hope for about 30/ 35 more
Old 11-16-2013, 06:07 AM
jcap's Avatar
Got a simple question was thinking of 3.5 hr cams and valves plus gasket match and light porting, what do uz guys think it would add power and torque?
jcap is offline
Old 11-19-2013, 10:27 AM
dot dot dot ...
NmexMAX's Avatar
You can gain nearly 50 whp with just bolt ons, something I'd suggest before cracking open the engine.
HR Cams very slightly more aggressive (.04"), HR valves are slightly smaller than the DE. So, not sure you'd gain anything there, also, the heads are different, so, unless you're swapping HR heads, not sure this does anything for you.
The majority of the extra power comes from dual path intake, dual MAF's, CVTC on the exhaust cam, more aggressive CVTC map on both cams, better flowing heads & intake manifold, and of course all that is brought in unison with the ECU.
Little background on your current set-up would be nice to see where you're at.
NmexMAX is offline
Old 11-19-2013, 01:02 PM
kenc15's Avatar
what year and car is your 3.5 from?? mine is from an 03 & a friend told me 350z cam was a little more agressive. hr looks like it might be more trouble than its worth
kenc15 is offline
Old 11-19-2013, 03:56 PM
dot dot dot ...
NmexMAX's Avatar
RevUp's came with slightly more aggressive cams and is not an HR. But if i were doing cams, I'd want to make it count.
NmexMAX is offline
TallTom
50
07-08-2022 09:54 AM
aw11power
10-10-2021 04:57 AM
mclasser
22
11-12-2020 01:58 PM
06-06-2017 02:01 PM
bernyp
10-02-2015 10:10 AM
Quick Reply: hope for about 30/ 35 more
