05-31-2008, 10:37 AM
LC-1 wideband questions
Okay...I planned on installing my wideband and tuning today until I was told/and read that there isnt actually a wire to connect to the RPM wire on the ECU. Can someone clarify that there is another component I need to buy in order to tune this? I got the impression one of the wires connected to the RPM wire and then I could datalog on my laptop.
How do you guys tune without having an RPM to look at on the graph?
05-31-2008, 11:21 AM
It does it by time. You as the driver know the RPM that you start and end the run. So you know thats the rpm range you have to work with when you log. Then you make the corrections in that range guesstimating more or less wat point in time is what RPM.
Its EASIER if you have an RPM X-Axis on the log, but really you dont HAVE to have it to log and tune. Takes maybe 1 or 2 more runs to get it all right but its no big deal. I've been tuning like this for months, and this si how we've been tuning streetz' car for like 2 yrs now. Works just fine
05-31-2008, 11:25 AM
i appreciate the help man. looks like i'll have to get a friend to help me with managing the computer then while i'm driving
05-31-2008, 12:10 PM
alright the wiring is pretty straight forward except for the brown wire which is Analog 2. I dont think I need it, although it shows it hooking to the ECU in the diagram. Analog 1(yellow) is for a gauge and I'm not using one at the moment so I know that one will be loose. Should I be leaving the brown wire loose as well?
05-31-2008, 12:36 PM
Resident Mass. Brownie
My buddy purchased the SSI-4 to log the RPM signal as well. Take a look at the innovatemotorsports site.
__________________
2002 Super Black SE 6-Speed (Best 1/4 Time: 14.639 @ 96.58 mph)
| Berk Intake w/ APEXi | APEXi WS2 | 17 BTDC | Eibachs/Tokico Illuminas 3F/4R | Progress RSB | ES MMs and Bushings | CE FSTB | H&R 15mm Rear Spacers | RTP Slotted Rotors | Axxis Metal Master Pads | SS Lines | 6,000ks D2Rs and H3s | Dark-V LED Lighting | VIS OEM CF Hood | 235/45-17 General Exclaim UHPs | G35C Seats | SSIM
05-31-2008, 12:38 PM
ah yeah I was reading about that. I'll have to get that in the future, I'm going to try to tune this today. thanks
05-31-2008, 05:56 PM
my laptop isnt that old but..it doesnt have a serial port that matches with this db-9 cable that came with the kit...
05-31-2008, 07:41 PM
The more I read these threads, the more I start to think it'd be alot easier to just go get cars dyno tuned.
I just bought a used safc2. I dont have: a laptop, wideband with 02 sensor or anykind of rpm reader. What would it cost me to do it myself? At least $400 for the laptop, $3-400 plus for a wideband, another $100+ for whatever to look at rpm signal, then what software do I use on the laptop? Sounds like alot of money to try and do this? Am I missing something here?
05-31-2008, 08:11 PM
Quote:
Radioshack sells a serial to usb adapter. Thats what i am using to log my zt-2. I think you can find them cheaper on ebay or something man.
__________________
99 GXE Auto V1 370cc injectors and Modded vb.
97 5sp SE 343whp/356wtq Turbonetics 60-1 @18psi,SAFCII,r33 full kit,Acura TL retroed headlights.Innovate LC1 wideband O2
Spec Stage 3 clutch, 550cc DW injectors,MEVI.
91 GXE Auto bone stock beater
Led retro's Pm me
05-31-2008, 08:12 PM
And to you if you plan to mod once and never change things then yes a dyno tune is in deed cheaper but if you are like me and others we would be spending thousands of dollars or tunes and waiting to have it done.
__________________
Led retro's Pm me
05-31-2008, 08:26 PM
Quote:
thanks. I'll check that out.
new problem. I make my corrections, I subtracted up to 20 points(?) of fuel and showed no differences on the wideband. I kept going back to subtract more fuel but was getting the same results on the wideband.
2nd gear pulls- VAFC2. any ideas? 500 rpm increments. Its dipping down below 11 and steady in the 12's up top.
I changed it back to no corrections since it wasnt giving me any results, just to be safe.
thanks.
on the wide-high map.
06-01-2008, 12:47 PM
Could you elaborate more on the time method? I have the SAFC2 and the LC-1, but was waiting to install when I bought the SSI-4. I have a laptop and can connect to an LC-1 no problem, but the tuning w/o RPM is where I would see difficulty.
__________________
06-01-2008, 01:20 PM
Quote:
the way I understood it was basically that you record your run (from 3k to 6500) and nothing more. That way when you look at your graph you know the beginning of the graph is 3000~ rpm and the end is 6500~ and everything in between is the rest of your powerband kind of like a dyno chart. I was doing it last night and I got the basic concept down I just wish the car would make the changes that I entered into the vafc.
I started at 10.9 and it went up into low 12's toward the upper end. I've been driving like this for over a year
06-01-2008, 02:23 PM
The Dirty Pearl
You could also add in a fair amount of fuel at one arbitrary RPM, then use that as a reference point in the wideband's logs.
06-01-2008, 02:39 PM
oh I see waht your saying. I just want my adjustments to make a difference period right now....I got zero response from my changes....
06-01-2008, 02:56 PM
The Dirty Pearl
Sure the VAFC-II is wired in/configureed correctly?
06-01-2008, 03:01 PM
Quote:
pretty sure yeah. would it even work if it was wired wrong? I am fairly sure the configurations are right. 10% and 50% for my throttle setting. the setup is correct.....i donno.
06-01-2008, 03:03 PM
what maf are you running and what are your in and outs?
__________________
Led retro's Pm me
06-01-2008, 03:06 PM
stock maf. 4 in 4 out.
06-01-2008, 03:16 PM
and you say you made corrections and it did nothing? Try adding to see if it makes a difference.
__________________
Led retro's Pm me
06-01-2008, 04:05 PM
Correct no changes at all. I will try adding tomorrow when I get back home.
06-01-2008, 05:00 PM
You do know that pulling fuel adds timing also. Wasnt sure if ya knew.
__________________
Led retro's Pm me
06-01-2008, 07:09 PM
Well I kinda knew that.sorta...that's a good thing though right? Doesnt really have much to do with the irresponsiveness though, yeah?
06-02-2008, 12:29 AM
For All Motor, Adding ign timing= FTW!!!!
