Go Back   Maxima Forums > Advanced Performance > All Motor
Thread Tools Display Modes
Old 06-15-2008, 11:13 AM   #1
3.5 finally runs- Now a coolant leak
So i fixed the air gap on the cps and it fired right up finally. Now ive got a coolant leak from where the inner timing cover meets the lower oil pan. I think it was to cold outside when i put the rtv on. Has anyone ever tried pulling the timing cover in the vehicle or had this problem? Should I just go ahead and pull the motor?
wagesgt903 is offline   Reply With Quote
Old 06-15-2008, 11:26 AM   #2
Send a message via AIM to 95BLKMAX
pulling the timing covers with the engine in the car is possible, but its a bia...
Did you change the water pump when you swap'd? because when water pumps go bad, what you're describing is exactly the sign- leaking bet'n block and timing cover. Its designed to do it like that.
To change it, you do not have to remove the timing covers, just the 2 cover plates for the timing chain tensioner (that has to come off), and the water pump. Not much room to work around in order for the pump to come out/ new one in, but it IS possible. Just have to turn it and twist you hand in some weird ways, but it works, lol.
__________________
NA-Built Baseline
95BLKMAX is online now   Reply With Quote
Old 06-15-2008, 03:12 PM   #3
The Dirty Pearl
pmohr's Avatar
That's really the only place coolant should come into contact with the timing covers...at the water pump area. Most likely it's a damaged o-ring on the water pump, or just a bad pump.
pmohr is online now   Reply With Quote
Old 06-15-2008, 11:16 PM   #4
Quote:
indeed. my pump gave out a year and a few months after the swap. I made the cheap-o mistake of re-using the stock pump when for $45 from Autozone I could have just put in the new one from then, but n000000.... Took it out with nismology's help, one of the o-rings on it was flacking and stiff as a rock. I didnt bother prying it off the pump, it just broke into pieces
__________________
NA-Built Baseline
Old 06-16-2008, 05:59 AM   #5
If its just that ill just lift the motor out to do it. I work at a shop but i had to do the entire swap until now in my garage at home so pulling it in my bay at work will be no problem. I just hope thats it i dont want to have to pull and clean the covers again, I cant wait to drive it.
I didnt realize how damn good it would sound!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
