No spark...
Posted in the 5th gen section... long story made short..
I've got a 3.5, running on a 02 harness/ECU.. I'm getting a crank position sensor circuit code on the Consult. It takes a good 4-5 seconds of cranking for the engine to start/run.. The RPM signal isn't showing while cranking on the Consult.. afer 4-5 seconds.. the cam sensors pic up at 63*, and the RPM starts to work.. The engine fires/runs at this time.
I've tried a few QR25 sensors that I've had laying around.. but, nothing works.. I finally ordered a new sensor for the Maxima.. which should be here tomorrow. I thought all of the newer hall effect sensors were the same in terms of signal/function.. Any ideas?
Also.. If anyone can give me a pinout for the sensor, that would be great... The FSM isn't very clear on which way to check the pins as far as order. Is it 1-3 with the pins facing me, and the plug snap facing up? Or, the other way around? I've got 12 volts, ground and continuity from the middle wire back to the ECU.
Travis
Travis
