SAFCII and Q45 Maf ?
Does anyone know if i can change to maybe setting one to make the maf lean itself out without pulling fuel? I know if i start pulling fuel it will add timing and thats something i dont want. Is there anything i can do?
Ill try that too. I found out theres a way to send half the signal out and that seems to be working now. But i will try that also and see what that does for me. I mean with it setup normal i pegged my wideband at 9.6 at wot.
Just curious, but how did you get that the Q45 MAF = 17?? And why "OUT"? It's the "IN" setting that needs to be changed.
Wouldn't the HW setting be 1? Therefore, I believe Kz should use 1 IN, 4 OUT.
Taken from here......
http://forums.maxima.org/showthread....2577&highlight
Thoughts??
Thoughts??
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
This is slightly off topic here, but relates to the questions...
Nmex: What do you think of going with a 1 in 17 out setting next time I tune on this 3" maf/intake so I can take out a bunch of fuel for ghetto timing advance? I know my maf pipe is 6mm smaller than the 82mm beast you are using, but I can't really see taking 15 or 20% fuel out being a bad thing.
Thoughts??
Thoughts??
TallTom
50
07-08-2022 09:54 AM
ballerchris510
09-10-2015 09:35 PM
