Go Back   Maxima Forums > Advanced Performance > All Motor
Thread Tools Display Modes
Old 06-11-2008, 03:38 PM   #1
Send a message via AIM to amomaxima
5 speed sway in a 5.5
i am hoping someone on here can help
I have an auto and i hate it
thought about a shift kit and if i cant get this to work i will do it
I found a great deal on a 2000 5 speed tranny and i have a junk yard with all the parts i need to swap.
My question is the ECU
I have an 03 auto so the ECU is designed as such.
What will happen when the 5 speed tranny is put in. My mechanic is a nissan tech and knows how to wire the wires up and make it work but he told me i would throw a shtiload of codes. he has a 3.5 manual swap in his 4th which was auto and he has all the tranny codes on all the time so he just unplugged the bulb. I am concerned about damaging a NICE And RELIABLE car
has anyone done this swap before
Any help is appreciated
Before you ask. I tried to get a 6 speed but the only ones i can find at 1800 dollars and the 5 speed is 325
thanks in advance for your help
__________________
http://forums.maxima.org/showthread....=1#post6287867
Amomaxia= lovemaking or necking in a parked car
amomaxima is offline   Reply With Quote
Old 06-11-2008, 04:24 PM   #2
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
FYI:
A33B ECU does not come in 5MT trim.
It's been tossed around before. No one has done it, but I would guess it's essentially the same as a 6MT swap. That HAS been done, there are a few threads on it.
Also, www.car-part.com does have 6MT's available.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 06-11-2008, 05:11 PM   #3
yeah i found the six speed but its 1800 when i can do the whole thing with a 5 speed stage1 and fidanza for 1400 with install
what do you mean by 5mt trim
are you suggesting that the ECU wont run on a 5 speed
__________________
Old 06-11-2008, 05:14 PM   #4
Certified Hooptie
NmexMAX's Avatar
Looks like you edited it, anyway.
Since no one has done it, I would assume it is safe to say that a 6MT ECU should work.
Search for the threads on the 6MT swap, read them, and go from there.
__________________
Old 06-11-2008, 05:19 PM   #5
i read all the 6 speed swaps
no one talk about ECU compatability as far as i can see and they are all in a 4th gen which has a different wiring
My tech is sure it will work but i am concerned that it will put the car into ECU safe mode
__________________
Old 06-15-2008, 12:27 PM   #6
Beast Mode!!!
Send a message via AIM to skuccio's max
Well from what I know the ECU doesn't know what gear the tranny is in, all it gets is the speed sensor signal...
If that's the only thing, find out of the speed sensors on the 5 and 6 spd trannys are the same and go from there
Won't you need new tranny mounts too? I know the 5 and 6spd tranny casings aren't the same.
__________________
skuccio's max is offline   Reply With Quote
Old 06-15-2008, 12:45 PM   #7
Both Jime and I run A33B auto ecus with no drivability issues. I run a 6MT and he is running a standalone controller for his 4AT.
You will get a CEL (CAN code) for the missing TCM.
eng92 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
