Go Back   Maxima Forums > Advanced Performance > All Motor
Thread Tools Display Modes
Old 07-20-2008, 06:16 PM   #1
RE4F04A swap with RE4F04V
Hi all,
I'm not sure if in the states you get this transmission - I know you get the LSD manual, but I'm not sure if you get the LSD Auto RE4F04V.
I had one on an old Cefiro I had in New Zealand. They have Japanese imports there and theyre not hard to find with LSD.
I've since moved to Australia where there are no imported Cefiros, and only Maximas which only have the RE4F04A (Non LSD) variant.
My dilemma is, that I have supercharged my current Maxima and the transmission hasnt lasted very long, and before you say "Manual Swap". Nope - not doing it - manuals are too hard to come by here.
So my question is, has anyone swapped a RE4F04A with a RE4F04V? Is it a direct swap? Or does it have different axle mounts/axle/splines etc like the manual?
Or... would I be better rebuilding the one I have (which slips occasionally) and getting an aftermarket LSD kit installed? Any recommendations?
Cheers if you can help.
__________________
*** www.maximasdownunder.org ***
His:
1998 Nissan Maxima A32 30 S.Touring - Automagic
V2 SC 3.125" 11psi | Matty's V1 Plate | RFL TurboXS BOV | MEVI | FSTB | RSTB | King Springs | Tints | Emanage
Hers:
1995 Nissan Maxima A32 30G - Automagic
HAI | Warpspeed Y-Pipe | Chrome Muffler
jordandalley is offline   Reply With Quote
Old 07-20-2008, 07:01 PM   #2
Send a message via AIM to MDeezy
I'll give it a try....
I know in the US majority of the transmission are open diff (non-lsd), its hard to come by with a tranny with an LSD (really a VSLD) and those have a different driver side axles than those with a non-lsd tranny.
I'm not sure if you've removed your axles before and/or have a way of comparing two axles to see if they are the same. If you're in the same boat as us here you would need a new driver side axles if you went with a non-lsd tranny. Best bet would be to have the current one you have rebuilt.
__________________
1996 Nissan Maxima 5MT 3.5 (Getting a fresh remix)
1995 Nissan Maxima 4AT "Champagne Coolie" *Sold*new home in FL
1997 Nissan Maxima "Powder Fresh" 5MT 3.5 (performance built)(*new plans*)
MDeezy is offline   Reply With Quote
Old 07-20-2008, 07:07 PM   #3
Quote:
If that's the case, then are there any recommendations for LSD upgrade kits? I've heard there are a few around - some good, some not so good.
My experience with transmissions is nil. I'd end up getting someone else to do it.
__________________
His:
Hers:
Old 07-20-2008, 07:10 PM   #4
my transmission experience is limited also. from what I've heard our LSD options are slim to none. Most try to find a VLSD tranny and install that. Some used to purchase the LSD and have it installed but I dont know if there is anywhere that still makes them or would be willing to make one for us (without killing out pockets)
Old 07-20-2008, 08:23 PM   #5
Anyone tried a Quaife LSD?
__________________
His:
Hers:
Old 07-20-2008, 09:01 PM   #6
Send a message via AIM to Blackmax1924
Quote:
I am not 100% sure on this so if someone could confirm this...but I believe the quaife's are only for the 5 speed manual maximas, so that would rule that out....
Again I am not completely sure so you might want to double check with someone more noligible before you throw that idea aside.
__________________
17" Moda R6 - CE Red/Clears - Aux Input - 97 Grill - Black Bumperlights - Tokico Illumnia Struts/ Springs
Full Stillen Kit w/ 97 Stillen Lip - 96 Clear Headlights - 97 Clear Corners - Stillen Front/Rear Strut Brace - Subframe Connectors
Full Cattman Exhaust - 00VI Swap - VAFC II - Green LED Interior
Blackmax1924 is offline   Reply With Quote
Old 07-20-2008, 09:03 PM   #7
The LandShark has teeth..
grey99max's Avatar
Hi all,
I've done it - about three years ago I got a '99 I30t RE4F0AV VLSD for my '99 max, and went racing - still have the same transmission installed. I run Mobil1 oil and two oil coolers, use the DR mod and my custom-built shifter when I tracked the car - a lot, two years ago. Now the same tranny is installed on a modded 3.5 L motor and it's still working great - back of a 2800-stall Edge TC.
Only the driver's side axle needs to be changed - they are different, but you can get rebuilds from most major auto parts places. The splines are different.
I have a spare in the garage - it's from a '01 AE Maxima - same transmission. I like the "4V" -it's tough and quick, and has taken was too much abuse in my car, but still spins the slicks and makes a great daily driver. And it's going racing again... Even some 2002 Altima 3.5s had this transmission.
__________________
'99 GXE, Tune-by-Tape MAF mod, 3.5L w/cams, SSIM, 255Walbro,AERO FPR, VLSDauto, Edge TC, DR-mod, Shift_Fast, dual-B&M cooler, JClawbars, dual-NX nitrous, dual heated15lb bottles, OBX headers, 3"Warpspeed exhaust, PLXR-300 wideband, IlluminasStrut/springs, 24.5"M&H, ProgressRSB, HawkHPS, Clarion50Wx4 head w/Alpines, Fosgate sub. Spare tire+jack,3300 lb car. 355WHP-dyno.
13.158 3.0 time slip
http://i48.photobucket.com/albums/f2...3/Fscn1518.jpg
12.394 @113.22 w/3.5
http://i48.photobucket.com/albums/f2...9/DSCN0527.jpg
grey99max is offline   Reply With Quote
Old 07-20-2008, 09:28 PM   #8
grey99max - I know what you mean about tough. I had a 4V with a TC and VB mod done and it was quick and took heaps of punishment.
Maybe this is what I need to do. I'll need to find a 4V somewhere in Australia but I doubt there are any. I'll probably need to import from New Zealand or Japan.
__________________
His:
Hers:
Old 07-20-2008, 09:35 PM   #9
grey99max's Avatar
Good luck - the 4V is a tough bastid - everything except the driver's axle is a direct swap, The axles are available from various sources, including RAxles for tough ones. If you can locate one.... use car-part.com to find different donor cars, at least in the US....
__________________
Old 07-20-2008, 10:10 PM   #10
Yeah I wish it were that simple here. Thanks for the heads up, now at least I know what I need to do.
__________________
His:
Hers:
Old 07-20-2008, 11:08 PM   #11
what about a kaaz or cusco or nismo aftermarket?
do any of these companies make one, or would they specially make one?
A32AusMax is offline   Reply With Quote
Old 07-21-2008, 12:01 AM   #12
it doesnt appear that those companies make an LSD for the Maxima... Nismo never did make anything for a maxima...
__________________
His:
Hers:
Old 07-21-2008, 07:40 AM   #13
KRRZ350's Avatar
Send a message via AIM to KRRZ350
Just for the record, VLSD auto's are a dime a dozen compared to 5-speed ones, and most of the same "rules" apply-- All '99 I30's, All I30T's, and with the Auto's the majority of regular I30's also came equipped with the $800 "traction enhancement package" that consisted of a 4V
KRRZ350 is offline   Reply With Quote
Old 07-21-2008, 07:52 AM   #14
grey99max's Avatar
Quote:
And the 2001 AE automatics as well... I wonder what the Canadian junkyards have lying about, since I understand most of the Maximas sold in Canada had VLSD ...
__________________
Old 07-31-2008, 05:53 PM   #15
I found a RE4F04V transmission in New Zealand for $525 AUD. Not a bad price. Shipping to Australia should cost a bit though. Does anyone know how much the transmission weighs? I'm talking international freight. They'll probably charge me another $500 for that at least!
Ok.. so just making sure. What I need to come with this transmission is the passengers side (Yes we drive RHD cars over here) cv axle? and thats it? No other little bits and pieces I need to add to the list before I import?
Thanks guys
__________________
His:
Hers:
Old 07-31-2008, 08:59 PM   #16
KRRZ350's Avatar
Thanks guys
Is the whole drivetrain really reversed! That's nuts!
In for the answer from someone who knoew the exact weight of an A/T, I've never actually put one on a scale, my geuss is 194lb's dry, I've always been curious on that.
__________________
PM or call 774-766-7462 for SSIMS.
3-bay garage in Massachusetts servicing all your maxima needs
Quote:
Originally Posted by Me
Oh yeah? Well my car goes zero to zero in zero seconds!
Old 07-31-2008, 10:56 PM   #17
No.. the drivetrain is exactly the same as yours. It's because the drivers seat is on the other side of the car that the axle becomes on OUR passengers side. LOL.
As to the weight, i'll probably be able to tell you soon... in kg's though..
__________________
His:
Hers:
Old 08-01-2008, 10:39 AM   #18
grey99max's Avatar
Just to be careful, get both axles - betcha the driver's side axle isn't reversed.....
__________________
Old 08-01-2008, 02:51 PM   #19
3.5 in the works
DandyMax's Avatar
Send a message via AIM to DandyMax Send a message via MSN to DandyMax
Quote:
They in fact do...
I doubt it's that much... closer to 100 lbs I think... I just had one out a few days ago when I was doing a DEK swap but I didn't weigh it.. It's definitely heavier than the 5MT though.
__________________
1998. 3L. 5-spd. Sterling Mist. SE.
1/4 mile stats (all N/A VQ30):
Best 60': 1.73
Best ET & trap: 12.61, 108.98 mph
Click to see the video. More videos also here.
Mods list and dyno here (as of May 9/08).
My EU writeup can be found at VQ Power.
DandyMax is offline   Reply With Quote
Old 08-03-2008, 10:22 PM   #20
DandyMax.. next time you pass through Townsville, wanna give me a hand putting it in? Free accomodation and Australian beer for your efforts! lol
__________________
His:
Hers:
Old 08-04-2008, 10:28 PM   #21
3.5 in the works
DandyMax's Avatar
Hope you don't need it right away then because who knows when I'll be back there.. (not that I wouldn't like to go back but no immediate plans...)
__________________
Best 60': 1.73
Old 08-05-2008, 09:56 AM   #22
The auto trans is between 90 to 110 pounds. I know since I almost sent my built trans to Norway and had to weigh it. Ship weight was 135 lb with the crate I built for it. Shipping from Chicago, US to Norway came out to $660. Hope that helps.
Ferhan
__________________
Don't believe your own bull****!
furbiss112 is offline   Reply With Quote
Old 08-05-2008, 02:41 PM   #23
SLOW
Nealoc187's Avatar
