Suprastick V4 The latest weapon for automatics
#282
I think I will be giving in to temptation and doing this as well, this has just become to tempting....My tranny will need to be rebuilt before this though as it is slipping really bad, but is there anything you guys would do to your auto tranny to make it better? As in what internals would you like to change if you had the opportunity?
I should note I will probably do the flappy-paddle gearbox, since I'm quintessentially british.
#283
as far as making the auto tranny better, do transcooler, valve body upgrade, higher stall TC. as far as internals, i thought i saw someone on here promoting beefier gear syncros to withstand more abuse. i forget the guys name...
#284
my tranny is slipping pretty good too and its kinda annoying. i dunno but sometimes at 5% throttle while in 3rd it would always jump to 4rth then back to 3rd over and over. and others from 1st it would even skip 2nd gear and go to 3rd.
BTW g4 I was looking on that LCD matix display website, can I use any of the displays? I want a red one
#285
Yeah my tranny does the 3rd to 4th to 3rd all the time. I have a trannycooler and I'm running Amsoil tranny fluid. I was about to buy kevlo's TC but saw it was sold. I know Jime talked about using gears from an older altima, I'm curious as to why he wanted to?
for the LCD display, make sure its 16x2 and it MUST have the serial output port in the back. also, don't buy it from the Canada Matrix orbital cause shipping is like $30+ something. it took me a while to find another distributor in the US that offered the one i wanted w/ lesser shipping charge.
buy it from Mouser electronics. here is the one you should buy since you want red:
http://www.mouser.com/Search/Refine....user_Wildcards
also, if your really thinking about doing this, read up on my HOW TO for like all the other MISC parts you need for the LCD screen.
#286
#287
yeh i haven't had the time to mess around w/ the shift table for the auto mode to fix the slipping issue so i just been driving around in manual mode this whole time. i think Jime mentioned using the altima gears cause they had slighter longer gear ratios or something, i could be wrong.
Thank you for finding that, now I need to find a place to put everything....
#288
You sure ur auto is slipping dude? it sounds like a software problem maybe your mph to shift 3>4 is set to high. I have mine to shift into 4th at about 30mph or so, also look at what mph ur downshift 4>3 is at. that could be the problem. cuz if the auto its slipping i dont see how it would go 3 to 4 and back, if it slips then it means it wont go into the next gear or ever catch the next gear.
i guess this is where the logging feature would be useful for me. i haven't even tried that out yet, have you? do you just enable it then drive normally in auto and it'll record your data or something?
#289
Well I'm going to pair the whole system with a carputer and lilliput display in-dash montior so I can change things on the go, this will also be paired my EU too, so there will be no need to use my laptop in the car.
#290
For those interested in doing paddle shifters I have found these:
http://www.worksbell.co.jp/en/produc...paddle_neo.htm
For the 5th gens I know for a fact that the 350z hubs with fit on our car. So this going to be paired with my new momo steering wheel. I'm very happy that I am going to stay auto and have these for daily use.
I do want to ask jime and the ones who have done this, is the shifting as delayed as what is in seen in this video...
http://www.youtube.com/watch?v=v4WDtIpAtt4
#291
Manual shifting is only for playing around, for real performance shifts adjust the automatic points to maximize your et's. I only use the manual shifting to tune, ie starting in 2nd gear from a stop to 7k for a/f.
#293
#294
SO....I'm picking up an auto tranny for $75 with 44,000 miles TEHE!
So I am going to have a shop clean and rebuild it for me. I emailed Protorque about their TCs, they go for 350 new. My only question is what about Don's VB mod? or does anyone have any info on where I can get a VB...I'm excited.
#295
and what is protorque's TC rated at, meaning stall speed?
#296
#297
#300
#303
#304
the suprastick dosnt increase the pressure, it just controls the solenoids on/off (shifts), but does not deal with the pressure, that would be the drop resistor mod which hopefully you have set up.
#306
#308
Seriously, if or when you have all the infos to order please keep me in the loop as I'm willing to order at anytime.
P.S: I took a look at those shifting paddle and I'm thinking of doing it with the Suprastick, I'm not ready yet but probably around jan - feb 09 once the car is painted and the engine is installed.
#311
I still using it, the currest fastest maxima in the country, and fastest all motor maxima still have it as well. Its a great investment no matter what type of racing your doing, paddles would be cool, i almost went that route but didnt wanna spend the money for paddles.
#312
#314
Would it be possible in a 5.5 gen to use the lighting and windshield wiper selectors as "paddle shifters"? I mean use the high beam flashing movement and the windshield wiper fluid movement to create look-a-like paddle shifter use.
#315
Is it possible to lock second while in manual mode. Just got this max from my grandma (no jokes please) this car has so much potential, mainly want suprastick for the manual aspect considering every car ive owend has been stick.
#316
Yes, you can lock it into 2nd gear with manual mode. With the Suprastick in manual mode, you can lock in any gear and it will stay in that gear no matter how much throttle you apply.
#317
It's possible the 'momentary-ON' windshield washer switch could work to shift up OR down. One or the other. But the high beams switch isn't a momentary-ON switch. Plus, you may lose the function of your washer fluid and high beams. I'm not sure without looking at the schematic.
But it's much easier to just get a different switch. I am using the dash light illumination switch that comes in the 1992 Maxima. It dims or brightens the dash lights and is a momentary-ON rocker switch. So I can shift up or down with that one switch. I have it zip tied to my parking brake. It works great for me.
#318
I used my cruise control switch, up upshifts, down downshifts and middle upshifts (middle button actually applies 12v to both up and down wires, but the suprastic's logic knows you mean to upshift. Pretty damn cool device, get it! wont regret it.
Andy29
09-29-2015 05:32 AM
