Go Back   Maxima Forums > Advanced Performance > All Motor
Thread Tools Display Modes
Old 05-21-2008, 05:30 PM   #1
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
Do all 2001 VIs have the cali smog equipment?
wondering if all 01 VIs are cali spec, and if the difference is enough to warrant not getting an 01 or cali spec 00VI. I wouldn't be using any of the smog stuff obviously, but I've never had my hands on an 00vi or 01vi so I don't know what's happening with them.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto Drag Radials
3.5L - I/Y/E - USIM
13.26 @ 101 - 1.80 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - stock 3.0L - I/Y/E/MEVI/JWT ECU - Totalled
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Totally Stock - winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 05-21-2008, 05:47 PM   #2
192.168.1.1
gtr_rider's Avatar
Regardless of if it is a 2000 or 01 you can just remove the smog valves and plug up the tiny holes that they leave.. Its not much of a difference so pick whichever you can get and go to town..
http://www.vqpower.com/gtrmax/00VI/
__________________
VQpower.com
Need work done:
Suspension, Engine, Brakes, Cosmetic, Headlight Retrofits
gtr_rider is offline   Reply With Quote
Old 05-21-2008, 06:58 PM   #3
Send a message via AIM to black_maxed95
I disagree, save yourself the trouble and get a fed spec one with out the swirl valves. Im not sure about your question tho refering to the 01vi being all Cali spec.
__________________
I like to "do it myself"
5MT SE 96er:
MEVI + NWP Spacers, Full Exhaust, Flywheel, lotsa more:
MOD LIST
black_maxed95 is offline   Reply With Quote
Old 05-21-2008, 07:24 PM   #4
SLOW
Nealoc187's Avatar
Quote:
On car-part.com when you search 2001 intake manifolds there is no option for cali or fed spec, but it lumps 2000 cali spec manifolds in with the 2001s making me think that all the 2001 manifolds may have the cali spec swirl valves.
__________________
3.5L - I/Y/E - USIM
Old 05-21-2008, 08:05 PM   #5
3.5 in the works
DandyMax's Avatar
Send a message via AIM to DandyMax Send a message via MSN to DandyMax
If you're only getting the upper mani Neal don't worry about it, either one is fine, the swirl valve stuff is in the lower, the upper only has an extra solenoid for them is all, and it doesn't matter if you have that there or not.
__________________
1998. 3L. 5-spd. Sterling Mist. SE.
1/4 mile stats (all N/A VQ30):
Best 60': 1.73
Best ET & trap: 12.61, 108.98 mph
Click to see the video. More videos also here.
Mods list and dyno here (as of May 9/08).
My EU writeup can be found at VQ Power.
DandyMax is offline   Reply With Quote
Old 05-22-2008, 06:55 AM   #6
GO TEAM GO
Kevlo911's Avatar
I would try to find a 00 fed spec lower manifold. It will save you time and it looks better than modding the cali spec one
__________________
97 Pearl White Max GLE
191WHP and 201WTQ
yeahhhhhhhhhhhhhhhhh
Auto tranny parts for sale, Stock VB , Flex Plate, and more! ect...
Kevlo911 is offline   Reply With Quote
Old 05-22-2008, 09:25 AM   #7
Build.
Send a message via AIM to nismology
He's not gonna be using a DE-K LIM.
__________________
"Men occasionally stumble over the truth, but most of them pick themselves up and hurry off as if nothing ever happened."
nismology is offline   Reply With Quote
Old 05-22-2008, 10:46 AM   #8
"I choose boobs!"
mowgli29's Avatar
Send a message via MSN to mowgli29
Quote:
I never even knew that existed.. I thought all of them had the swirl valves
__________________
1997 A32 5MT SE
Powah
=||00VI||V-AFCII & LC-1||UR Ultra Sc||
||Cattman headers + catback||
WSP test pipe||
||Fidanza flywheel and 4-puck kevlar clutch||
||Z33 intake tube + K&N||
Handling=||17x9 +35 FN01R-Cs||255/40-17 T1Rs||
||GC/Koni||TMS FBs||
||All ES Bushings & MM||Hawk pads||
Other=||20% Tint||E55 BiXenon||Red/Clears||
||GREEN Pathy 6CD||peeling front bumper
Awaiting Installation - TMS SFCs, 3.5 cams, Konis, 4 cv & 2 rack boots
FOR SALE! http://forums.maxima.org/4th-generat...-cleanout.html
mowgli29 is offline   Reply With Quote
Old 05-22-2008, 11:11 AM   #9
Send a message via AIM to MOHFpro90
In the case that he is only using the A33 UIM, it wont matter, there are no important differences.
There are A33 LIMs without swirl valves.
__________________
FOR SALE: Ksport Coilovers, VQ30DE Engine, MAF, Auto ECU, Stock Parts
00VI | 5.5Gen BBK | Axxis Ceramic | Raxles | Ksports | 00 5 spokes | AE'd | Cleared Tails | Shortram | 9007 conversion | LED interior | SNOMAX's LCAs
MOHFpro90 is online now   Reply With Quote
Old 05-22-2008, 10:07 PM   #10
SLOW
Nealoc187's Avatar
Danke for the info - I'm an 00vi noob obviously.
I'd be using a 3.5L LIM with a machined adaptor plate to match the ports.
__________________
3.5L - I/Y/E - USIM
Old 05-23-2008, 05:05 PM   #11
I was wondering if the swirl valve in the LIM of DEK should be removed ? Does it make any difference with or without the swirl valve ?
__________________
2K1 AE-SE - Sterling Mist
2k8 Nissan Rogue
doublea is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
