ECU Pinout cheat-sheets (large images, 1000+px wide)
Old 03-09-2013, 08:48 PM
  #41
kidgrave's Avatar
Cant see them....is it because I'm mobile?
kidgrave is offline
Old 03-19-2013, 04:12 PM
  #42
smokinbonz's Avatar
Can someone please confirm for me?? 02 signal input pin positions on the ecu
I am going to install a dual output sim Id prefer not to install it in the engine compartment and I intend on installing it near the ECU.
I Intend on intercepting within the ecu harness pin 55 for o2 sensor 2 bank2 and pin 74 o2 sensor 2 bank 1 Both are labelled "L" I presume for lavander??
Is my information correct? Ive had a hell of a time trying to figure this out.
It also makes me wonder why no one does it this way? Is there some reason?
If not maybe ill take pics and try to do a decent write up of my install.
dunno if its in my sig Have to update if not but 2004 Maxima 6 spd.. Thanks All!!!
smokinbonz is offline
Old 03-19-2013, 05:21 PM
  #43
No more Maximas...
pmohr's Avatar
L is blue, I don't know of any car company that would use a 'lavender' wire color.
Correct, pins 74 and 55 are B1S2 and B2S2 signal (respectively).
Right at the ECU should be fine, AFAIK. I can't think of any reason not to.
pmohr is offline
Old 03-19-2013, 05:35 PM
  #44
smokinbonz's Avatar
Thank you, I appreciate it very much !!
Old 03-19-2013, 09:15 PM
  #45
ajcool2's Avatar
Man you still on here? I had to check the date of the post to make sure it wasn't from 2009 lol.
ajcool2 is offline
Old 03-19-2013, 09:18 PM
  #46
No more Maximas...
pmohr's Avatar
I like to make an appearance every now and then.
pmohr is offline
Old 03-19-2013, 10:46 PM
  #47
mightyMax95's Avatar
HE'S ALIVE!!!!!
mightyMax95 is offline
Old 03-19-2014, 11:44 AM
  #48
Phewie's Avatar
J31? What country do you live in? USDM 6th gen is A34.
Hi pmohr,
I own a cefiro/maxima/teana j31 too. I'm located in Singapore. So it's known as cefiro here. It's a 2007 model.
The engine is qr20de. Do you have the ecu pin code for this?
Phewie is offline
Old 03-19-2014, 02:55 PM
  #49
No more Maximas...
pmohr's Avatar
Originally Posted by Phewie
Hi pmohr,
Not specifically, but I would imagine it's quite similar to the USDM A34.
pmohr is offline
Old 03-19-2014, 06:29 PM
  #50
Phewie's Avatar
Hmmm okie but which diagram is the A34 model?
I need to know which pin is for the RPM and Speedo.
Phewie is offline
Old 03-20-2014, 03:02 AM
  #51
No more Maximas...
pmohr's Avatar
The one labeled 04-07.
pmohr is offline
Old 03-20-2014, 08:12 AM
  #52
Phewie's Avatar
Ok I saw it. But which is the rpm and speedometer? It's not indicated? Or it's indicated but I don't know the "term" for it? Can enlighten me?
Phewie is offline
Old 03-20-2014, 08:21 AM
  #53
No more Maximas...
pmohr's Avatar
Sorry, I don't have those marked out. You can check out the FSM for those pinouts: http://boredmder.com/FSMs/Nissan/Maxima/2007/EC.pdf
pmohr is offline
Old 08-13-2016, 01:16 AM
  #54
Walkabout's Avatar
Hey
its that ecu connecting the same of 2,0 [121 cid]engines like 3,0[128 cid] engines of noth europe too i think about sensors everywehere
Walkabout is offline
Old 05-23-2018, 11:54 AM
  #55
quickspeed6's Avatar
Does anyone have a pinout for the 2014 maxima S want to install an apexi neo
quickspeed6 is offline
Old 12-11-2018, 04:43 PM
  #56
Tyremathis's Avatar
Pinout sheet for ecu 2004 maxima se
E cu pinout sheet
Tyremathis is offline
Old 01-26-2022, 04:20 PM
  #57
EHOWELL0074's Avatar
Red face 05 maxima ecu pinout
anyone have any info on how to setup a test bench, i need more info. cant find a cheat sheet. i work at a salvage yard, and im try to set up for multiple ecu's. so i can test these vehicles. any info would be appreciated.
EHOWELL0074 is offline
Jeff92se
04-13-2008 06:36 PM
zero2sixtyZ
10-22-2006 11:09 PM
vsamoylov
06-11-2006 04:50 PM
hct67
03-08-2004 08:45 PM
Quick Reply: ECU Pinout cheat-sheets (large images, 1000+px wide)
