All MotorAll Motor Advanced Performance. Talk about Engine Swaps, Internal Engine work. Not your basic Y pipe and Intake Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
I had my Innovate XD-16/LC-1 and PLX M300 both connected at the same time and the PLX was reading basically the same as the Innovate. The Innovate kit is not really reliable at all, most of the time that I had it, its been giving me an error code so I kinda of regret swapping the PLX out.
anyone notice that they ran for an hour on leaded reace gas before testing? not sure why they would do that, but i would bet if they hadnt used leaded gas all of the results would have been more accurate
I saw this a while back - i wonder how much it might vary from controller to controller. If you got 10 of the same model wideband controllers and tested the variance between them.
__________________ 95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR 3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
I guess im just kind of annoyed with the Innovate unit. The first one, the LC-1 came DOA so they sent me a replacement. It worked well for a few months, then once in a while it would give me an E-8 code and sometimes an E-2 code. Right now all it does is give me an E-8 code and does not work at all. I think the code is related to an issue with the sensor so Ill try out another one but I have a feeling something is up with the LC-1 unit. Maybe im just having bad luck with it so Ill take back what I said about it being unreliable.
Credit really goes to another member at my350z.com who shared that with me. I was leaning towards the Innovate LC-1 or PLX R-300 to begin with, so now it is just a matter of finding a good deal on one.
Neal brings up a good point about brand quality though. I'm assuming most "big" names will have decent quality control, then again, you never know I guess.
The only units that I know of that you can calibrate are the Innovate and TechEdge. (I have both) They mention the TechEdge in their article but I was disappointed they didn't test it.
The best authoritative read about the Innovate vs the others is here.
my350z.com has a deal for the LC-1 for $325 shipped in the Vendor Classifieds section.
I have the zeitronix and im happy with it so far. But i may change later.
__________________
97 SE Auto Built Auto
97 SE Holset HX52|N2O|6 SP|Built 3.56|More to come
91 GXE Auto bone stock beater
91 GXE 5sp Another beater
Led retro's Pm me
ya i was going to buy a AEM WB but then i saw this chart and started reading reviews of the innovate WB's. Everyone seems to love them so i'm getting the LC-1 and an LED display, i don't want the big guage.
For people with the UTEC or planning to get a UTEC, see Jime's comments on the TurboXS Tuner as well:
Quote:
Originally Posted by Jime
If you want the best W/B setup go with the TurboXS Tuner, it is the most compatible. I have used the Tech Edge as well as the LC-1 and LM-1 and like everyone else with the UTEC experienced lockups etc. You can pick up a used one for around $200 on either the 350Z or NASIOC forums.
Quote:
Originally Posted by Deckdout2
That's very helpful info, thanks Jime. I've been searching for the most trouble free WB. I'll see what more info I can find on it and if I can have one for a good price.
BTW the TurboXS Tuner is the only W/B that will display\log with the terminal software, UTI3 and MPS UTEC Logger will work with some of the others if you are interested in them. Check their sites to see which W/B's will work with them. I prefer UTI3 over the MPS UTEC Logger for ease of use and tuning
Even though the TurboXS Tuner is the only one compatible with the default software, would you consider it the best option overall since other W/B options can be used with the 3rd party software?
Yes, as I indicated I was experiencing lockups etc with 3 other widebands but with the Tuner none. If you read some of the 350Z forum threads this is a common experience with the 3rd party software and a non-TurboXS wideband. I eventually gave up using my LC-1, LM-1 and TechEdge because of that and got the TurboXS Tuner, I could have saved myself a lot of grief and money had I did that in the first place.
The other widebands are great and perform well on their own, just not with the UTEC.
BTW regardless of which third party software you use, you still have to use the terminal program to make any changes to the UTEC so better get fluent with it.
Possibly the stupidest question i have but... are we suppose to run one LC-1 or is it best to have two units? I dont know where I saw this posted, but someone had a bunge up by or around the headers, and then another further down the exhasut.
Is this helpful, or not really needed?
Not needed. Just place the sensor right after the "Y" in the y-pipe. You'll be set.
__________________
99 Max SE 5 spd, SC'd, MEVI, Cattman Headers, LED tails, R34's with S2000 projectors, 13.1" Brembo BBK, EU.....381 HP/323 TQ
