My 00vi Swap, step by step & members advice.
Old 01-06-2008, 09:42 PM
  #81
MOHFpro90's Avatar
Pics!
FULL ALBUM: http://s23.photobucket.com/albums/b361/MOHFpro90/00VI/
There are very few shots of me...mostly because Im the one taking the pictures...
Dont remember why we were laughing...
MOHFpro90 is offline
Old 01-06-2008, 09:45 PM
  #82
MOHFpro90's Avatar
Modifying rear Valve Cover:
Finished Valve Cover:
Tapping the LIM:
Old 01-06-2008, 09:47 PM
  #83
MOHFpro90's Avatar
[reserved space]
Are the pics too big?
Old 01-06-2008, 10:00 PM
  #84
MOHFpro90's Avatar
[more reserved space in case...]
Old 01-06-2008, 11:32 PM
  #85
spdfreak's Avatar
Originally Posted by MOHFpro90
Two questions.
Why did you place that fitting into the valve cover?
And why did you have to cut and JB weld the valve cover? To get away with using a 5th gen valve cover?
spdfreak is offline
Old 01-07-2008, 04:47 AM
  #86
MOHFpro90's Avatar
Yes, that fitting was for a PCV valve. Yes, I used the 4th gen valve cover so I didnt have to get A33 rear valve covers and coils.
Old 01-07-2008, 06:58 AM
  #87
spdfreak's Avatar
Where was the 4th gen PCV valve originally?
spdfreak is offline
Old 01-07-2008, 09:55 AM
  #88
XAugusta MoonX's Avatar
On teh side! The 5th Gen valve cover has the PCV on top.
XAugusta MoonX is offline
Old 01-07-2008, 02:42 PM
  #89
MOHFpro90's Avatar
Other way around, check this out:
Thread:
http://forums.maxima.org/showpost.ph...6&postcount=20
Old 01-07-2008, 03:01 PM
  #90
MOHFpro90's Avatar
Oh, and IT STARTED! I took it to a mech, they hooked up a sweet smoke machine, and it was a huge vacuum leak...upper manifold gasket. It was on the back of it, so it was really hard to see/hear before. Anyhow, we put the A32 gasket on(the A33 was shot) and there is a small leak to where I idle high, but it runs great. I am going to work on that this weekend, just after classes this week.
Old 01-11-2008, 07:01 AM
  #91
MOHFpro90's Avatar
Installing EVAP nipple.
Old 01-12-2008, 05:33 PM
  #92
ajcool2's Avatar
What size is that nipple?
ajcool2 is offline
Old 01-12-2008, 06:52 PM
  #93
aznsap's Avatar
seems like you guys like to drill and tap.
aznsap is offline
Old 01-12-2008, 08:07 PM
  #94
MOHFpro90's Avatar
Ah yes, sorry I forgot to put that. It was a 3/8" nipple with the smallest diameter threads they had at Ace. It was 1/4 inch something, not sure whether it was thread pattern, inner diameter or outer.
Aznsap, works well and its easy. That took me 5 minutes with 3 different step-up bits.
Old 02-06-2008, 04:45 PM
  #95
MOHFpro90's Avatar
Alright, Ive been having a vacuum leak lately, I think(high, fluctuating idle). I was wondering what gasket is better to use for the Upper? 4th or 5th gen?
Old 02-07-2008, 07:02 AM
  #96
Horizontally opposed.
mowgli29's Avatar
I used the 5th gen gasket. then again, I have the 5th gen lower too. Still, I think the 5th gen gasket is your best bet. Since the 00VI has that groove for it's gasket I think you might have more leaking problems using the 4th gen gasket. and when you drilled he 4th gen lower, you filled the old holes right? so the 5th gen gasket should make a nice seal on the 4th gen lower. IMO....
mowgli29 is offline
Old 06-30-2008, 06:39 PM
  #97
Facelesslegion's Avatar
What Parts (exactly) do i need for the 00vi swap just whats necessary ? Thank you
Facelesslegion is offline
Old 06-30-2008, 07:45 PM
  #98
G4nismo's Avatar
http://tatanko.boredmder.com/
G4nismo is offline
Old 01-14-2011, 05:05 PM
  #99
smx2's Avatar
Great Resource!
I have read many many threads about 00vi and I have decided to do this using build # 6 entails....
00 Upper and 4th gen Lower, 4th gen Fuel R&Inj, 00 TB w/ 00 IACV, and 00 EGR guide
To make this as easy as possible what I don't understand is why you cant just use an 00vi LIM and just get away with connecting the A32 rail and injectors???? I suppose this is because the LIM injector physical mount points must be a different size, due to the different cc of the injectors (240 as opposed to 270) so the LIM is machined to accommodate this and hence you have to go A32 LIM with A32 rail. It would be so much easier if you could just use a A33LIM with 4th Gen rail and not have to prepare the 4th GEN LIM.
smx2 is offline
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
04-16-2020 05:15 AM
gigabyte
01-06-2017 06:05 PM
Quick Reply: My 00vi Swap, step by step & members advice.
