Quote:
Originally Posted by matty
They are pretty much of a waste to have because by the time you notice that there is no oil pressure or lack of, the motor is far gone.
Best setup would be a kill switch hooked up like Dandy max has.
-matt
true in a way, sometimes one maybe lucky to see their oil pressure dipping underload, but most wouldnt react fast enough before the motor goes.
I'll have to look into this kill switch for the future.
Quote:
Originally Posted by nismology
I don't see a problem.
BTW, the oil pump is driven by the crank snout so it doesn't matter which timing components are installed. Also, oil pressure is RPM-dependant and is not affected by load.
I didnt really see a problem, just noting incase others were wondering about their oil pressure. At idle it seemed a little low but underload its normal, and very high during warm up as it should be.
Your right oil pump is driven by the crank. I remember seeing the end of the crank going thru the oil pump
