Engine Torque Link Bracing Kits now available for the 1995-2003 Maxima!
The first VQ35DE Full ECU engine swap in a 3rd gen Maxima
92 Maxima SE Auto VQ35DE Swap
VE Auto PB: 12.8 @ 104mph w/ 75 shot
VQ35 PB: 12.76 @ 108 mph ALL MOTOR
Winner of the MAXUS 09 NA Maxima Unlimited class!
Aaron92SE is offline   Reply With Quote
Old 10-24-2008, 08:18 AM   #46
NWP Engineering.com
Aaron92SE's Avatar
I just got my hands on a 5.5 gen auto starter, LH engine mount bracket, and bolts for the tranny. The bolt size for the VQ is bigger than on the VE. And the correct size bolts do not exist on my VE parts car. So I had to find them elsewhere. Thanks to KRRZ350!
Oh well, I'm set now and hope to test compression soon.
__________________
Old 10-24-2008, 08:35 AM   #47
Send a message via AIM to 95BLKMAX
aaron that starter looks like its seen better days.... under a very salty ocean!
__________________
Guys I need money to recover from my recent engine build (it wasnt by choice LOL). Im selling a Holset turbo if you are interested
95BLKMAX is offline   Reply With Quote
Old 10-24-2008, 08:57 AM   #48
NWP Engineering.com
Aaron92SE's Avatar
Quote:
Yeah, it works, but hasn't been load tested yet. It's been sitting outside and should only have about 30K miles on it. But I got a ripping good deal on it, so it was worth it.
__________________
Old 10-24-2008, 02:16 PM   #49
HandyMan
SurraTT's Avatar
Send a message via AIM to SurraTT
like $5 i hope
damm
the bindix does look bran new tho!!!
its whats inside that counts.... i guess
__________________
336-338-3570
HAVE:
2002 SE 6Speed KH3
2002 SE Auto
HAD:
1985300ZX5Speed
1992SEAutoAztecRed
1992SE5SpeedKH3
1990SE5SpeedPartscar
1987SE5Speed Started it all!
SurraTT is offline   Reply With Quote
Old 10-25-2008, 11:19 AM   #50
NWP Engineering.com
Aaron92SE's Avatar
Today, I got a chance to finally test compression on this new engine.
Due to a bad valve gasket, there was a ton of oil on the spark plug #5. I bet it was somewhere around 3 or 4 cap fulls of oil. (The cheap oil caps, not the large caps on the Mobile 1 bottles).
I probably should have tried to remove the oil before removing the spark plug, but I didn't.
The rest of the cylinders looked clean:
Here are the numbers I got:
#2: 172
#4: 173
#6: 171
#1: 155 (170 after adding 1/2 cap oil)
#3: 155 (170 after adding 1/2 cap oil)
#5: 190 (had lots of oil in it)
So I'm guessing the only cylinders I need to worry about are #1 and #3. I bet #5 would have gotten around 170-175 if it wasn't for all that oil being in there reducing cylinder volume. But, #1 and #3 may be a bad head gasket since they are next to each other. But I added a 1/2 cap full of dino 10w30 oil and it raised the compression from 155 to 170 in both cylinders.
Do you think the rings are bad in those cylinders? More so than the rest of the rings? I've only put oil in #3 and 5. I haven't added oil to the LH bank (2,4,6).
And I could only get this engine to spin over about 150-170rpm and the FSM says it needs 300rpm. I'm still charging the battery, but it seems to be fully charged.
Anyway, the most important thing is whether I should still remove the heads to inspect everything or should I just return it? I don't want to have to replace the rings in this engine if I don't absolutely have to. If anybody has any suggestions or thoughts, please post. Thanks.
__________________
Old 10-25-2008, 04:54 PM   #51
Send a message via AIM to wirelessdude04 Send a message via Yahoo to wirelessdude04
Quote:
Originally Posted by accordingtou View Post
Subscribed
xx2 good luck
__________________
Under Major Overhaul
Team All Out Nissan: President
Visit us @ teamalloutnissan.com
wirelessdude04 is offline   Reply With Quote
Old 10-25-2008, 04:54 PM   #52
You can't friend yourself
Kevlo911's Avatar
I would do HR pistons and rings
Isn't the rule to be with 20 of eachother?
__________________
97 Pearl White Max GLE
I has car
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline   Reply With Quote
Old 10-25-2008, 05:16 PM   #53
NWP Engineering.com
Aaron92SE's Avatar
The book says 14psi difference max. But this is a completely cold engine. So results are going to be somewhat inaccurate. That's why I am hoping someone can chime in if they've had experience doing a cold compression test.
The biggest reason I don't want to mess with rings is b/c then I'd have to spend a lot more money on prepping the block and honing or boring it over so the new rings seat perfectly. Plus, it's a lot more work to remove the crankshaft and pistons. I'm hoping that the cylinder difference is just from the inaccuracy of doing it on a cold engine. The engine hasn't turned over since sometime in July 08 probably.
__________________
Old 10-25-2008, 08:20 PM   #54
Helicopters! Money!!!
Weimar Ben's Avatar
Then you're extremely lucky. I have 31k total on my motor and it smokes on WOT and on startup. Burns about 1qt/500 miles. I used to have compression of about 200psi. I now average 175psi in all cylinders. My plan is to put in the HR pistons/rings in soon.
Quote:
Originally Posted by Aaron92SE
"Plus, it's a lot more work to remove the crankshaft and pistons."
And then you get pi##ed off after having done all the work just to have a smoking car and have to remove the engine to put in new pistons/rings.
Weimar Ben is offline   Reply With Quote
Old 10-25-2008, 08:43 PM   #55
NWP Engineering.com
Aaron92SE's Avatar
Here are my latest compression test results after letting the engine sit for about 8 hours while the battery was on the trickle charger.
Keep in mind that #5 got a lot of oil right from the get go. #1 and #3 got a 1/2 cap full already. And #2, #4, and #6 haven't got any oil so far.
2: 162
4: 175
6: 175
1: 182
3: 178
5: 192
So the results are definitely inconsistent from my afternoon test. Similar, but still inconsistent. Here is the average test results from this afternoon:
#2: 172 (dry)
#4: 173 (dry)
#6: 171 (dry)
#1: 155 dry (170 after adding 1/2 cap oil)
#3: 155 dry (170 after adding 1/2 cap oil)
#5: 190 wet (had lots of oil in it)
So, I figured I'd put an entire cap full of oil in the LH bank to level the playing field with #5, so to speak. And I also put another 1/2 cap full in the #1 and #3 cylinders to try to match them to the LH. And #5 already has plenty of oil in it, so I put a few drops just to wet it a tiny bit.
Here are the results after doing that:
2: 190 (1 cap total)
4: 196 (1 cap total)
6: 188 (1 cap total)
1: 193 (1/2 cap added to make 1 cap total)
3: 188 (1/2 cap added to make 1 cap total)
5: 198 (few drops added since it already has 3-4 caps in it)
Now these numbers make me feel a whole lot better. After doing lots more research on cold compression tests, I have come to the conclusion that the results could vary a lot between cylinders. But, there is a lot of contradicting information about cold compression tests. Some say that is the best and most accurate method, while the majority (and FSM) say a warm engine is best.
One person did a cold compression test on his BMW engine that sat for several months. The cylinders varied much more than mine. But when he got it running and tested compression again with a warm engine, all his cylinders were within 10 psi.
__________________
Old 10-25-2008, 08:46 PM   #56
NWP Engineering.com
Aaron92SE's Avatar
Quote:
Exactly! I think I may just try my luck with this engine and put it in the car.
__________________
Old 10-25-2008, 09:44 PM   #57
Shift_Broken Tranny
ok I asked a old skool muscle car buddy of mine and he said warm and this is why
when the engine is warm the rings will expand also with other parts of the engine and will change your readings
his car has a sb 327 that was setup to read around 12/1 cr cold and 13/1 at warm and this was done by playing with ring gap and expansion rates
I can not give you any info about my motor cause I did not even bother cause when I torn into the motor everything looked fine and I only had 3 days to get my car back on the road so I could go to work
__________________
My Cardomain _ _Maxima runs 13.4@109
Dyno:? whp & ? wtq
Nitrous PB: 13.4@110mph
All Motor PB: 14.0@99mph
3280lb with driver, full trim, rims, spare, jack, fluids, etc & notorized proof
t6378tp is offline   Reply With Quote
Old 10-25-2008, 09:54 PM   #58
Shift_Broken Tranny
Hey I was just thinking this maybe a good time to check bearings, it would be one less thing to worry about
__________________
Dyno:? whp & ? wtq
Old 10-25-2008, 11:26 PM   #59
well aaron, i know you said you only had worries about 1 and 3... but you're just gonna re-ring all 6 anyways aren't you? as well as new headgaskets? or you're only doing what you have to to it?
__________________
Old 10-25-2008, 11:43 PM   #60
Send a message via AIM to Tippy Toes Send a message via Yahoo to Tippy Toes Send a message via Skype™ to Tippy Toes
looking good so far aaron. Any chance your putting in some nice spacers?
oh yeh...I'd like to run mid 12s //all motor\\. But it all depends on how this engine build goes.
what about some nitrous? or is that not an option with this build...?
Tippy Toes is offline   Reply With Quote
Old 10-26-2008, 12:35 AM   #61
Shift_Broken Tranny
yeah right I am willing to be this motor will see nitrous oneday
I am just wondering if he is going to make a tb spacer that will have a spot for well maybe a nitrous nozzle
__________________
Dyno:? whp & ? wtq
Old 10-26-2008, 06:52 AM   #62
Hi Aaron, piston ring are not that expensive I would replace those while the engine is open, I would hate to see you remove the engine in a month or so, after all that hard work, trust me been there done that.
Keep up the good work, that car is going to be a real beast with the 3.5
AA
__________________
2K1 AE-SE - Sterling Mist
2004 BMW X5 4.4i
doublea is online now   Reply With Quote
Old 10-26-2008, 07:33 AM   #63
eng92's Avatar
I agree with doublea completely.
I opened up my VQ35 swap motor (02 w/ 30K) after it failed a leakdown test miserably.
The walls were all in good shape, so I just yanked the pistons and installed new rings.
It also gave me a chance to clean up the heads, lap the valves and do a little bit of porting.
It is now 2-1/2 years and 24K (not winter driven) later and it does not burn any oil whatsoever.
eng92 is offline   Reply With Quote
Old 10-26-2008, 08:22 AM   #64
HandyMan
SurraTT's Avatar
i know your getting new valve covers!!! and gaskets ! right? if not ill
Just got my new valve covers (pic)
save ya some $ there !
__________________
336-338-3570
HAVE:
2002 SE 6Speed KH3
2002 SE Auto
HAD:
1985300ZX5Speed
1992SEAutoAztecRed
1992SE5SpeedKH3
Old 10-26-2008, 09:47 AM   #65
if you are interested in replaceing the internals i got some 350z pistons and rods i won't mind slanging your direction!
also are you going to convert to return fuel? if so it's actually simpler than people make it out to be. You just need to get another fuel inlet damper( i think thats what nissan calls it) the one that has a hose connections, and a FPR, and it gets pretty straight forward from there.
irax is offline   Reply With Quote
Old 10-26-2008, 10:32 AM   #66
HandyMan
SurraTT's Avatar
hmm thats a good point, the fuel system
i think u will have to convert to a return system if u use anything other than a 3.5 specific pump.
so im assumming ur gonna use the stock tank, and fuel system form the 3rd gen???
__________________
336-338-3570
HAVE:
2002 SE 6Speed KH3
2002 SE Auto
HAD:
1985300ZX5Speed
1992SEAutoAztecRed
1992SE5SpeedKH3
Old 10-26-2008, 02:19 PM   #67
NWP Engineering.com
Aaron92SE's Avatar
Quote:
I will.
I wasn't planning on replacing the rings or pulling the crankshaft. I may do a leak down to see what happens. If it's out of spec, I guess I'll just finish the rebuild and replace the rings.
Of course intake spacers will be installed. And of course nitrous will be sprayed. Just not right away. I'm sure I'll have some All Motor fun in the beginning.
AA
I'm more concerned with the new rings sealing properly to the 50K mile old cylinder walls. I've heard a lot of stories of people burning oil when all they did was rering it and not overbore the cylinders.
So with the new rings, you passed the compression and leak down test with flying colors? Did you hone the block or bore it when you did the rings?
Of course.
Not sure quite yet about the fuel system.
Yes, I'll stick with the stock VE fuel pump.
__________________
Old 10-26-2008, 02:24 PM   #68
HandyMan
SurraTT's Avatar
what about using the vq30 fuel rail. its a return system right?
i havent looked at injectors at so for all i know vq30 fuel rail will plug n play wit vq35, thus having a return system.
which for the ve fuel pump im 99% sure u will have to convert to return system
__________________
336-338-3570
HAVE:
2002 SE 6Speed KH3
2002 SE Auto
HAD:
1985300ZX5Speed
1992SEAutoAztecRed
1992SE5SpeedKH3
Old 10-26-2008, 02:44 PM   #69
The Dirty Pearl
pmohr's Avatar
Yes, VQ30 is a return style setup. The rail won't work with the VQ35 LIM, though. So to use the VQ30 fuel rail, you'd need a VQ30 LIM, which only matches up perfectly with the Pathfinder VQ35 heads (or VQ30 heads obviously).
As has been said, it's a trivial thing to convert the VQ35 to a return style fuel setup. Many aftermarket companies make return systems for this motor.
Of course, you could always look into the 4th gen VQ35 swap threads, there are instructions there for cobbling together a return system.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 10-27-2008, 10:02 AM   #70
HandyMan
SurraTT's Avatar
makes sence, jus do what 4tg gen guys do to convert to return system!
i didnt think of that.
__________________
336-338-3570
HAVE:
2002 SE 6Speed KH3
2002 SE Auto
HAD:
1985300ZX5Speed
1992SEAutoAztecRed
1992SE5SpeedKH3
Old 10-27-2008, 10:15 AM   #71
NWP Engineering.com
Aaron92SE's Avatar
There is a lot I am going to do the same as the 4th gen guys.
__________________
Old 10-27-2008, 02:34 PM   #72
Send a message via ICQ to Torgus Send a message via AIM to Torgus Send a message via MSN to Torgus Send a message via Yahoo to Torgus Send a message via Skype™ to Torgus
good luck with the project!
Torgus is offline   Reply With Quote
Old 10-27-2008, 02:44 PM   #73
If you open the engine, checking the cylinder wall concentricity will be your no # 1 priority, with a bad block everything will happend. If the engine was run properly then the cylinder concentricity/wall, should be fine, you would only need to deglaze them, put new ring before you re-assemble, new heads gasket, HR heads bolts etc etc.
It only depend on how far you want the etc to go. Lol
__________________
2004 BMW X5 4.4i
Old 10-27-2008, 02:52 PM   #74
NWP Engineering.com
Aaron92SE's Avatar
Yeah. Whenever you replace rings without boring out the cylinder, you are only making things worse unless the rings are in really bad shape, then anything would be better. If all you do is break the glaze with a light hone and use stock rings, it will seal just that much less.
I guess my next step is to remove the heads and inspect the cylinder walls. Or do you think I should bother with a leak down test first? I can get a tester pretty cheap. But, I am not willing to spend the money on boring the cylinders right now. I'm already way over my budget because of the, "while you're in there, you might as well", mods.
__________________
Old 10-27-2008, 06:15 PM   #75
The LandShark has teeth..
grey99max's Avatar
I've been running with a bone-stock 2002 short block (except for ARP rod bolts) and I feel just fine about that...
I wire-brushed the heads and block, wire-brushed the cruddy piston tops till they were clean, and laid out the 2005 350Z three-layer head gaskets and bolted them down with 2005 OEM head bolts.
Seems to work for me - so far...
__________________
'99 GXE, Tune-by-Tape MAF mod, 3.5L w/cams, SSIM, 255Walbro,AERO FPR, VLSDauto, Edge TC, DR-mod, Shift_Fast, dual-B&M cooler, JClawbars, cryoed axles, dual-NX nitrous, dual heated15lb bottles, OBX headers, 3"Warpspeed exhaust, PLXR-300 wideband, IlluminasStrut/springs, 24.5"M&H, ProgressRSB, HawkHPS, Clarion50Wx4 head w/Alpines, Fosgate sub. Spare tire+jack,3300 lb car. 355WHP-dyno.
12.394 @113.22 ( 114.51 now) w/3.5
http://i48.photobucket.com/albums/f2...9/DSCN0527.jpg
grey99max is online now   Reply With Quote
Old 10-27-2008, 06:18 PM   #76
NWP Engineering.com
Aaron92SE's Avatar
Did you replace the rings or touch the cylinder walls?
__________________
Old 10-27-2008, 06:24 PM   #77
Shift_Broken Tranny
I know what you mean
I had to catch myself because it was quickly going from a few dollars here and there to a few hundred
you should see the tab on my truck motor ................. sorry I passed out for a second just thinking about it
__________________
Dyno:? whp & ? wtq
Old 10-27-2008, 06:26 PM   #78
grey99max's Avatar
Nope..... no reason to do that, with a 60K-mile motor....
__________________
Old 10-27-2008, 08:21 PM   #79
NWP Engineering.com
Aaron92SE's Avatar
Did you happen to test compression or do a leak down test prior to removing the heads?
I did another compression test tonight and got even more consistent readings.
2: 183
4: 185
6: 183
1: 190
3: 186
5: 188
I don't know if I'm rationalizing or not. But the numbers keep getting more level after adding that 1 cap full of oil a couple days ago. Did I just cheat or has the engine been sitting for so long that the dry compression numbers made it skewed?
If anybody else has any thoughts, please post. I am ready to either do a leak down test or remove the heads so I can inspect these cylinder walls.
__________________
Old 10-27-2008, 08:50 PM   #80
eng92's Avatar
I did not rehone and I do not burn any oil. The factory x-hatch hone pattern was still clearly visible on the walls so I just left them.
My leakdown numbers went from about 40% to about 5% on a cold engine. Originally I was leaking air past the rings and through a few of the exhaust valves.
If you are pulling the heads anyways then don't bother doing a leakdown.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
