Go Back   Maxima Forums > Advanced Performance > All Motor
Thread Tools Display Modes
Old 08-28-2008, 03:25 PM   #1
MAXC's Avatar
Send a message via Yahoo to MAXC
Question????
Can anyone tell me where I can find a wiring schematic for a 02 maxima 6speed combination meter? The FSM only has one for the automatic combo meter.
MAXC is offline   Reply With Quote
Old 08-28-2008, 04:01 PM   #2
Build.
Send a message via AIM to nismology
What specifically are you looking for?
And next time, please try to make your thread title a little more descriptive. Thanks.
__________________
"Men occasionally stumble over the truth, but most of them pick themselves up and hurry off as if nothing ever happened."
nismology is offline   Reply With Quote
Old 08-28-2008, 04:45 PM   #3
MAXC's Avatar
im in the process of doing a full 6speed swap, so im looking for the wiring diagram of m32 m33 & m34 so I can get this cluster installed.
Old 08-28-2008, 05:01 PM   #4
Build.
Maybe I/we can better help if we know this. Because from what I see the FSM has all the pins covered.
__________________
Old 08-29-2008, 12:50 AM   #5
MAXC's Avatar
Yes, the fsm has the automatic cluster covered, but not the 6sp. cluster. here is an off the head example. Lets say on the 02 AT cluster, M34 has 24 wire connections. Now lets choose pin # 56 & say it has red wire & its for, lets say "R"reverse. Now that same connection same pin# on 02 6sp. cluster you think would be empty because the 6sp. does'nt have a "R" on the cluster. Right. but it does have a wire connected, you just dont know what it goes too. SO my question: is there a way or how do you find out what each individule wire is for & where its supposed to be connected?
Old 08-29-2008, 06:13 AM   #6
KRRZ350's Avatar
Send a message via AIM to KRRZ350
Quote:
The FSM does have the 6-speed covered, it's the same diagram, it's just that there is no differences specific to the m/t and the specific differences for the a/t are done via internal wiring, meaning the clusters are different but the harness' are the same. If you look closely at the Schematic (120 of 480 on mine) You will notice that there is an optional splice that connects the A/T indicator to pin # 64 & # 30 on A/T vehicles only. It appears that all the wiring for the a/t indicator will be there on either vehicle. There are some minor differences where they go to though, for example on an '02 vehicle pin 15 on the cluster can run to pin 22, 18, or 19 of the abs unit depending upon a/t, m/t, or tcs.
But trust me, it's all there, the diagrams will have symbols <a> or <m> or <tcs>
KRRZ350 is offline   Reply With Quote
Old 08-29-2008, 08:05 PM   #7
MAXC's Avatar
Got it. its installed now. Thanks guys. So let me ask this. How can I find out what each wire on a connector is for? Like lets say M229. Is there anywhere in the fsm that shows where all the wires on M229 go & what they are for?
Old 08-30-2008, 07:58 PM   #8
The Dirty Pearl
pmohr's Avatar
Not AFAIK, you'll have to run through all of the relevant EL sections and do it manually.
pmohr is online now   Reply With Quote
Old 08-30-2008, 10:19 PM   #9
Build.
There is no M229 connector.
Depending on what a particular connector connects to you can go to the harness layout section in the EL portion of the FSM and look to see which component it is associated with. That makes finding the wiring diagram significantly easier.
__________________
Old 08-30-2008, 11:19 PM   #10
MAXC's Avatar
On the 03 I35 there is a M229. that same connector on the 02 Maxima is M161. I was just using M229 as an example cause my swap came from a 03 I35. But im in the process of helping someone do a 6 spd swap. Thanks for the Help Nismo. Its good to see some old skool org members still know how to help instead of criticizing them.
Old 08-31-2008, 12:41 AM   #11
Quote:
And EC and HA and possibly AT. I had connectors that took me a while of searching everywhere trying to find the last one or two wires of a connector.
__________________
1997 Maxima SE
Pearl White/Black Leather
2004 VQ35DE Full Swap
2004 4AT Full Swap
2004 Infiniti I35 Leather Swap
2004 I35 Cluster Swap
Warpspeed Y-Pipe
Completely stock looking
(快速的汽车)
made in china is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
