Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-12-2008, 10:55 AM   #81
RIP Kevin007
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
Quote:
Originally Posted by t6378tp View Post
put the bolt in the crank and turn it
Ok will I have to redo all the timing stuff?
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The 3.5 Swap 15.508@90mph 60' 2.3 AUTO (Bad KS and stock catback) 210whp, 213wtq
The Dark Phoenix 13.402@102mph 60' 1.9 AUTO 257 RWHP 3280lb w/driver
Fear me.
My VQ35 Swap Progress Thread Now Complete!
ajcool2 is offline   Reply With Quote
Old 10-12-2008, 12:21 PM   #82
Shift_Broken Tranny
Well I had help when putting the main chain on wanted to make sure I did not screw it up, well Darryl put it on but it was not as hard as I thought it would be.
I ran into the same problem with the motor not being at tdc so we line up the secondary chains put water pump guides on. primed the tensior compressed it put the pin in to hold it in place, lined up the main chain on the cam sprockets and turned the crank to tdc so it lined up with the colored chain link
step back made sure all the colored links were lined up and the secondary chain were still lined up with pulled the pin from the tensior check everything again
not really sure how to explain it but there are these little tabs you can use as referance marks to make sure the crank and cam sprockets are in the correct location turn the motor by hand a few times and check everything again
I am sure someone else can explain alot better than me so maybe someone will chime in
__________________
My Cardomain _ _Maxima runs 13.4@109
Dyno:? whp & ? wtq
Nitrous PB: 13.4@110mph
All Motor PB: 14.0@99mph
3280lb with driver, full trim, rims, spare, jack, fluids, etc & notorized proof
t6378tp is offline   Reply With Quote
Old 10-12-2008, 01:43 PM   #83
Gut it like a fish
accordingtou's Avatar
As stated above....
There are tabs on the rear timing cover to assits in alignment
Notice the location of the arrows & discolored timing chain links.(they both point to the tabs on the rear timing cover).
Left side
Right side
There is a line on the oil pump @ about 10 oclock.In order for the #1 piston to be @ TDC,the woodruf key on the crank should be aligned with the line on the oil pump
Align (timing marks)
Prime/release (tensioner)
Rotate (assembly)
Be sure to post start up & WOT flyby vid
__________________
Stock & performance parts F/S@ PANTRY sale.lol Philly Pa
accordingtou is offline   Reply With Quote
Old 10-12-2008, 01:50 PM   #84
Gut it like a fish
Side note I just noticed the 3.5 timing chain tensioner..
I didnt know you could use it with te 3.0 equipment?
__________________
Old 10-12-2008, 02:35 PM   #85
Shift_Broken Tranny
Hey ^ post my startup on youtube so I can link it to my cardomain
__________________
Dyno:? whp & ? wtq
Old 10-12-2008, 02:57 PM   #86
Beater
Tatanko's Avatar
Send a message via AIM to Tatanko
Good work so far, AJ. I may just have to have you build me one
__________________
SHIFT_obsession
Tatanko's Maxima Site & VQ35DE.com
Tatanko is offline   Reply With Quote
Old 10-12-2008, 07:04 PM   #87
we're sharing the same thoughts
__________________
SHIFT_LOTS OF OIL
DCMAX current mods- 4th gen intake, 2.5" custom catback, NWP block off plate, 00SE tailight w/overlays, Rewired fog lights, Eyelid, JIC coilovers, FSTB, 3.0 OBX headers, SSIM...
95 White GXE- 15.1 sold... now 14.9 (car next to me in sig)
00 Sterling GXE- 15.0 (ebay intake, exhaust) my next love and beauty (crashed n sold)
02 Sterling GLE- 13.84@100 2.1'
Grand_hustle17 is offline   Reply With Quote
Old 10-13-2008, 03:58 PM   #88
RIP Kevin007
ajcool2's Avatar
Ok thanks for the help guys hopefully I can get a chance to work on it tonight. I'll try to get a pic of how it is currently and after I align it the way you guys say. I'll be glad when this part is over haha.
Since I've put most of the timing stuff on and and taken it off about 4 times so far it doesnt seem to bad. Especially once you start understanding how things work and what everything is. I can actually read those 3.5 swap thread and know what they are talking about lol. Maxsapphire is at a point that when I ask for a certain part she knows what it is which is cool. She cant wait to take it to the track. We will definatly have vids up once everything is done, of course she'll get the first drive.
Edit: ONLY USE THE 3.0 TENSIONER
__________________
DCMAX FTW
Fear me.
Old 10-13-2008, 04:12 PM   #89
Gut it like a fish
Done
Quote:
I used the 3.5 tensioner because thats what tavarish did in his writeup. I had to double check it after I put it on myself.
Maybe Ishouldnt have thrown away that tensioner.lol Good to hear though
__________________
Old 10-13-2008, 06:15 PM   #90
NWP Engineering.com
Aaron92SE's Avatar
Send a message via AIM to Aaron92SE Send a message via MSN to Aaron92SE Send a message via Yahoo to Aaron92SE
I'm definitely paying attention to this thread. Thanks for updating it every so often.
Messing with the timing components can seem scary at first, but if you have the ability to read the FSM and understand it, then it's surprisingly pretty simple. Just take your time and follow each step. Once you have everything together, turn the engine over manually several times to make sure it rotates freely.
I'm planning on going a little deeper into my engine. If I have it on the stand, I might as well do as much stuff as I can to it like seals, HGs, cams, valve springs, rod bolts, port work, etc.
I can't wait to get my progress thread started! I don't want to start it until I have an engine though. That way people will know I'm serious. I hope to buy my engine tomorrow. We'll see.
__________________
NWP Engineering Phenolic Thermal Intake Spacers
10hp and 12ft-lb gain & 40°F temp drop on the VQ35DE
Engine Torque Link Bracing Kits now available for the 1995-2003 Maxima!
The first VQ35DE Full ECU engine swap in a 3rd gen Maxima
92 Maxima SE Auto VQ35DE Swap
VE Auto PB: 12.8 @ 104mph w/ 75 shot
VQ35 PB: 12.76 @ 108 mph ALL MOTOR
Winner of the MAXUS 09 NA Maxima Unlimited class!
Aaron92SE is offline   Reply With Quote
Old 10-13-2008, 09:30 PM   #91
Send a message via AIM to SouthFlMaxTech Send a message via Yahoo to SouthFlMaxTech
I just finshed my 3.5 swap and it is great!!! put in a 2008 engine from a maxima.. had 491miles on it when I put it in.. I hooked everything up and no check engine light on does anyone know if anyone else has done a 3.5 swap and had no check engine light I have EGR and EVAP system complety hooked up.. anyways any help or questions you have ask away..
SouthFlMaxTech is offline   Reply With Quote
Old 10-13-2008, 09:36 PM   #92
RIP Kevin007
ajcool2's Avatar
Quote:
No check engine light?? Good job. You got a dream swap. I'm sure I'll be posting more questions here as I go along.
__________________
DCMAX FTW
Fear me.
Old 10-13-2008, 09:41 PM   #93
RIP Kevin007
ajcool2's Avatar
Quote:
Originally Posted by accordingtou View Post
Done
I just triple checked the picture from the writeup and its a 3.0 tensioner. I guess its a good thing I checked again. I'll edit my post to keep good info here.
__________________
DCMAX FTW
Fear me.
Old 10-13-2008, 09:43 PM   #94
RIP Kevin007
ajcool2's Avatar
I'm sure its going to be a beast once its done.
__________________
DCMAX FTW
Fear me.
Old 10-19-2008, 02:26 PM   #95
RIP Kevin007
ajcool2's Avatar
PLEASSSEEE tell me this is right.
__________________
DCMAX FTW
Fear me.
Old 10-19-2008, 06:04 PM   #96
Gut it like a fish
__________________
Old 10-19-2008, 10:23 PM   #97
Send a message via AIM to 95BLKMAX
all looks good from here sir. just be srue that you did in fact prime that primary chain tensioner with plenty oil. LAST thing you need is for there to be slack and you end up with a chain skipping a tooth at startup. Not trying to jinx it or anything [*knock on wood*] but that is a very important thing to do that will save you huge headaches down the road
__________________
Guys I need money to recover from my recent engine build (it wasnt by choice LOL). Im selling a Holset turbo if you are interested
95BLKMAX is offline   Reply With Quote
Old 10-20-2008, 05:57 PM   #98
Shift_Broken Tranny
pic's please and what did you do with the egr
did you install the 4gen egr or did you rig it up somehow
__________________
Dyno:? whp & ? wtq
Old 10-23-2008, 04:25 PM   #99
4.5 Gen & 3rd Gen
93altima's Avatar
update!?
__________________
1993 Maxima GXE 1995 Maxima GXE
As A De-K: 11/28/08 14.8 @ 93.8mph
As A 3.5: 03/13/09 14.1 @100mph
HPaddictionz
Team all out Nissan
93altima is offline   Reply With Quote
Old 10-23-2008, 04:33 PM   #100
RIP Kevin007
ajcool2's Avatar
Quote:
Originally Posted by 93altima View Post
update!?
I'll be working on it tonight. I've been working late and havent had a chance to work on it this week. I need to prime that main tensioner, put the last chain guide on and install the outer timing cover. Then put everything else back together.
__________________
DCMAX FTW
Fear me.
Old 10-27-2008, 09:12 AM   #101
RIP Kevin007
ajcool2's Avatar
The outer timing cover is on and all the timing is set. I know it took a long time to do but I wanted to make sure everything was right so I dont run into any problems later. We'll be putting everything back together during the week. My goal is to have it running before november 9th.
__________________
DCMAX FTW
Fear me.
Old 10-27-2008, 09:28 AM   #102
RIP Kevin007
ajcool2's Avatar
Also if anyone is planning the swap in the future and want pictures of anything just let me know.
__________________
DCMAX FTW
Fear me.
Old 10-27-2008, 09:53 PM   #103
looks good
vwracer1172 is offline   Reply With Quote
Old 10-28-2008, 10:38 PM   #104
VQ35 FTW
mastercater7's Avatar
In your picture of the chain tensioner, I dont see the piston pushing on the guide? Make sure that piston didn't fall out. Also, I would recommend buying a new tensioner if you can afford it. 2 months after my swap my tensioner began to go out. I really did not want to have to pull the motor again... Looking great though!
Zack
mastercater7 is offline   Reply With Quote
Old 10-29-2008, 09:05 AM   #105
Aj, never looked in this thread before now and...I bet you're glad you dont have to do this in your apt parking lot.
Nevertheless, nice job man. Really like all of the pictures! Good luck.
__________________
00VI | 5.5Gen BBK | 00 5 spokes | Kumho Ecsta SPT | Cleared Tails | FX retro | LED interior | SNOMAX's LCAs | Raxles
FS: Plug and Play E-manage Ultimate, E-manage Blue & VAFC/SAFC Harnesses
Florida Gators: (10-0) | CSU (62-3) W | Troy (56-6) W | Tenn (23-13) W | Kentucky (41-7) W | LSU (13-3) W | Arkansas (23-20) W | Miss St (29-19) W | Georgia (41-17) W | Vandy (27-3) W | SC (24-14) W | FIU | FSU
MOHFpro90 is offline   Reply With Quote
Old 10-29-2008, 09:10 AM   #106
RIP Kevin007
ajcool2's Avatar
Quote:
Zack
The piston is there its just not sticking out. Its really tight up against the guide. Would I be able to tell if a tensioner is good or bad before its all in the car? When I primed it it pushes in and comes out smoothly.
__________________
DCMAX FTW
Fear me.
Old 10-29-2008, 09:12 AM   #107
RIP Kevin007
ajcool2's Avatar
Indeed I am my friend lol. I need hurry up and finish this because it is getting really cold.
__________________
DCMAX FTW
Fear me.
Old 10-29-2008, 04:32 PM   #108
VQ35 FTW
I have never seen that. The piston is always pushing out on the guide. I would get a new one regardless. They arent very expensive.
Zack
Old 11-04-2008, 10:50 AM   #109
RIP Kevin007
ajcool2's Avatar
Got a question. Is there any reason why most people decide to shave the block instead of just rewiring the 3.5 CPS?
__________________
DCMAX FTW
Fear me.
Old 11-05-2008, 01:14 PM   #110
RIP Kevin007
ajcool2's Avatar
Zack
I turned the assembly and it did move out as I turned it around. I think I'll wait and see how it works once everything is back together.
__________________
DCMAX FTW
Fear me.
Old 11-07-2008, 06:45 AM   #111
Send a message via AIM to maxspeed88 Send a message via Yahoo to maxspeed88
yo man i need help with my swap
maxspeed88 is offline   Reply With Quote
Old 11-07-2008, 12:18 PM   #112
RIP Kevin007
ajcool2's Avatar
Quote:
What part do you need help with?
__________________
DCMAX FTW
Fear me.
Old 11-08-2008, 09:35 PM   #113
4.5 Gen & 3rd Gen
93altima's Avatar
Whats the Est. time until the start up youtube vid? lol
__________________
HPaddictionz
Team all out Nissan
Old 11-20-2008, 01:06 PM   #114
Send a message via AIM to dfownz
I'm really considering doing a partial swap into my 2000. The only parts I seem to not understand is how/what sensors are hooked up and what you need to do to stay 5spd.
Care to clarify this for me?
Also, how did you get no codes SouthFLMaxTech?????
__________________
What will I end up doing with my Maxima?
dfownz is offline   Reply With Quote
Old 11-20-2008, 02:46 PM   #115
RIP Kevin007
ajcool2's Avatar
LOL Dont know but it will be in the car by sunday.
__________________
DCMAX FTW
Fear me.
Old 11-20-2008, 03:15 PM   #116
RIP Kevin007
ajcool2's Avatar
I just printed page EL-318 and EL-319 from my FSM and highlighted the sensors I'll need to bring over from the 3.0. I'll list them and if anyone sees anything missing let me know and I'll add it here.
3.0 02 sensors
3.0 Rear 02 sensor
3.0 TPS
3.0 IACV
3.0 CPS (Phase)
3.0 Engine coolant temp sensor
3.0 MAF
3.0 IATS
3.0 Map Baro solenoid
3.0 CPS (POS)
3.0 Knock sensor
3.0 CPS (REF)
I'm actually going to use the 3.5 CPS (POS) sensor and wire it up. My question is do I still need to switch over the AT driveplate if I do this?
__________________
DCMAX FTW
Fear me.
Old 11-21-2008, 11:17 AM   #117
So all the 3.0 sensors fit on the 3.5 w/o modification? The only one you have to modify for is when using the 3.0 cps?
This seems almost too easy...
__________________
Old 11-21-2008, 11:42 AM   #118
RIP Kevin007
ajcool2's Avatar
Yup so far I've just unbolted them from the 3.0 and bolted them on the 3.5.
__________________
DCMAX FTW
Fear me.
Old 11-22-2008, 09:55 PM   #119
well its 12am sunday morning well is it in???lol
95pealmax is offline   Reply With Quote
Old 11-23-2008, 07:53 AM   #120
Shift_Broken Tranny
I reused all 3.0 sensors, but then again I used the 3.0 upper and lower pan also
__________________
Dyno:? whp & ? wtq
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
