Crank trigger disk teeth count
Old 08-27-2007, 10:34 AM
Only gentoo powered Maxima!
rmh3093's Avatar
Cam and crank signals
I just wanted to double check since I couldn't find it posted anywhere. Does the crank trigger disk have 180 teeth?
rmh3093 is offline
Old 08-27-2007, 12:10 PM
nismology's Avatar
I can see where this is headed. You're not planning on starting a brand new thread for every question you have concerning your future MS setup, are you?
nismology is offline
Old 08-27-2007, 01:27 PM
Nissan maniaco conpulsif
hightuner's Avatar
, i will try to find info on the fsm,
hightuner is offline
Old 08-27-2007, 01:33 PM
rmh3093's Avatar
Originally Posted by hightuner
the one on the ring gear is 360
is that a 3.0 flywheel or 3.5 cause i think they are different and I need the specs of the 3.0....
from http://forums.maxima.org/showpost.ph...67&postcount=1
i count 180 on this pic which is supposed to be for a 3.0
rmh3093 is offline
Old 08-27-2007, 01:41 PM
rmh3093's Avatar
i only have 1 more 2 more questions that I havent asked, and the info isnt necessarily related or helpful for only MS installs, its good info about the VQ motors that isnt posted anywhere yet
rmh3093 is offline
Old 08-27-2007, 02:14 PM
hightuner's Avatar
Man lol , i never count it , i just took someone word .
it looks like your right
its 180
I confirm this is my 3.0 96 resurfaced.
from what i read , this is too much for the ms, i wonder how much is the other one.
Old 08-27-2007, 02:24 PM
rmh3093's Avatar
its 180
i think i can use a hardware divider circuit (couple bucks) 180/4 = 45 which would bring i think is ok with the MS
EDIT: acutally i think an even number is needed so 360/5/2=36 and 360/6/2=30
rmh3093 is offline
Old 08-27-2007, 02:39 PM
nismology's Avatar
Cool. Just wanted to make sure we were on the same page.
But to answer your question, yes it is 180 teeth. 180 teeth and 180 spaces to make up the 360° signal.
Old 08-27-2007, 07:26 PM
Ichiban King
Apparition's Avatar
What would we do without you..
Apparition is offline
Old 08-27-2007, 07:55 PM
rmh3093's Avatar
Alright so if the crank trigger wheel has 180 teeth... now with regards to the crank sensors... does reference signal fire a pulse once per revolution when cyl1 is at TDC? and does the position signal fire 180 pulses per revolution or 360 pulses per revolution?
rmh3093 is offline
Old 08-27-2007, 08:54 PM
3.5 in the works
DandyMax's Avatar
IIRC the REF sensor is 2 teeth at TDC, and one at 120 degrees and at 240 degrees (all relative to #1 TDC). The POS sensor is a square wave, corresponding to gaps and teeth on the ring, and used only to establish rpm, it's blind to piston position. See below...
From my first EU thread back in the day... all the crank and cam signals scoped...
Originally Posted by DandyMax
Speaking of waveforms...
Here's the cam signal.
Here and here for the crank signal.
Didn't get a chance to get more signals scoped last night - did it this afternoon instead.
Here we go:
Cam and REF 1
Cam and REF 2
REF only 1
REF only 2
DandyMax is offline
Old 08-27-2007, 09:06 PM
rmh3093's Avatar
ahh i knew i saw this a long time ago when i first read your thread... thanks for the links
rmh3093 is offline
Old 08-28-2007, 06:24 AM
hightuner's Avatar
thanks DandyMax
It looks like its very near to what GM DIS Ignition
exept it work whit 60 instead or 120 , dont know if theres is a way to mod it or somthing
Old 08-28-2007, 08:32 AM
hightuner's Avatar
It looks like i read too fast ... once again
what dandy descibe is the opposite as GM
is this what you mean dandy ??
Old 08-28-2007, 09:44 AM
rmh3093's Avatar
this also seems similar to the buick C3I: http://megasquirt.sourceforge.net/extra/setup-c3i.html
rmh3093 is offline
Old 08-28-2007, 08:56 PM
rmh3093's Avatar
one of the programmers on the ms2/e forum can probably write support for the crank ref + cam signals if we can draw out a timing map like the other ignition systems have...
are there any pictures of that crank ref plate? and what generates the signal for the cam sensor?
here is another photo from the FSM that migh help us out:
rmh3093 is offline
Old 08-29-2007, 06:31 AM
hightuner's Avatar
sup guys , can anyone confirm that Vq35 cams have the same groove as the VQ30 ???
Old 08-29-2007, 07:55 AM
eng92's Avatar
They are not even close. VQ30 cam sensor is on the timing cover and picks up off the sprocket. The VQ35 sensors are on the rear end of the valve covers and pick up off that trigger that you have pictured above.
Dan posted the VQ30 cam waveform above.
The VQ35 crank and cam waveforms are given here:
http://forums.maxima.org/showpost.ph...53&postcount=3
eng92 is offline
Old 08-29-2007, 08:34 AM
hightuner's Avatar
Thanks Eng92 ... appreciated
is this the reason why ppl need to put a cam adaptor (vq35 swap A32 ecu) ?
thanks
Old 08-29-2007, 09:37 AM
rmh3093's Avatar
hightuner, i found this interesting... seems like our cars run in batch fire mode on startup then switch to sequention once its up and running
rmh3093 is offline
Old 08-29-2007, 02:42 PM
hightuner's Avatar
interesting , and odd.
Old 08-30-2007, 07:13 AM
rmh3093's Avatar
DandyMax, do you by any chance have a scope of the cam vs. crank pos and the crank rev vs. crank pos? or if you still have access to that scope could you get these signals for me please?
EDIT: Are all those scopes with the engine running at the same RPM?
rmh3093 is offline
Old 08-30-2007, 01:16 PM
rmh3093's Avatar
this is my best first attempt to turn the time based scope images into a degree based timing map.... can people look over this and see if it is accurate, thanks!
rmh3093 is offline
Old 09-02-2007, 02:23 PM
rmh3093's Avatar
Does this look right to anyone that has scene the crank ref signal plate?
rmh3093 is offline
Old 09-04-2007, 06:32 AM
rmh3093's Avatar
can no one really confirm or reject any of this?
.... this is all thats keeping the megasquirt devs from writing code for our stock sensors!
rmh3093 is offline
Old 09-04-2007, 08:34 AM
3.5 in the works
DandyMax's Avatar
I haven't had time to check any of this, sorry. You don't have a cam sprocket/REF ring to compare? IIRC the scopes I posted above were done at idle and 2000 rpm.
Are they writing the program based on those 2 signals?
I'll try and look over your timing diagrams later tonight if I get a chance.
DandyMax is offline
Old 09-04-2007, 11:13 AM
rmh3093's Avatar
no i dont have cam sprocket or crank ref ring to compare too...
they said if I could draw a timing diagram with the crank ref and cam signal (in degrees) then they could write the code... but the i has to be relative to degree and the scopes are in milliseconds
if I could get a scope of the crank ref vs crank pos and cam vs crank pos then there should be no issue in converting that to degrees
thanks for your help!
rmh3093 is offline
Old 09-04-2007, 12:34 PM
eng92's Avatar
The signals are periodic. You can calculate the degrees of separation directly from the scope outputs
eng92 is offline
Old 09-04-2007, 02:09 PM
rmh3093's Avatar
thats how I generated the ingition map 2 posts above, but its an estimate... not exact, thats why i want confirmation
... from the looks of the cam+crank ref 2 scope, it seems like there are exactly 150ms between each crank trigger and each grid is about 10ms apart so that would mean 120/180 = .8 degrees per 1ms or 8 degrees per 10ms
it also appears from those graphs that on the crank ref plate the second tooth at TDC starts 10 degrees after the first one.... that what i have been able to come up with
rmh3093 is offline
TKHanson
11-24-2018 01:39 AM
chisam14
11-06-2018 08:56 PM
09-27-2015 08:37 AM
zmcneely13
09-26-2015 02:26 PM
msellas
09-23-2015 09:16 PM
Quick Reply: Crank trigger disk teeth count
