Go Back   Maxima Forums > Advanced Performance > All Motor
Thread Tools Display Modes
Old 08-31-2008, 06:10 PM   #1
Use the Search Function!!
mtrai760's Avatar
Send a message via AIM to mtrai760
Emanage Ultimate assistance - larger injectors and MAF
I installed a EU yesterday in my 98 Maxima, and I have one issue though with fuel at idle.
Issue #1: Nevermind, figured it out. Is anyone running a Z32 MAF with the EU? I tried selecting VG30DETT for my MAF, but it will not accept it in the menu screen, it just goes back to blank (stock). Anyone have a similiar issue? <-- It uses the same MAF type as the VG30DETT already, that is why you cannot select it.
Issue #2: I'm having a problem with injector lag time with my Z32 injectors. After doing a LOT of research, I came across 2 answers for lag time on Z32 370cc injectors, .58ms, and from calling Deatsch Werks, 1.4ms. I tried both, and the issue I am having is running way to rich at idle. At .58ms, I am running at 11-12 AFR. At 1.4ms, I run at 10-11 AFR. I tried playing around with the lag time, but I want to set it correctly, not guess.
I am running 370cc Z32 injectors cleaned and balanced by Deatsch Werks. They tested between 411cc-418cc at 43.5psi. I am running stock fuel pressure (34psi). Anyone have any suggestions? I would think that the stock ECU would compensate, but the AFR is staying really rich. I do not have any adjustments programmed into the EU that should be affecting idle (or anything below 50% throttle for that matter). Do you have to set your stock injector size and lag time in the boxes for that info? I set the stock size in (260cc) but it made no difference.
Other than that, car starts and runs fine, albeit really rich. I am currently running version 2.20 on the software. We have to use the VQ30DET setting, does anyone know if this is actually using VQ30DET specs, ie a different MAF and injectors than the A32 Maxima?
Thanks for any help, I'm eager to get out and start doing some tuning runs!
__________________
98 SE - Supercharged at 10psi w/the works - VQ35 coming soon...
2k SE - Stock... pretty much
88 RX-7 - Sold
95 240sx KA-T 10psi - sold
3 4th gens.... gone....
mtrai760 is offline   Reply With Quote
Old 09-01-2008, 09:43 AM   #2
Send a message via AIM to MOHFpro90
Not sure if this is of any help, but if I recall correctly, don't you have the option of tapping or intercepting the MAF signal? Which did you do? I haven't used or seen the software/interface so I am not sure how it correlates with the option but maybe that has something to do with it?
Not sure on tha A/F issue. But just from reading what you wrote, I would say it would have to be higher to make it leaner. But I really have no idea.
Good luck man!
__________________
FOR SALE: Ksport Coilovers, VQ30DE Engine, MAF, Auto ECU, Stock Parts
00VI | 5.5Gen BBK | Axxis Ceramic | Raxles | Ksports | 00 5 spokes | AE'd | Cleared Tails | Shortram | 9007 conversion | LED interior | SNOMAX's LCAs
MOHFpro90 is offline   Reply With Quote
Old 09-01-2008, 09:46 AM   #3
mtrai760's Avatar
You do have the option of tapping or intercepting, I intercepted the signal since I am running a Z32 MAF.
__________________
88 RX-7 - Sold
Old 09-01-2008, 10:42 PM   #4
mtrai760's Avatar
Just a quick update, I have the MAF issue figured out. The VQ30DET setting uses the NS_HW2 Hotwire MAF selection already, which is the same thing the VG30DETT uses, so it will not allow you to select it.
Thankfully, I used D-sub connectors like Dandymax recommended, so I disconnected the EU so that I can drive the car to work tomorrow. I'm still trying to troubleshoot the rich at idle condition, the injector setting issue has me stumped for now.
__________________
88 RX-7 - Sold
Old 09-02-2008, 01:54 PM   #5
mtrai760's Avatar
I guess I'm the first and only person to run larger injectors using the EU.
__________________
88 RX-7 - Sold
Old 09-02-2008, 03:15 PM   #6
have you tried messing with your lag time in the i\j adjustment tab(IE setting them at like 2-3ms?) or your injector sizes in the perameters??
__________________
1997 GXE 5 Speed CG2 RIP 160k (My new parts car)
1996 SE 5 Speed KH3 awaiting |00vi(done)|EU,100 shot(Hopefully)|97 front and rear end swap|
locknuts is offline   Reply With Quote
Old 09-02-2008, 03:24 PM   #7
opps sorry didnt read your post entirely kinda just skimmed. but from what i have understood in the past is that you pretty much just have to play trial and error till you reach what you desire. but i could be totally off
__________________
Old 09-02-2008, 08:29 PM   #8
3.5 in the works
DandyMax's Avatar
Send a message via AIM to DandyMax Send a message via MSN to DandyMax
I replied in the boosted forum..
__________________
1998. 3L. 5-spd. Sterling Mist. SE.
1/4 mile stats (all N/A VQ30):
Best 60': 1.73
Best ET & trap: 12.61, 108.98 mph
Click to see the video. More videos also here.
Mods list and dyno here (as of May 9/08).
My EU writeup can be found at VQ Power.
DandyMax is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
