Go Back   Maxima Forums > Advanced Performance > All Motor
Thread Tools Display Modes
Old 06-10-2008, 08:45 AM   #1
Send a message via AIM to black_maxed95
370cc injectors on a bolt-on only Maxima?
Hey guys, I need to replace my stock injectors so I figured I might as well upgrade now since in a year or so I plan on being boosted. However right now I am pretty much only bolted-on. Now I tried searching and it looks like I would need a aftermarket FPR also but I am at work and cant search too much right now. Most of the threads I read through were for people running boost so that doesnt help me now.
My question is can I run some 370cc 300zx injectors without other major changes besides a FPR? I dont have any tuning devices. I read that a 300zx MAF will help balance it out which I do have (not installed right now for obvious reasons tho).
What are the suggestions on this?
__________________
I like to "do it myself"
5MT SE 96er:
MEVI + NWP Spacers, Full Exhaust, Flywheel, lotsa more:
MOD LIST
black_maxed95 is offline   Reply With Quote
Old 06-10-2008, 08:57 AM   #2
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Explain how you think a Z32 MAF will balance it out? If anything, that combo (Z32 MAF / injectors) will make you run richer than the injectors alone. You need a tuning device and a wideband. And, IMO, an AFPR is not a tuning device.
Why do you 'need' new injectors?
If anything I would wait it out until you went boosted, then toss in a new set of injectors relative to your boost level.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 06-10-2008, 09:08 AM   #3
370cc injectors=more fuel
Z32 MAF=more air
Thats how...that is what I found searching, I didnt come up with that myself but it does make sense.
I realize a FPR is not a tuning device but it would be used to lower the fuel pressure so the injectors dont dump too much fuel in.
I admit I dont know much about this subject so that is why I am asking. But right now I have bad fuel injectors making my car run like crap and I figured I could upgrade now since I plan on going boosted soon. If its a bad idea over all I wont do it but that is why I am asking.
Im not 100% sure I 'need' new injectors but right now my car is hard starting and sputtering under hard acceleration. I have basically no power. I have gone through several other things to check and so far I have not found the problem. Fuel injectors were one of my next approaches.
__________________
5MT SE 96er:
MOD LIST
Old 06-10-2008, 09:10 AM   #4
Use the Search Function!!
mtrai760's Avatar
Send a message via AIM to mtrai760
I run 370cc injectors with a Z32 MAF and an adjustable fuel pressure regulator set to 34psi (stock FP). I have nothing else to control my A/F under stock (not boosting) conditions. When not boosting, my car drives normally, at 14.7 AFR. No starting or idling issues.
The big question that comes into play is how your car will act at over 50% throttle application, when your ECU goes to pure fuel maps and ignores AFR. I am boosted and have no issues, but I would think that you would run rich under those conditions.
I ran my 240sx with Z32 injectors and a stock MAF NA for a few months before I installed my turbo system, and did not have any running issues. The ECU's of the two are really not that different. I think you can get away with it, you just may run really rich under hard acceleration while NA. You will have to play around with it to be sure though.
__________________
98 SE - Supercharged at 10psi w/the works - VQ35 coming soon...
2k SE - Stock... pretty much
88 RX-7 - Sold
95 240sx KA-T 10psi - sold
3 4th gens.... gone....
mtrai760 is offline   Reply With Quote
Old 06-10-2008, 09:18 AM   #5
Thanks, thats alot of what I wanted to hear. Soon I also plan on getting a wideband and a AFC also so that will help.
What FPR do you use?
__________________
5MT SE 96er:
MOD LIST
Old 06-10-2008, 09:24 AM   #6
Certified Hooptie
NmexMAX's Avatar
I was going by this:
Stock ECU, Z32 MAF, 550's...explained
__________________
Old 06-10-2008, 09:26 AM   #7
Also I can only use 95-96 300zx injectors?
I look on ebay and I find alot that listed for 90-96. Im not finding much for the purple tops, most are dark red.
__________________
5MT SE 96er:
MOD LIST
Old 06-10-2008, 09:48 AM   #8
Build.
Send a message via AIM to nismology
Quote:
The Z32 MAF will lean things out regardless of which injectors are being run.
__________________
"Men occasionally stumble over the truth, but most of them pick themselves up and hurry off as if nothing ever happened."
nismology is offline   Reply With Quote
Old 06-10-2008, 09:52 AM   #9
Certified Hooptie
NmexMAX's Avatar
Quote:
By being slightly larger in ID,
__________________
Old 06-10-2008, 11:08 AM   #10
mtrai760's Avatar
I use an AEM universal AFPR.
__________________
88 RX-7 - Sold
Old 06-10-2008, 11:27 AM   #11
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
I have 370s in my car temporarily since I'm using side feeds right now instead of top feeds with the 3.5. I have my base FP set at like 28psi I think (never adjusted it. car fired up on the first crank after the swap so I never bothered to mess with it) - z32 maf and emanage blue. a good amount of tuning on EB was required to get the AFRs where they should be. pulling fuel in the very low rpm/idle range and adding fuel most everywhere else.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto Drag Radials
3.5L - I/Y/E - USIM
13.26 @ 101 - 1.80 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - stock 3.0L - I/Y/E/MEVI/JWT ECU - Totalled
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Totally Stock - winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 06-10-2008, 11:34 AM   #12
Does that have a guage built on to it? I was looking on ebay and it didnt look like they did. The OBX universal ones looked nice and had gauges. They were cheaper too but obviously OBX isnt going to be as good of quality as AEM.
Quote:
thanks for the info, I should probably get a wideband and AFC also.
__________________
5MT SE 96er:
MOD LIST
Old 06-10-2008, 11:41 AM   #13
mtrai760's Avatar
No, I purchased a 0-100psi gauge from Jegs, and I have a electric fuel pressure gauge in the car. I trust AEM a lot more than OBX, but there are good FPR out there that are cheaper than the AEM.
__________________
88 RX-7 - Sold
Old 06-10-2008, 12:21 PM   #14
"I choose boobs!"
mowgli29's Avatar
Send a message via MSN to mowgli29
sorry this is a little OT...how much did you pay for it?
Are the $50 ebay AFPR's crap?
__________________
1997 A32 5MT SE
Powah
=||00VI||V-AFCII & LC-1||UR Ultra Sc||
||Cattman headers + catback||
WSP test pipe||
||Fidanza flywheel and 4-puck kevlar clutch||
||Z33 intake tube + K&N||
Handling=||17x9 +35 FN01R-Cs||255/40-17 T1Rs||
||GC/Koni||TMS FBs||
||All ES Bushings & MM||Hawk pads||
Other=||20% Tint||E55 BiXenon||Red/Clears||
||GREEN Pathy 6CD||peeling front bumper
Awaiting Installation - TMS SFCs, 3.5 cams, Konis, 4 cv & 2 rack boots
FOR SALE! http://forums.maxima.org/4th-generat...-cleanout.html
mowgli29 is offline   Reply With Quote
Old 06-10-2008, 12:42 PM   #15
Send a message via AIM to 95BLKMAX
[....] should probably get a wideband and AFC also.
SHOULD? more like you NEED to get those things PRIOR to installing the 370s so the car will run right.
But with that working all together, you'll be just fine
__________________
NA-Built Baseline
95BLKMAX is offline   Reply With Quote
Old 06-10-2008, 01:28 PM   #16
mtrai760's Avatar
I paid around $150 for mine a year ago. Keep in mind that you will also need to purchase fittings for it, which can get expensive.
I have no experience with the ebay ones, I know some people use them with no issues.
__________________
88 RX-7 - Sold
Old 06-10-2008, 01:47 PM   #17
12's or bust
Stay away from cheap afpr, I had a name brand afpr and had problems with the diaphram blowing out. And trust me you do not your afpr going bad.
__________________
My Cardomain _ _Maxima runs 14.30 N/A
Mevi/I/Y/E/N
Dyno:258whp & 267wtq
Nitrous PB: 13.9@95mph
All Motor PB: 14.3@95mph
Looking to join the 300whp club in 2008
3280lb with driver, full trim, rims, spare, jack, fluids, etc and notorized proof
t6378tp is offline   Reply With Quote
Old 06-10-2008, 02:03 PM   #18
Certified Hooptie
NmexMAX's Avatar
Nismo unit is ~ 120$ from Courtesy.
__________________
Old 06-10-2008, 02:12 PM   #19
Indeed. I bought a greddy knock-off on ebay for $55 when I first did the swap. The sucker didnt last more than 3 months before it got stuck internally and whored the pressure to 75psi and would not adjust down from there.
I then called Justin from ImportCarPartsPro and I got a Fuelab AFPR for $139shipped.... it was expensive for SO worth it. Super dupper high quality piece.
__________________
NA-Built Baseline
Old 06-10-2008, 07:27 PM   #20
Quote:
+1 defently buy a qualilty peice. i got a knock off one off ebay. and i hooked it up for about a week and before i knew it i had gas spewing out the vaccum
__________________
1997 GXE 5 Speed CG2 RIP 160k (My new parts car)
1996 SE 5 Speed KH3 awaiting |00vi(done)|EU,100 shot(Hopefully)|97 front and rear end swap|
locknuts is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
