Go Back   Maxima Forums > Advanced Performance > All Motor
Thread Tools Display Modes
Old 06-02-2008, 08:13 AM   #1
OOvi question
hi there.
i'm trying to work out if my 00vi is broken or not.
the first time i supplied the VIAS with +12v and ground, the actuator moved a little bit (not the full range i was expected) the next time i supplied power it didn't move at all. however i did hear the click, when i suck on the nipple it actuates the VIAS without a problem.
i'm wondering, is this because it needs to be "recharged" with vaccumme or something? is anything wrong. and where are the 2 O-rings that i keep hearing about "needing to be replaced", is this behind the brass plate that the nipple comes out of? or is this when you undo the 4 "soft" screws and its the bit with the spring in it (i replaced the o-ring there, but i could only find the 1)
mywhitewolf is offline   Reply With Quote
Old 06-02-2008, 08:21 AM   #2
Send a message via AIM to G4nismo
Quote:
Originally Posted by mywhitewolf View Post
hi there.
have you checked your cup inside the VIAS? it should not be able to rotate independently of the shaft. maybe it came loose and broken off or something.
JB weld it.
__________________
00VI, Full Exhaust, Suprastick, Ksport coilovers, FTSB, Hayden 404, Full LED interior,
CAI, 2K3 SE rims, RTP rotors, etc...
LED Master :
http://forums.maxima.org/showthread....483&highlight=
http://forums.maxima.org/showthread....667&highlight=
http://forums.maxima.org/showthread....391&highlight=
G4nismo is offline   Reply With Quote
Old 06-02-2008, 08:24 AM   #3
yes, I've checked that the cup doesn't move independently.
Old 06-02-2008, 08:32 AM   #4
00vi'dvq30devq354.5genftw
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
hi there.
The same thing happened to me when I was testing mine to make sure it worked. I would touch the battery in the car with the wire to the vias and after doing a couple of times it would just stop moving completely. Once I got it hooked up to the car with the car running it worked just fine.
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The Dark Phoenix 13.517@102.3mph 60' 2.0 AUTO 245 RWHP 3280lb w/driver
Fear me.
VQ35 Swap Progress Thread
ajcool2 is offline   Reply With Quote
Old 06-02-2008, 08:38 AM   #5
phew, thats ok then. thanks for your help.
Old 06-02-2008, 03:49 PM   #6
just a suggestion
i would jb weld it before you do the swap. i didnt do it before the swap and i had to take it all back off and jb weld it. it is much easier doing off the car vs on the car. cause it will more than likely go bad on you in time
__________________
1997 GXE 5 Speed CG2 RIP 160k (My new parts car)
1996 SE 5 Speed KH3 awaiting |00vi(done)|EU,100 shot(Hopefully)|97 front and rear end swap|
locknuts is offline   Reply With Quote
Old 06-03-2008, 01:54 PM   #7
Licensed to Spell
ptatohed's Avatar
OOVI.
__________________
Cleaning up the .org's grammar, one member at a time.
1999 SE, Pearl White/Black leather - Fully loaded with all factory options except TC (ABS, heated seats, side airbags, etc.) - Supercharged (322 HP / 307 TQ)
1996 GLE, Pearl/Black - Superchargerless
1993 SHO, Pearl White/Gray - Stock
Super Charger install instructions
ptatohed is online now   Reply With Quote
Old 06-03-2008, 01:58 PM   #8
ajcool2's Avatar
Quote:
Originally Posted by ptatohed View Post
OOVI.
Guess its the new kind.
__________________
DCMAX FTW
Fear me.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
