Go Back   Maxima Forums > Advanced Performance > All Motor
Thread Tools Display Modes
Old 07-20-2008, 09:58 AM   #1
Send a message via AIM to ghostmax301 Send a message via MSN to ghostmax301
Cylinder #2 & 3 arent firing
Well as the title states,for some reason my car is not firing cylinder number 2 & 3.
So far, I have checked for codes(none) cleared them, start the car for a little bit and check again(none related besides evap and egr and o2 sensors). I've changed the spark plugs and coilpacks and fuel injectors.still no fire. the 2 coilpacks are getting constant power and ground but on cold starts, the signa wires are get 0.10-0.12volts while the other 4 are getting 0.20-0.30 volts. And when its warm, the 2 bad ones get 0.00v while the other 4 are getting 0.01-0.02volts
I also tried running a wire direct from the ECU to the coilpack and still the samething..
can anyone PLEASE help me fix this problem?
__________________
http://www.youtube.com/watch?v=e1i7ZP5R-jg
13.55@103(no tune,steet tires)
^ N/A.. Guaranteeing mid 12s before boosting it
Mower Mahdz then j0000o!!
WHEELS FS/FT!!! PM ME!
ghostmax301 is offline   Reply With Quote
Old 07-20-2008, 08:36 PM   #2
ALL COMES DOWN TO 1 QUESTION
Which wire goes to the ECU to tell it which order to fire the cylinders in or tell it to fire the cylinders period?
If it helps any, somehow i blew the BATTERY fuse in the fuse box beside the battery.(fuse was replaced)
Im asking which wire controls them because i want to trace the wire to see if it burned up or anything.
sooooo many headaches
__________________
Old 07-20-2008, 09:31 PM   #3
Are you getting fuel? When I had my 3.5 swap done, something shorted out the injector driver in the ECU and cylinder 1,2,3 werent firing. Injectors were fine, plugs were firing but the ECU would not send the signal for those injectors to open. When the ECU was opened up, there was visible damage (burnt). This may not be your case but its an idea.
Good luck.
__________________
Mods:| Cammed VQ35 | SSIM | HR springs | ARP rod bolts | OEM Nissan rwd head-gaskets | Budget Y-pipe and Catback | NWP Spacers | Dynomax Superturbo muffler | EdgeRacing Converter | Transgo Reprogramming Kit | JWT Pop Charger | Emanage Ultimate | SSV4 | Innovate LC-1 WB | DR mod | ES motor mounts | ES x-member bushings | ES LCA bushings | Polyfilled tranny mount| 15" RX-7 BBS wheels (12lbs/rim) | Street tuned: 13.0 AFR, 7200 Rev limit, advanced timing |
whlimi is offline   Reply With Quote
Old 07-20-2008, 11:09 PM   #4
well, the fuel injectors are firing but I pulled the coilpack out with the plug attached and it didnt spark.
__________________
Old 07-20-2008, 11:18 PM   #5
THINK I FOUND MY PROBLEM(thanks to phmor)
http://www.asashop.org/autoinc/jan2001/techtips.htm
now is this possible if my timing is at 15 degrees? Or does this mean my igniton timing is good but my cam timing is off? If so, i think i might know why my cam timing is off
__________________
Old 07-21-2008, 10:03 AM   #6
Send a message via AIM to VqMoNsTeR Send a message via Yahoo to VqMoNsTeR
Quote:
the best way to test the coils for spark is to disconnect the crank pos. take a coil and a plug that u know works and hold the end of the plug to ground while cranking.
__________________
I Got Stagger Swagga
1 3 5
-l-l-l-
2 4 6
R
SHIFT_SEE ME
13.4@106.6
VqMoNsTeR is offline   Reply With Quote
Old 07-22-2008, 05:53 PM   #7
Ding! Ding! Ding!
Thats your answer!!
I know this first hand because it happened to me. I went crazy looking for the problem for a month or two. I switched out the wiring harness, checked and replace the CPS and CKPS because it had low readings. I suspected the timing maybe, but nobody knew and doubted the timing issue... and finally, a freind and fellow orger emailed me that same site, and BADABING!!!
I had found that my Unorthodox UDP stripped and the Crankshaft dowel key tore a huge gap into it, causing it to rotate a few degrees clockwise. The dowel key was also bent like nothing I have ever seen. Luckily, the crankshaft had no damage to it whatsoever!!
__________________
915Max is offline   Reply With Quote
Old 07-22-2008, 11:07 PM   #8
well.I got the problem fixed thanks to that link..THANKS! it should be sticky'd.
anyway,it wAs my cam timing. was off ONE tooth. fixed it and the car runs great now BUT I do have a question about the crankshaft dowelpin. I should go ahead and replace that now shouldn't I before it gets too bent up? its bent a LITTLE now but the pulley is on TIGHT sooo, wat u think
__________________
Old 07-23-2008, 06:40 AM   #9
Send a message via AIM to i2vicious2 Send a message via Yahoo to i2vicious2
i think u should swap it out.....
__________________
VQ30DE-K inside
I2VICIOUS
HA. IM coming for dat auto.... ( u alredy know )
i2vicious2 is offline   Reply With Quote
Old 07-23-2008, 03:46 PM   #10
swap it out!! Its bent already... any more stress will cause it to completely strip, and you might damage the actual crankshaft... you for sure dont want that!!!!
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
