3.5 swapped 4th gen starting problems
Last April, Nismo3112, BlackBIRDVQ, and I swapped a 3.5L out of an 02 Altima into my 4th gen. For the first few months, the car started like it came with the setup from the factory...turn the key, it fires up. However, as the summer progressed, it got harder and harder to start requiring me to feather the throttle as I started the car. After storing the car for the winter, I tried to start it but all it would do is crank and crank. Flooring the gas would allow it to fire up eventually but then I would have to feather the gas some more to keep it alive for the first ten seconds or so. I need some help figuring out what's going on.
My setup:
02 VQ35
Pathfinder throttle body (properly calibrated TPS)
SSIM
Walbro 255lph fuel pump
Nismo FPR (gauge is showing 38psi when idling)
Returnless fuel setup
VQ35 injectors
IACV relocated and hooked up using a Stephen Max adapter and a new inlet was drilled and tapped right by the brake booster barb on the IM; vaccum hose between the IACV and the barb is about 2"
__________________
Some people call it an obsession; I call it my Maxima.
Daily driver: 2004 Obsidian Black Infiniti M45
Fun/project/track: 1996 Deep Evergreen Nissan Maxima w/ cammed VQ35, Quaife 5spd, and a whole bunch of other stuff
Bad weather/winter beater: 1998 Silver Toyota Rav4 (AWD w/ LSD)
STUFF FOR SALE!
FS: VQ35 cams
FS: 4th gen David L red/clear tails
